Old 30th May 2010, 14:28   #2236
nishantgandhi's Avatar
Thanked: 151 Times
Originally Posted by ashthedivx View Post
Not sure, logically it should not. Else they'll start loosing their "899 plan" customers
Well not really. VMC is still pay-as-you-go (5p/10kb billing), as opposed to 899 unlimited plan. So there are high chances that people might spend more on BB Lite 299+VMC 199 plan.
nishantgandhi is offline   Reply With Quote
Old 30th May 2010, 14:43   #2237
Thanked: 245 Times
The waiting sure did worry me a little.. but mission accomplished
Now the Bold is on 5.0.0.592!
Thanks for your help mate
Remove vendor.xml
Remove any network connections
and that should be it, have upgraded so many times.
Btw, 5.0.0.681 is the new version which was released few days back, has faster boot times.
Old 30th May 2010, 15:00   #2238
Thanked: 3,632 Times
Originally Posted by dadu View Post
Remove vendor.xml
Yep i removed vendor.xml file and the sim card before flashing.
I downloaded 5.0.0.681 etisalat package just now Dadu any other pack i should try? All Indian releases are at 592.
Thinking whether to upgrade...
Btw where have the Blackberry maps disappeared to? I cannot see it in the main menu.
Old 30th May 2010, 15:01   #2239
ashthedivx's Avatar
Thanked: 22 Times
Remove vendor.xml
I ain't sure if you case is same as ours i.e. we aren't subscribed to BIS plan. 5.0 will not in any case if you aren't on BIS plan !!
Old 31st May 2010, 12:56   #2240
SohailPistawala's Avatar
Thanked: 20 Times
done all of the above for my 8520 after doing the apploader and updating the software it does show the 5.0.6XXx but after doing next it says searching for avaliable software then a screen says no software update required for this device....?? what next?
SohailPistawala is offline   Reply With Quote
Old 31st May 2010, 14:27   #2241
If you do as said in the quote below, it should work.
It's tricky. Switch off your bb, remove battery from bb, make sure vendor.xml is deleted.
Now you have to be really fast, attach usb wire with BB, add battery to mobile, quickly start Loader.exe, it will show "unknown" port (Most important step to watch out), click next-next-next, now you can update it.
Note: Be Fast
I made a slight variation in the process mentioned by Ashish, but its more or less similar.
Pull out the battery from your BB.
Connect it to the PC.
Start Loader.exe (vendor.xml should be deleted)
It detects the device "USB: Unknown PIN"
Click Next and Put the battery in the device.
And follow the steps.
Btw this worked in Bold, may work in your Curve too.
Now my Bold is on OS 5 681 release.
Old 31st May 2010, 14:43   #2242
nandishpal's Avatar
Thanked: 56 Times
how do i remove vendor.xml??
how do i load run loader.exe?
i am using 9700 bold2
nandishpal is offline   Reply With Quote
Old 31st May 2010, 14:58   #2243
SumitBahl's Avatar
Thanked: 219 Times
C:\Program Files\Common Files\Research In Motion\AppLoader
In the same folder you will find loader.exe
After you have deleted the vendor.xml file, run loader.
SumitBahl is offline   Reply With Quote
Old 31st May 2010, 15:03   #2244
Thanked: 20 Times
Sankar its doing the process.. as i am typing this. Thanks Buddy. keeping my fingers crossed.
Old 31st May 2010, 15:55   #2245
Thanked: 20 Times
successfully done but the phone has got slow and i am not liking it now!
Old 31st May 2010, 16:14   #2246
mukeshgoel's Avatar
Thanked: 379 Times
Newest Official Bold 9700 OS 5.0.0.680
Package Version: 5.0.0.1149
Consisting of:
Applications: 5.0.0.680
Software Platform: 5.1.0.160
File name: 9700jEastAsia_PBr5.0.0_rel1149_PL5.1.0.160_A5.0.0. 680_Hutchison.exe
File size: 128.04MB
https://www.blackberry.com/Downloads...2BAA6EBC8B872D
mukeshgoel is offline   Reply With Quote
Old 31st May 2010, 16:24   #2247
Thanked: 245 Times
It doesnt matter what plan you are on, as long as you follow what I wrote. The plan has got nothing to do with this upgrade.
You are already on the latest version, "what next" do you want.
Old 31st May 2010, 17:27   #2248
It has become faster on the Bold and cursor movements etc are very smooth. A friend updated his 8520 yesterday (his was BIS active, so did the regular way) and he is happy with the update.
If the Blackberry service isn't enabled on the Blackberry device, which is trying to be updated, the update doesn't work.
I followed the regular method using loader and desktop manager before i had to fall back on the battery pull method. Mine is not yet on a BIS service. OS can even be updated online and they specifically say that a BIS (any) plan should be active on the phone.
Old 1st June 2010, 16:00   #2249
Exclamation
Originally Posted by pranavt View Post
1, 2, 3: Contact Vodafone regarding this. Tell them you are travelling abroad and need the unlock code because you don't want to pay roaming charges. Make up some details if they ask you when and where. If they refuse, escalate it to the Nodal Officer. Stay adamant that you want your handset unlocked. They are required to provide the unlock code to you, do not pay anyone a single penny to do this. Once you have the unlock code, just follow this guide:
How To Unlock RIM Blackberry Curve 8900 | Mobileslate
The Vodafone rep will give you the Network MEP code, enter it in the above screen.
Thanks. Got this done.
victor0012 is offline   Reply With Quote
Old 2nd June 2010, 13:53   #2250
Thanked: 20 Times
[quote=Sankar;1913974]It has become faster on the Bold and cursor movements etc are very smooth. A friend updated his 8520 yesterday (his was BIS active, so did the regular way) and he is happy with the update.
Sankar, it is performing better for me too. Hope it continues. thanks for the help.
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
