Old 21st June 2010, 12:34   #2341
normally_crazy's Avatar
Thanked: 393 Times
Dropped my Blackberry face down and screen has gone kaput. Calls and everything are working fine.
Where do I get the screen checked and repaired / replaced in Mumbai ??
It's urgent fellows.
normally_crazy is offline   Reply With Quote
Old 21st June 2010, 12:43   #2342
viper's Avatar
Thanked: 9 Times
Gautam,
Either a BB service centre, Heera Panna or Alfa.
You might consider investing in this.
BlackBerry Curve 8900 Defender Series Case // OtterBox.com
Viper
viper is offline   Reply With Quote
Old 23rd June 2010, 00:18   #2343
speedfreak01's Avatar
I just bought a BB 8520 .. its not really a fancy phone but fits my needs perfectly
Anyway .. I'm facing some problems with bluetooth .. I am able to send files without any problems but cannot receive them .. what should I do? Is this a common problem or I have a defective piece..?
speedfreak01 is offline   Reply With Quote
Old 23rd June 2010, 02:11   #2344
Xehaust's Avatar
Thanked: 74 Times
You just need to learn the procedure for bluetooth use in BBs
In order to recieve a file, the sending device needs to be already paired with your phone & then you need to go into Media, click on the option button, and then select recieve file.
This whole procedure is for increased security. There is no other way to recieve a file.
Hope this helps.
Xehaust is offline   Reply With Quote
Old 23rd June 2010, 13:08   #2345
Thanks .. it really helped
Old 23rd June 2010, 18:59   #2346
Xehaust's Avatar
Thanked: 74 Times
Your always welcome
Old 28th June 2010, 10:33   #2347
Thanked: 13 Times
How does one get a Blackberry pack active on a prepaid sim on Airtel in BLR
BB pack = Internet/messenger service?
Thansk guys.
Old 28th June 2010, 11:48   #2348
nandishpal's Avatar
Thanked: 57 Times
send a message to
121
AIRTELBB . then select the plan according to your requirement.you should have balance of 300 & above for the same.
nandishpal is offline   Reply With Quote
Old 28th June 2010, 19:15   #2349
Sahil's Avatar
Thanked: 2,602 Times
My BBM status updates have been very delayed, for instance I have been back in Bombay for a week and people still have my status as the city I was last in.
Google returned results that said if you contact list is more than 100 there are lags. Is this true? And how can one resolve this problem?
I try and be picky with the people I share my pin with but it's hard to delete people once they are already on your list
Old 28th June 2010, 20:23   #2350
Akshay1234's Avatar
Thanked: 6,986 Times
thats true. once you cross 100 your statuses dont change for many people. youll have to keep it below 100 if you want your status to work.
oh btw MUMBAI guys - i discovered this place in opera house called colormii. they can change your blackberry any colour. they use original blackberry bodies which are coloured and coated in the us and import them here. the finish looked pretty good, as good as the original. they have many colours and you can mix and match as you like. for the 9700 it costs 3000 for the whole body. they also sell phones and exchange old ones.
id recommend them to anyone. good for personalizing since bb's are getting soo common nowadays.
Old 28th June 2010, 21:01   #2351
better4worse's Avatar
At colormii, did you manage to see a BB with sunburst cover finish, just as you have on the guitars ?
- B4W
better4worse is offline   Reply With Quote
Old 29th June 2010, 06:59   #2352
Thanked: 13 Times
Originally Posted by nandishpal View Post
send a message to
121
Is that it? So that will transition a regular prepaid to become BB enabled?
How reliable is the BBM on prepaid?
Thanks!
Old 29th June 2010, 13:41   #2353
sajands's Avatar
Thanked: 139 Times
Fellow BHPian's,
I got myself a BB 8900 curve. Need help on how to add themes into the phone. each time i connect the phone to the PC and open the BB Desktop Manager, It does not show the complete list under application loader and under browse tab does not acecpt to add the theme from the desktop into the phone. Need help.
Also which is the best navigation map for the curve 8900.
sajands is online now   Reply With Quote
Old 30th June 2010, 11:20   #2354
ashthedivx's Avatar
Thanked: 22 Times
Well, I usually download themes via Over The Air Links. As easy as 1-2-3.
Garmin and Google are available for BB, Google is the best one as garmin still dtruggles with old maps.
Old 30th June 2010, 11:50   #2355
sajands's Avatar
Thanked: 139 Times
Thanks ashthedivx,
How do i download BB worldApps into the phone , says my 8900 curve does not meet the requirements.
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
