Old 9th March 2012, 20:47   #3916
neofromcapone's Avatar
Thanked: 118 Times
Default Re: First time BB user queries
Originally Posted by gpa View Post
Thanks for this.
But are you sure this is not specific to the Mumbai circle?
I did check the Vodafone website again and the BIS399 is available on prepaid like it is here in the Karnataka circle but not on postpaid.
@gpa, you will need to check with your local vodafone store, you may need to use StrangeWizard's suggestion
neofromcapone is offline   Reply With Quote
Old 12th March 2012, 14:21   #3917
Thanked: 145 Times
Default Re: First time bb user query
Originally Posted by StrangeWizard View Post
98/2gb plan doesn't work on bb. I tried it on my 8520. You need to activate the bb services.
You can actually use 98/2gb on 8520. I had been using it for long since my office wasn't allowing BB
You can use: nimbuzz, Opera, whatsapp and gmail applications but not BBM and native meail client.
A little jugaad is needed. I can let you know exact steps if you need
BTW 98 plans now gives 5 or 7 GB instead of 2GB on airtel now.
vikramvicky1984 is offline   Reply With Quote
Old 12th March 2012, 14:26   #3918
mobike008's Avatar
Thanked: 8,037 Times
Default Re: Blackberry Phones and Services in India
I am thinking of upgrading my one year old 9800 with a 9810.
What is the current best possible market price for a 9810?
If I sell the 9800 ( its without b&W but in excellent condition) how much can i expect?
Finally, is there a huge difference between the 9800 and 9810 except for the processor speed and OS 7?
Old 12th March 2012, 14:32   #3919
StrangeWizard's Avatar
Thanked: 228 Times
Hey ya do let me know the steps please! And, I use vodafone 99/2GB btw.
StrangeWizard is offline   Reply With Quote
Old 12th March 2012, 14:51   #3920
Thanked: 145 Times
1. settings> advanced options> TCP/IP: tick APN settings enabled and enter APN ( airtelgprs.com for airtel, ask vodafone customer care for it)
2. download opera Mini (maybe using wifi etc): settings>advanced> protocol> set to socket while using on gprs & http when on wifi
3. Whatsapp: download using wifi. It should work fine
4. Nimbuzz: download and in connection settings: when you use gprs select automatic
5 gmail client: download from internet
6: connect to laptop and use mobile internet as well.
All should work, kindly let know if I can be of further help.
There is a link which I am not able to find now, shall update when i get it. it was really helpful.
Couple of links :
http://www.theonlyanil.com/2011/01/2...hout-bis-plan/
http://www.sunny-bajaj.com/apn-setti...in-india/1654/
Old 12th March 2012, 18:26   #3921
deathwalkr's Avatar
Thanked: 495 Times
hey, if you are picking up the 9810, please update the OS to 7.1 [available from crackberry] first itself and save yourself from a lot of headache
The 9810 you will get it for Rs.30,600 or so. Even lesser perhaps. And it is a good upgrade over the 9800.
deathwalkr is online now   Reply With Quote
Old 13th March 2012, 10:29   #3922
slicvic's Avatar
Thanked: 363 Times
What are the changes in 7.1 over 7.0?
I'm using a 9810 with 7.0.0.261
slicvic is offline   Reply With Quote
Old 13th March 2012, 23:13   #3923
S350L-E240's Avatar
Thanked: 374 Times
Please help,
I use a 9790 and I have two major problems,
1. Sometime when I talk the hand set goes on speaker is there any way to avoid this or just disable the useless touch screen?
2. When my phone is on standby sometimes i have to keep pressing unlock 7-8 times before the screen comes back on?
Any solutions esp. Point 2?
S350L-E240 is offline   Reply With Quote
Old 14th March 2012, 01:12   #3924
Thanked: 228 Times
Originally Posted by S350L-E240 View Post
Please help,
The 2nd problem that you have mentioned happens in my Curve 8520 too! Whenever I get a new message or something, or when the phone is charging, I need to press the unlock key 8-10 times! Might be a common niggle with many BBs. Even my old curve had this problem.
Old 14th March 2012, 13:30   #3925
infotech58's Avatar
Thanked: 217 Times
that is a very common issue with BBs; my BB 9700 had it, then 9780 too developed this issue; strangely it does not happen when the phone has been restarted recently.
infotech58 is offline   Reply With Quote
Old 14th March 2012, 19:11   #3926
S350L-E240's Avatar
Thanked: 374 Times
Thanks a lot for the confirmation is there no way to sort this I mean e very reason I upgraded from 9700 to this was only the screen locking issue it's frustrating sometimes during important calls or during email which are critical
Old 16th March 2012, 05:19   #3927
Sahil's Avatar
Thanked: 2,296 Times
Can someone please confirm if the warranty that we get on our BB in India is worldwide?
My 9900 is having hardware issues and I need to get it repaired/fixed under warranty as it is relatively new. I am currently living in Spain and would much rather get it done here than have to send the phone back but need to be sure that the warranty is valid here too.
Old 16th March 2012, 08:35   #3928
h@r$h@l's Avatar
Thanked: 686 Times
AFAIK all BB purchased from India come with a 18 months India warranty. But still, you should try approaching the BB shop / service centre there and see if they can help you in anyways.
h@r$h@l is offline   Reply With Quote
Old 16th March 2012, 17:42   #3929
deathwalkr's Avatar
Thanked: 495 Times
Yes it comes with an India specific warranty but you can always try your luck.
And for the 9790 issue have you tried upgrading to the new 7.1 OS?
Old 19th March 2012, 16:25   #3930
IndianNomad's Avatar
Thanked: 34 Times
I use BB 8530 CDMA model on BIS 599 plan with Reliance.
Yesterday I switched off my Mobile Network and connected to my Boradband connection through Wi-Fi and tried to surf through browser, also tried to use gtalk but none of them worked.
My question is will I be able to use chat, browser and other apps through wi-fi in places where there is no coverage or say abroad.
IndianNomad is offline   Reply With Quote
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
