Old 25th August 2012, 19:36   #4126
Thanked: 237 Times
Default Re: Blackberry Phones and Services in India
Originally Posted by StrangeWizard View Post
My curve is 1 year old but I've already void the warranty but opening the phone up to replace the body.
Btw it started working properly today as if nothing has happened !
Btw if you type 7:28:55 PM and press space then it will display the exact time.
Ohh hahah that happens a lot. Opening the battery counting till 5 and resetting the phone is the answer to 90% of the problems with blackberry. The first time I called the helpline I thought they were kidding.
I just tried typing 7:28:55 PM. Nothing happened! Where should I type it?
Can you please tell me how to go about replacing the body and how much it costs and how good or bad it is. My phones side buttons have fallen off!
promit is offline   Reply With Quote
Old 25th August 2012, 19:47   #4127
StrangeWizard's Avatar
Thanked: 229 Times
Well you typed RT and the time is showing in your post !
I changed the body once at colaba for 700 bucks and once in london on my own for 8. The side buttons suck man.
StrangeWizard is offline   Reply With Quote
Old 25th August 2012, 20:41   #4128
chinmaybaikar's Avatar
Thanked: 68 Times
I changed the body once at colaba for 700 bucks and once in london on my own for 058. The side buttons suck man.
Its not RT. Its L D for date and L T for time. But without the spaces
chinmaybaikar is offline   Reply With Quote
Old 25th August 2012, 20:55   #4129
Thanked: 49 Times
The enter key stopped working on my Curve 8520. Is it a simple fix?
CrackedHead is offline   Reply With Quote
Old 25th August 2012, 21:20   #4130
Thanked: 229 Times
Hey I just figured it out. You need to type LT and then space and then the time appears. I typed LT in my previous post but the current time appeared when I submitted the post. So I guess you got confused. Type LT and then press space.
Old 25th August 2012, 22:38   #4131
Thanked: 229 Times
Sorry I saw your post now. Yes it is LT and I posted RT by mistake. It was a typo.
Old 25th August 2012, 22:55   #4132
Thanked: 43 Times
I was thinking of jumping on Blackberry bandwagon as my Nokia E72 has become very unreliable for emails.
Is Torch 9860 a good buy? I would prefer a touch screen as the screen real estate will make it easy to read long emails.
Adi_k is offline   Reply With Quote
Old 26th August 2012, 09:12   #4133
Thanked: 237 Times
I'm no genius when it comes to blackberry's. I have heard the 9860's touch screen isn't very responsive and you really miss having a keyboard for hardcore users. A friend of mine bit the bullet sold his phone and bought a curve 9360. The phone isn't doing to well, and couple of months back it had a massive price cut. From some ~30k down to 20k. Don't fall for that. Look at the bold 9790,9900,9780. You can look at the torch 9810. It too has a biggish screen which is touch and combines a slide out keyboard.
Old 27th August 2012, 16:30   #4134
mobike008's Avatar
Thanked: 8,160 Times
I use a 9810 and its best of both worlds. A touchscreen and a keypad. Its one of the best phones from blackberry ( barring ofcourse the new bold 9900) and camera quality is simply out of this world.
I used to use a 9800 before this phone and i somehow still like the 9800 over the 9810 despite everything is same about the phone except the processor speed and OS version.
Old 27th August 2012, 16:38   #4135
Thanked: 43 Times
Thanks promit & mobike008.
Once the cost reaches 25000/-, I start thinking if I should get a low end blackberry and a mid-range tablet. I might end up spending a bit more but this one will be flexible solution.What do you think of this combo?
Old 27th August 2012, 16:41   #4136
mobike008's Avatar
Sure. Nothing stops you from doing that too. Get yourself a 8520 ( starter BB handset) and a playbook. Both put together should not cost you more than 25K
You can then bridge both devices and enjoy your BBM, emails and many other features synched on each other.
Old 27th August 2012, 17:47   #4137
Thanked: 23 Times
There seems to be only 2 members in the bbm group which I joined by scanning the code on the penultimate page. Have members left already?
deepakchan is offline   Reply With Quote
Old 29th August 2012, 13:24   #4138
mobike008's Avatar
Ever since I moved to Blackberry Enterprise Services ( 6 months ago) I have been having issues with logging into AppWorld
Technically, when I click the Appworld, I should be able to just get inside the app without asking me for password etc which is usually a one-time affair.
But, last month it asked me password and when I type the password was getting incorrect password messages. I changed the BB password and it works perfectly on the blackberry website but, on phone it wasnt.
Customer service recommended me a total WIPE of the handset ( painful process in which i lose my Enterprise Emails and Enterprise IM which after approvals have to re-install) and after that i was able to log into appworld
Now from last week, I again have the same issue and unable to log into appworld
When I click the appworld Icon, I get an Error ID : 30702)
Can someone please help resolve this issue once for all?
Old 29th August 2012, 16:35   #4139
planet_rocker's Avatar
Thanked: 368 Times
You can always take a data back up before you do the security wipe.
Appworld has an upgrade available - download it via air / wifi - in my Bold3 it flashes a message to upgrade before continuing. I still haven't done that and i have not been asked for a password ever, while downloading any application.
Before downloading the upgrade, do a soft reset - with the phone on, pull out the battery and put it back in after 30 seconds. see if this solves the issue. Soft reset will not delete any data / bbm contacts / contacts / calendar / emails / messages
also try this:
Click on payment options and you'll be asked to log in. You can cancel out once logged in on payment options, then go to "My World" again fine. I hope this works for you.
Source: http://supportforums.blackberry.com/...P/td-p/1321185
planet_rocker is offline   Reply With Quote
Old 29th August 2012, 17:00   #4140
mobike008's Avatar
Originally Posted by planet_rocker View Post
Thanks this helped
Now i am able to log in to Appworld. Hope it continues to work well.
Guys, any recommendations for any MUST HAVE apps from appworld? It's been a while that I visited it. Will download a few good apps based on suggestions here.
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
