Old 20th July 2015, 10:02   #31
Thanked: 165 Times
Default Re: Photograph Scanner
Aroy, condor and alpha, thank you for the valuable inputs, although the whole exercise went in vain. Here is the procedure I followed to scan papers into PDF -
  1. Download "Sonic PDF Creator Version 3" software and install it.
  2. Scan papers at 200 DPI and save them as jpg.
  3. Open the jpg images in Microsoft Picture Manager and compress them into "Documents", so that their size is reduced to less than 100 KB.
  4. Once the images are compressed, give the print command. Select the Sonic PDF Creator option and convert the jpg image into PDF.
  5. Alternatively, I could also scan by using CamScanner.
Now I had the PDF files of size less than 200KB, scanned at 200 DPI. All as per the Department's wish. I attached the files with the application, They got attached and the application was uploaded successfully.
What happens today is, I checked my email. I got one from the Department, stating that my application has been rejected. Reason? None of the PDF files could be read on their Adobe (Adobe Reader 11). I was also told that of the 12 applications, 10 were rejected on the same grounds. Those who did this using CamScanner were also rejected. Now I have to do the whole exercise again.
Swapnil4585 is offline   Reply With Quote
Old 20th July 2015, 13:34   #32
Thanked: 1,082 Times
Use CutePdf, it is compatible with Adobe Reader. To ensure portability, install the Adobe Reader 11, and check your final files in this.
http://www.cutepdf.com/Products/CutePDF/writer.asp
Enter,National Geographic 'Photograph of the Year' contest 2010 fazalaliadil Shifting gears 29 29th November 2010 04:49
OBD-II scanner for Gypsy COUGAR Technical Stuff 5 21st December 2009 20:03
OBD-2 Handheld Scanner NPD: Survey subache Shifting gears 3 16th November 2009 14:31
High-end imported bikes under Customs scanner downsouth Superbikes & Imports 4 2nd December 2008 22:48
You cannot photograph your car!? BaCkSeAtDrIVeR Shifting gears 1 17th January 2008 20:21
