Old 13th November 2012, 13:22   #556
Thanked: 62 Times
Default re: Mirrorless or EVIL Cameras
Why not Sigma 30 F1.4 instead ? It gives wonderful shallow DOF.
I am using on Canon its sharp and focus is fast
Its available in nex mount as well.
http://www.photozone.de/Reviews/298-...report--review
It does not say that it is available for the NEX (E mount). It should be possible with an adapter, but then I have to invest for the adapter as well.
joe1980 is offline   Reply With Quote
Old 13th November 2012, 18:05   #557
tsk1979's Avatar
Thanked: 16,421 Times
So if you get some good glass for Nex 5N, you may as well kiss D7000 goodbye. Admit you are having such dirty thoughts now.
Actually I need two cameras. Lens changing on the field is not for me.
So I will keep the D7000.
Moreover, there is no wired release for nex(intervalometer not possible. and wireless is too cumbersome to use for intervalometer).
I am actually going to make the D7000 the specialist cam. Use either fisheye, or a telephoto prime depending upon need.
On the NEX, I will use the 18-200
Originally Posted by joe1980 View Post
. This just intensifies the justification for more NEX lenses at least from other manufacturers other than Sony.
Well tamron is already out with the 18-200. So I guess more will follow.
Old 13th November 2012, 19:16   #558
vivekiny2k's Avatar
Thanked: 184 Times
did you look at this?
http://www.amazon.com/Sony-RML1AM-Co...mote+commander
and
http://www.amazon.com/NEEWER-RM-S1AM.../ref=pd_cp_p_0
Also, why not take sony 18-200 instead of tamron 18-300? there is not a lot of difference and being a native lens, it might give you better performance.
vivekiny2k is offline   Reply With Quote
Old 13th November 2012, 21:14   #559
HellwratH's Avatar
Thanked: 57 Times
Shh, don't give him such ideas. I don't want the MF lens market to go higher than it is already . I took the Nex 5 out on saturday to Baltimore
It's a wonderful lens, but I doubt it has an aperture ring (for adapting). Also, I am not too sure if it's available in the E mount.
HellwratH is offline   Reply With Quote
Old 13th November 2012, 22:34   #560
vivekiny2k's Avatar
Thanked: 184 Times
I take that back, those remotes will not work. There are some DIY projects using IR sensor though.
Old 13th November 2012, 23:10   #561
Thanked: 445 Times
Theres also iphone app that can do the trick. Am not sure if there is a droid equivalent.
joslicx is offline   Reply With Quote
Old 14th November 2012, 00:18   #562
Thanked: 62 Times
Would this Tamron be ideal for Macro photography? Looks like it is an all round lens for every day use. I already feel that my camera with the Sigma 30mm lens has added a bit of weight. This zoom lens from Tamron weighs round about half a kil0. Not sure how the ergonomics would be if I use it on my NEX. If I purchase my next lens for my NEX 6, it will be a Macro between the 75 and 105mm focal length. Currently there is none for the NEX in that range. Hope to see one next year. My guess is that Sigma might bring in something!
Another crazy question: Why is that we have different mounts? It seems to me that only the metal that gets locked to the camera differs from the different mounts. The vöigtlander lenses has a curvy metal and the Sony E mount has sharp edges that gets docked to the camera. Is there anything else that differentiates the different mounts?
Old 14th November 2012, 06:28   #563
Thanked: 445 Times
The connection between the lens and the camera body (electronics) will be different. Unless camera manufacturers make that open source (something like micro four thirds) it wont be compatible without an adaptor.
basically everything to make you buy more gadgets (different kinds of adaptors etc).
Old 14th November 2012, 08:45   #564
Thanked: 420 Times
It is available in Sony Alpha mount so using Sony adapter should be usable.
Any way if one does not have adapter already then cost will go up.
So bad suggestion from me.
amitk26 is offline   Reply With Quote
Old 14th November 2012, 11:34   #565
Thanked: 62 Times
Did you try the WiFi connectivity on your 5R? Have you already explored the play memories? I tried couple times to set up my access point on the camera, after many tries I was finally able to get it. Feel's like the NEX 6 should have had the touch screen.
Old 14th November 2012, 11:52   #566
Thanked: 445 Times
Does it not? I kind of remember reading somewhere that it has a touch screen. I like it on my OM-D as it makes reviewing images so easy. Though the screen response is on the poor side really. I guess it'll still take some iterations for them to put a screen as good as a decent smartphone.
Old 14th November 2012, 11:59   #567
Thanked: 62 Times
The Sony website, the Amazon website claimed that the NEX 6 has a touch screen but it was dpreview that pointed out after their first field test that the NEX 6 does not have a touch screen.
http://www.amazon.com/Sony-Compact-I...rds=Sony+NEX+6
The Amazon link above states even today that there is a touch screen. The information is obviously pulled from the Sony content. I wish the NEX 6 had a touch screen and it really makes no sense not to have it with the camera being WiFi enabled and has a concept similar to an app store. When I had to type in my password for the WiFi connectivity, I realized the pain to go through the buttons to navigate between the words.
Old 14th November 2012, 12:19   #568
Thanked: 445 Times
Tried taking some pics of fireworks yesterday night.
Heres couple of my efforts. 60s Exposure, lens at 12mm (eq. 24mm) with iso set at 200 and aperture of f16. I do not have a tripod yet so just rested the camera on the wall.
Old 14th November 2012, 18:09   #569
vivekiny2k's Avatar
Thanked: 184 Times
I did. and after a cople tries it worked. I was looking at it from TSK's perspective (5N). A remote will be convenient since turning the app on camera and phone and then them connecting takes a while. Touch screen is really good for quick focus changes.
Old 14th November 2012, 18:30   #570
Thanked: 62 Times
I stumbled upon this website. It is a good guide to information on the currently available lens options for the E mount. Thought of sharing it here...
http://sonyalphalab.com/nex-lense-e-mount-buying-guide/
I will test out the WiFi on my NEX 6 tonight. Hope it isn't much of a hassle.
The Evil Twins - JBL Swifts - Pics raftaar In-Car Entertainment 4 4th December 2007 21:33
The Evil Twins -JBL Swifts -No more Requests Sam Kapasi In-Car Entertainment 96 3rd December 2007 19:28
Girls are evil. X-Machine Shifting gears 5 1st October 2004 11:16
