Old 16th August 2010, 22:51   #2536
ghpk's Avatar
Thanked: 192 Times
Slightly OT but I need this information.
As I have a Crackberry (i.e., cracked Blackberry CDMA with no access to BB services) I need to get a data plan from Reliance. I am on L0 , i.e. pay as you go with Rs.25/- per entry and Re.0.05 per 10kb and 0.5per MB data. It is the frist and second which kill, and got a bill for 3.8k last month (downloading software, testing out GPS, etc.).
I am postpaid and I have to subscribe to a data plan. By the looks of of the MB based plans all attract the 0.05 per 10kb net connect charges in addition to the plan charges (lowest is Re. 0.50per MB).
On the other hand the time based plans are silent on the net connect. So the options I have are 'Pay as You Go' at Rs.174 pm and Re.0.60/0.30 per minute. Alternate is Swift 30 which is 15h/30h with additional usage at 0.50per min.
It has also been suggested that I got buy an L1 from a DAPO user and then go for a data plan (like Rs.99 for 350MB per month).
Any person with experience with either of the first two.
If you would have gone for 1099 plan, you could have saved that 3.8k bill.
Reliance all other plans are CRAP, pay as you go is just a RIP OFF.
Also if you connect it to laptop & run internet its flat 40p minute.
don't know what plan they have you on. its called using tethered modem.
and you don't need to pay any upfront fee for it, seems you are given wrong plan which is not applicable on BB devices.
For my 8330 I've following on my connection.
BB Elite plan + Simple PPS plan + Rs.25/month sms pack.
As I don't use BB except for excessive mails I don't need its crappy speed browser.
I handle more than 500 mails a day.
I use my voda USB stick when i need to connect laptop and not at home.
I am however 24x7 online using BSNL Broadband when at home.
Using Blackberry with laptop is expensive.
You''ll need to pay for laptop use(40p/minute) even if you are on 1099 plan.
If you want you can call Blackberry customer care *363
and ask them to give you a BB plan.
don't say you are on cracked B berry, say I've got a gift from someone.
And stay away from Pay as you go type plans, they would give nightmares when you get the bills.
Originally Posted by JVH View Post
B'lore BBians - where do you go for fixing occasional hitches and irritants?
My Curve 8900's roller ball has a mind of its own. It operates perfectly fine one day and refuses to the next. Scrolling becomes a nightmare
TIA!
If you are regular user, you'll end up with a dirty trackball, I have cleaed my original one not less than 20 times before it gave up.
then ordered a few from china, it was cheaper than going for a hunt on local market.
Originally Posted by xtreme power View Post
i have a problem,
my blackberry starts and a message saying app error 523 comes on
and if i reset it comes back
and i cant use my phonw
what do i do
dont have a backup of my phone book contacts
Seems your last installed application is causing this, if you remember, un-install it, using desktop manager or phone installed application list.
check if your devices is recognized by DM. if yes back it up asap.
Old 17th August 2010, 09:10   #2537
Thanked: 57 Times
Does anyone have inside information on what is the fate of BB in India after 31st Aug ?
LonelyPlanet is offline   Reply With Quote
Old 17th August 2010, 09:17   #2538
sgiitk's Avatar
Thanked: 3,797 Times
Infractions: 0/1 (5)
@ghpk; Thanks for the detailed post. First none of the BB services (BES, BIS, IM, etc) are available on cracked units. So any BB plan is out. Why I need a plan is precisely because of the Rs.3,8k bill on L0! Here it was Rs.25 per connection + 50p/MB + 50p/10kb for Network Usage, Once bitten twice shy. I have switched off the net connection. And do not want a repeat.
I have access to a 1GbPS link at work, so do all my heavy work there. Also, I have Photon+ for web browsing. So I need the plan for occasional usage only, (mainly GPS and downloading BB applications which I may need). To access Facebook I have to go through Opera Mini. On BB it requires BIS, so cannot be even be downloaded and installed! Swift 30 does not list any network usage charges. Maybe I should call up *222.
Having got a cracked set I intend to use it for 2-3 years before going for a proper 'legal' BB. I am quite happy with what I have. The user interface and sms, calling etc. are brilliant.
