Old 25th August 2011, 12:29   #3601
addyhemmige's Avatar
Thanked: 465 Times
Default Re: Blackberry Phones and Services in India
Hey guys,
Finally got the Wifi issue resolved. Basically what worked out for me was I had to activate the 599 plans as the service books needed for BIS service were either not downloaded or corrupt when I registered for the 299 plan. Now if I shift back to the Lite plan, the wifi should work. Got this advice from both Idea & Vodafone customer care (got a friend on Vodafone to confirm the same).
Is it really necessary to be on any kind of data plan to use the wifi services on the BB? I am planning to buy a Bold 3 9780, but I do not want to get a data plan (at least for now) since I have free wifi at home and at office.
If this is true (that a data plan is needed for wifi), isn't this illegal? Has no one raised a complaint yet?
addyhemmige is offline   Reply With Quote
Old 25th August 2011, 12:44   #3602
JayD's Avatar
Thanked: 1,999 Times
Everytime i connect my BB9700 to my bluetooth headset, the LED indicator starts flashing continuously in blue. Is there any way i can stop that from happening, as it gets really irritating at times.
Old 25th August 2011, 12:48   #3603
ninjatalli's Avatar
Thanked: 1,183 Times
No you don't need a data plan. The wifi works perfectly fine. But google apps (google maps/gmail) do not work without a dataplan. You can visit the corresponding websites, but the apps give the popup message of a dataplan requirement.
Otherwise everything else works - you can even visit the BB App world and download apps - most of them will work on wifi.
ninjatalli is offline   Reply With Quote
Old 25th August 2011, 13:25   #3604
Maverick79's Avatar
Thanked: 525 Times
The blue indicates you are connected via blue tooth. This is completely normal. It happens in my 8520 also when ever I connect it with my car stereo.
Only Way you can stop this is by covering it with your mobile case.
Jokes apart, there would be some option for LED on off. Didn't check in my handset though, till now.
Maverick79 is online now   Reply With Quote
Old 26th August 2011, 01:30   #3605
Thanked: 11 Times
You can turn off the LED indicator from Bluetooth options.
Mugen_Power is offline   Reply With Quote
Old 26th August 2011, 12:58   #3606
Thanked: 465 Times
I have another query. Is it necessary to get a BIS plan compulsorily to use email and other internet functions? From what I could see on the net, the BIS does not have 3G speeds. So, I was thinking, can I get a regular 3G data plan (like I can do with another 3G phone) and use it on a Blackberry?
I plan to get a BB Bold 9780. I am currently on the Vodafone network. Does anyone know if Vodafone has started 3G services in Bangalore? People using the BIS 599 plan in Bangalore, how are the speeds compared to the regular EDGE network or even the 3G?
Old 26th August 2011, 14:17   #3607
ninjatalli's Avatar
You can utilize the mail & internet services without activating the Blackberry services. However you won't be able to get the push mail facility.
On 3G matters, I don't have any info. But ideally you should be able to get 3G internet speeds for browsing, if the operator is providing the same in your area(s) at Bangalore. Others could chip in on this matter.
Old 28th August 2011, 21:53   #3608
wanderernomad's Avatar
Thanked: 787 Times
Does all bb models support BBM or it is only supported by a few models? I am using bb mail services on my SE p990i, will I able to use BBM on SE if i download it from an external link to my 990i?
wanderernomad is offline   Reply With Quote
Old 29th August 2011, 10:04   #3609
mayankk's Avatar
Thanked: 3,507 Times
No you wont.
Its handset bount, specifically, BB handset bound, the pin.
mayankk is offline   Reply With Quote
Old 29th August 2011, 21:21   #3610
Thanked: 787 Times
Ok but do all bb phone handset models have bbm?
Old 29th August 2011, 23:12   #3611
Thanked: 11 Times
Yes It is there in all BB models.
Old 30th August 2011, 15:00   #3612
mobike008's Avatar
Thanked: 8,037 Times
I use a Blackberry Torch (9800) and essentially an app freak
Can we all share what apps that we have all downloaded from the "App World' and how useful it is?
A few from my side :-
1. Shazam :- Listens to music playing and tells you the name of the song. Brilliant
2. Callblocker : Blocks are unwanted calls. Caller will get one ring and then it automatically disconnects. He wouldnt know what hit him. Must Have !
3. Add Contact App : This app allows you to add contacts in a jiffy. Very useful app
4. Whoisit : This apps allows you to customize your LED light color as per the caller for you to know who calls without opening the phone from its pouch. Brilliant
5. Stormslider : A simple touch and scroll can lock and unlock your phone
6. Twinkle : Add events and it counts down days left for each events.
7. Leave it on : This app allows your backlight to remain ON based on your customization
8. GPSspeedometer : Brilliant app that tells you all stats of a particular drive like Speed, Av time, Distance etc.
9. Weathertrax : One of the most accurate weather apps out there. You can add any number of cities. Tells 7 days weather forecast in advance.
10. Wallpaper Changer: My Torch has never been this beautiful since i downloaded this. Homepage wallpaper changes automatically every 15 minutes. This time is customizable
11. Screencharger : When your phone is charging, beautiful slideshow of images.
Apart from above, I had hordes of other apps like Dilbert, TOI, BURRP, Linkedin, FB, Gmaps, Funniest Bar Jokes, Funniest Blonde Jokes
Games ( Only my favorite) :-
1. Bubbleshooter
2. Hangman
3. Free Chess
4. MathsWorkout
5. Memory
Would love to know which are the apps you all are using and what you think of them?
Old 31st August 2011, 11:09   #3613
speedsatya's Avatar
Thanked: 706 Times
Default Re: Blackberry Phones and Services in India( The 9900)
I do need to carry the charger with me now with usage remaining same .The form factor is just so good ,that you tend to type on and on and on This is definitely the best phone that I have ever used till date !
Fortunately ,I have never had any restart issues till date ,but sometimes the phone did tend to be slow.And ,I read on Crackberry that new software updates should be able to solve the battery problems to some extent .
alt lglg does work .I do clear logs regularly
BTW have you started using Wikitude?
speedsatya is offline   Reply With Quote
Old 31st August 2011, 12:36   #3614
valhallen.282's Avatar
Thanked: 157 Times
Guess who's back. and now free from the shackles of the shitty old office laptop thank you to my brand new: BB PLAYBOOK! man did i miss visiting here!!! any other PlayBook people here?
valhallen.282 is offline   Reply With Quote
Old 31st August 2011, 17:12   #3615
jatinpatel's Avatar
Thanked: 191 Times
hello
updated my curve 9300 to OS6
now one issue i face is in the previous OS5 google maps used to work perfect without any glitch now in OS6 it does not work it gives error that data plan unsupported but it used to work perfect on OS5 with same data plan.
what can be the solution to this problem ?
google mpas is essential for me and so is OS6.
jatinpatel is offline   Reply With Quote
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
