Old 21st July 2009, 18:23   #1126
Thanked: 11 Times
Originally Posted by Sahil View Post
Also, is there a way for the BB to stop pulling mail? I know this defeats the purpose of a blackberry but I'd rather have piece of mind than being bombed by work emails in the middle of the night or on weekends.
Is there an option to manually check the mail as and when needed? Or set a time after which mails should stop pulling automatically?
Sahil,
You can ON/OFF data service manually.
You can Auto ON/OFF cell for Weekday and Weekend.
Mugen_Power is offline   Reply With Quote
Old 22nd July 2009, 01:18   #1127
aZa
aZa's Avatar
Thanked: 17 Times
guys anyone using BBM 5.0?? i've loaded it up on my bold running .247 !
The msger 5.0 has an awesome interface but i think the messages take a lil bit more time to deliver to the older BBM.
Great upgrade i feel.
Old 22nd July 2009, 01:53   #1128
Thanked: 11 Times
I am Upgrading Javelin OS to 4.6.1.250 and BBM to 5.0
Old 22nd July 2009, 09:34   #1129
Sahil's Avatar
Thanked: 2,602 Times
Ok so I managed to transfer the data from the Nokia to the Javelin. But here are the hicups:
I used ZYB to transfer the contacts, the Nokia allows you to have two or more mobile numbers for each name. This data transfered perfectly from Nokia to zyb. But when I transfered from zyb to bb the 2nd mobile numbers do not come. I think this is due to bb have just one entry for mobile under each name.
For the calender I used outlook. Each entry per day has reminder set at a certain time. But when I transfer the calender from the Nokia to outlook all those reminders get converted into "all day events". Hence I'm not reminded at the designated task time.
How can I resolve these issues??
Old 22nd July 2009, 10:41   #1130
Jaggu's Avatar
Thanked: 8,441 Times
Why are you avoiding outlook sync? isnt it easier and straight forward?
Old 22nd July 2009, 11:05   #1131
Sahil's Avatar
Read my post above, I did use outlook sync for the calender.
When i try and sync the contacts via outlook, it only takes 2 numbers per name
Old 22nd July 2009, 15:09   #1132
quickdraw's Avatar
Thanked: 1,346 Times
Sahil trust me time and again I have noticed that we will never be able to fully properly sync two devices that run on different platforms. Stick to BB's from now on and I dont think you'll face too many issues. A little trick though, try exporting the backup file and during import in outlook assign the fields (mobile, mobile 2 etc)
quickdraw is offline   Reply With Quote
Old 23rd July 2009, 11:01   #1133
Jaggu's Avatar
Are you able to see the other numbers in the outlook once you sync with the nokia phone? If yes, then i think this method will not help.
If its not shown in Outlook, then check for drop downs in the fields of the address book, sometimes while syncing its stored under different field (mismatched mapping). Once you allocate the appropriate fields, then the numbers will show up.
IIRC Rehaan faced this issue for his dad's BB, check with him if he can help ie if he found an answer.
Old 23rd July 2009, 20:41   #1134
quickdraw's Avatar
This cross platform PIM syncing has always been a toughie. I wish there was a universal PIM format it would make switching so much easier.
Old 24th July 2009, 23:29   #1135
sujitm's Avatar
Where can i find a charger for 8310 curve? I lost mine recently :(
Any idea about the cost?
TIA
sujitm is offline   Reply With Quote
Old 25th July 2009, 09:16   #1136
DerAlte's Avatar
Thanked: 2,879 Times
If 8310 has the same mini-USB socket for charging like other BB models, and you are not able to source a BB charger, look for the iPod AC charger. These China-made units have a USB socket (instead of a wire leading out of the unit with a plug at the other end) into which the BB USB cable goes in (ditto for iPod), and it supplies 5V for charging. This is available at most electronic retail shops, usually in a blister-pack kept along with miscellaneous cables and headphones.
Old 26th July 2009, 00:36   #1137
quickdraw's Avatar
You can use any normal mini-usb Motorola or Chinese types mp3 player chargers they will work on the 8310, dont spend money on the original one its too expensive.
Old 26th July 2009, 18:20   #1138
sujitm's Avatar
Thanks DerAlte & quickdraw.
I tried a Motorola charger, but that didnt work for me. Will try iPod AC charger or some mp3 players charger and see how it works out!
Old 26th July 2009, 20:33   #1139
quickdraw's Avatar
It should definately work, I used my old MOTOROKR charger with my Curve sometime back, why dont you carry the curve to some local mobile shop and check which of the chargers work with your phone there.
Old 30th July 2009, 18:31   #1140
mobike008's Avatar
Thanked: 8,159 Times
When i select a number from my call list and press CALL button, phone exits to the same screen and does not go the calling screen. I have to do this 2-3 time before the actual call goes through.
It just happened 2-3 times till now. It's not a problem but a very minor irritant.What could be the problem? Time for a battery pull?
Of Bappa, Blackberry, Beach and a Beige beauty - My trip to Ganapatipule JoshMachine Travelogues 4 16th July 2013 14:21
Blackberry Pearl 8100 Sahil Gadgets, Computers & Software 20 10th September 2009 20:14
blackberry's for banglore cops whatcanthisbe Shifting gears 11 30th May 2007 22:18