The issue was 9k against 18.5k for the legal Reliance BB.
The other option may be once MNP is in and stable, get a cracked legal (or even cracked) GSM BB and then change operators.
With MEID coming they may not be able to sustain the system monopoly for long. Also, once 3G is in I expect major rationalisation of connecion charges. Even Anil Ambani will have to see the light.
Old 17th August 2010, 10:15   #2539
johnda's Avatar
Thanked: 11 Times
They're agreed to the govt's requirements -
BlackBerry gives in, to provide access to encrypted data - India Business - Business - The Times of India
thus you and I can keep our phones...
johnda is offline   Reply With Quote
Old 17th August 2010, 10:59   #2540
SPARKled's Avatar
Thanked: 325 Times
From the sources that I have read, apparently they have allowed to tap in BBM but corporate mails using BES is still an issue.
SPARKled is offline   Reply With Quote
Old 17th August 2010, 12:44   #2541
raghu230506's Avatar
Thanked: 63 Times
RIM denies this
Source: Economic times.
RIM denies knowledge of agreement with India - Hardware - Infotech - The Economic Times
raghu230506 is offline   Reply With Quote
Old 17th August 2010, 13:25   #2542
shajufx's Avatar
Thanked: 455 Times
Time to clean it up. Google it, you will find plenty of instructions, even videos. I used after-shave lotion (without moisturizer) and it works perfect. Any mild spirit that evaporates quick should do the work.
shajufx is offline   Reply With Quote
Old 17th August 2010, 14:12   #2543
sajands's Avatar
Thanked: 135 Times
Guys, I have the BB 8900 and on the Vodafone BIS 899 plan. Please advice on how to watch streaming media. I tried to watch SL vs India from www.crictime.com and it kept saying please wait till the video loads but even after an hour nothing happned.
Is there a way to watch Live streaming media on BB.
Downloaded Google maps 4.4, site says has voice navigation but did not get find any options. How does one use the in-built GPS. I need lots of help in the GPS.
P.S. I have 6 satellites detected by the internal GPS.
sajands is offline   Reply With Quote
Old 17th August 2010, 22:10   #2544
arsudarsan's Avatar
Thanked: 13 Times
Google maps has voice based search facility and not voice navigation. You need to press the Green call button and then speak. Make sure you use US accent.
How did you manage to get 6 sattelites detected?
arsudarsan is offline   Reply With Quote
Old 17th August 2010, 22:41   #2545
sajands's Avatar
Thanked: 135 Times
Hey arsudarsan,Dont ask me, i guess got very lucky. i also updated the O.S. to 5.0.0.610 maybe that had something to do to in detecting satellites. my guess again.Thanks for the tip. -Sajan.
Old 18th August 2010, 08:54   #2546
JVH
JVH's Avatar
Thanked: 148 Times
Ordered the trackball from China? And then how did you fix it? DIY or a local mobile store?
I do clean it all the time but the frequency has now increased. Looks like I've to order a new trackball.
Thanks Guys!
JVH is offline   Reply With Quote
Old 18th August 2010, 10:51   #2547
SPARKled's Avatar
Thanked: 325 Times
Thanks Guys!
On an average whats the life of a trackball. I mean how long before I should expect it to start acting weird.
Old 18th August 2010, 11:57   #2548
shajufx's Avatar
Thanked: 455 Times
My ball sorry the pearl ball is rolled around 2 years + I have cleaned it only once so far, but I dont have the habit of handling it with a dirty or dusty hand.
Old 18th August 2010, 12:48   #2549
JVH
JVH's Avatar
Thanked: 148 Times
Pearl 8100 - For 1.5 years, absolutely no problem. My wife uses this now and even she is quite happy
Curve 8900 - For 9 months, no issues. After that the headache started.
Both were handled with clean hands though
Old 18th August 2010, 14:35   #2550
The_Warrior's Avatar
I have a BB Bold and 2 days ago it stopped responding, as in the software crashed. They relaoded the new software and now i am not able to connect the phone to the PC. Have given it back to the store and have asked for a replacement. they say that it will go to Bangalore and then the next course of action will be decided.
Now the question is.... will they replace the phone or not??
Any pointers??
The_Warrior is offline   Reply With Quote
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
