Old 3rd July 2010, 20:21   #2371
sajands's Avatar
Thanked: 135 Times
Originally Posted by ashthedivx View Post
You are not on BIS plan, right ??
Hi ashthedivx,
I am on the 899 BIS plan.
sajands is offline   Reply With Quote
Old 3rd July 2010, 22:20   #2372
ashthedivx's Avatar
Thanked: 22 Times
Originally Posted by sajands View Post
Hi ashthedivx,
Then you must be missing some step. Try going through the mentioned steps.
How To: Upgrade your BlackBerry Operating System (OS) | BlackBerry Rocks!
EDIT: Are you deleting vendor.xml before up-gradation ??
Old 4th July 2010, 12:49   #2373
sajands's Avatar
Thanked: 135 Times
ashthedivx,
Thanks for the help so far. Yup, I have deleted the vendor.xml file after which connected my BB 8900 to the comp.
Old 5th July 2010, 01:26   #2374
sajands's Avatar
Thanked: 135 Times
ashthedivx,
I have tried all steps including getting into the Windows Regisry in the PC and deleting the RIM entries.
I am still not able to upgrade the OS using DM or Loader.exe from C:\Program Files\Common Files\Research In Motion\AppLoader
I even ensured that I delete the vendor.xml file, restarted the PC and also tried switiching OFF the phone still I am not able to get the update into the phone.
How does one unzip a zip file in device? which is the best freeware application for the same.
this is the screen shots in BM and Loader.exe as below when I try to update the device. help.
When I run the DM, I can see the update 5.0 and it says to click on next in order to start the update after which I get the screen below, both the Options and Settings tab are greyed out.
When I try running the update from Loader.exe, this is the screen that I get stuck at.
Old 5th July 2010, 06:42   #2375
classicselva's Avatar
Thanked: 22 Times
Tried the options quoted to use browser withOUT BIS/BES in my BB 8100, no luck.
can any one share their own steps and the BB SERVICE BOOK ENTRY for Airtel.. please
classicselva is offline   Reply With Quote
Old 5th July 2010, 10:59   #2376
ashthedivx's Avatar
Thanked: 22 Times
I am on Airtel as well, Are you following steps specified religiously.
And most importantly, did you changed "browser type" in browser options ??
ashthedivx,
Strange it is !!
Two Questions :
1. Did you recently shifted to BB Services?? There might be a possibility that BIS haven't been activated on your SIM.
2. Most importantly I hope you are upgrading handset with your BB activated sim inserted inside phone. Right ??
As the second screenshot cleary states that Desktop Manager could not find BIS plan hence not upgrading firmware.
Old 5th July 2010, 11:04   #2377
Ardy's Avatar
Thanked: 86 Times
I am using a BB8900 that I have upgraded to the version 5.0.0.681
I have been noticing that there are times when I see multiple copies of SMS from the same person lying the SMS folder.
For example, if I receive an SMS from Mr. A, to which I reply and I send a new SMS to Mr. A and Mr. B and then delete this last SMS, I find a duplicate of my conversation with Mr. A in my SMS folder. Do anyone know the remedy? Also, is there a way to make the view more like individual SMSes and not as a conversation?
Cheers,
Ardy is offline   Reply With Quote
Old 5th July 2010, 12:41   #2378
Thanked: 22 Times
ashthedivx, Thanks for your continued support and i really want my BB8100 to have the browser without BIS/BES.
BB 8100 i have is, purchased in US from T-Mobile, it is unlocked and i am using in Airtel network for the past 3 years.
I followed extacly the same process that you have sent, the point that I did not understand is
"Open backup file (.ipd) containing SB to load into BlackBerry"
I do not have SB to reload. So i am in need of the SB for Airtel to load.
When i try to access a webpage, i get the below error message.
"Unable to open a PDP context to the following APN: blackberry.net
This may be happening because the currently selected browser configuration is not compatible with the current network"
I do not know if I have completed the process that is mentioned.
I can see the
APN:blackberry.net,
IP/Ports: 100.1.200.99:9201:8205
in the SB entry when i click show HRT (but not editable)
Please help
Old 5th July 2010, 12:56   #2379
anmolbedi's Avatar
@classicselva,
Just do this:
APN:airtelgprs.com
IP/Ports:
Authentication enabled, user/pass blank.
Restart connections and good to go.
Make sure your GPRS is activated beforehand
anmolbedi is offline   Reply With Quote
Old 5th July 2010, 12:59   #2380
ashthedivx's Avatar
Thanked: 22 Times
I can see the
APN:blackberry.net,
Please help
Look into the folder, It is there in the folder. It works mate trust me.
EDIT: To be precise 7th file in the folder
Old 5th July 2010, 13:10   #2381
sajands's Avatar
Thanked: 135 Times
Strange it is !!
Two Questions :
ashthedivx,
First of all, thanks for all the support and help.
Yes, I recently got the BB Serivces activated, 4 days back and I am trying to upgrade the handset with the BB activated sim inserted inside phone.
Please help. I am almost given up on trying to upgrade.
Please let me know on how to unzip a theme file and add it under themes and also how to install applications on to the phone.
Sorry for all the questions.
Old 5th July 2010, 14:49   #2382
ashthedivx's Avatar
Thanked: 22 Times
ashthedivx,
Forget about themes currently, lets resolve issues one-by-one.
now in your case as you have recently activated BIS services, OS up-gradation is tricky. Switch off your bb, remove battery from bb, make sure vendor.xml is deleted.
Now you have to be really fast, attach usb wire with BB, add battery to mobile, quickly start Loader.exe, it will show "unknown" port (Most important step to watch out), click next-next-next, now you can update it.
Note: Be Fast
Old 5th July 2010, 19:16   #2383
sajands's Avatar
Thanked: 135 Times
Note: Be Fast
ashthedivx,
I was not fast but lighting quick and boy it DID WORK
I am on the top of the world. Thanks a million. I have no idea what I would have done without your sound advice.
This is one of the reasons why i am glad to be part of BHP tribe.
It's finally got the O.S. 5 loaded. tell me, how did you figure it out. You must be a Blackberry Guru.
Thanks a million and thanks for hearing me out.
Old 5th July 2010, 22:38   #2384
ashthedivx's Avatar
Thanked: 22 Times
ashthedivx,
Phew... Finally Happy to hear finally it's done.
I encountered the trick while upgrading mine to OS5, As not being on BIS plan I had also undergone the same brain-storming as well.
Old 5th July 2010, 23:07   #2385
sajands's Avatar
Thanked: 135 Times
ashthedivx,
I am sure after this will not trouble, I have troubled you enough
I am trying to get the Ferrari F1 8900 into the phone, from this link,
BB Themes Javelin Free Applications Blackberry
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
