Old 11th April 2011, 20:28   #31
Thanked: 167 Times
Default Re: IMP Excel sheet got corrupted. Any possibility of recovering data?
try this, might probably work :
1. Open excel application
2. Click on Office and Open -> you would get a dialog box where you can browse to place where you have saved the file
3. Single click on the file and at the bottom there is open button and next to that there is an arrow
4. Click the arrow and select "open and repair" option.
malgudi is online now   Reply With Quote
Old 11th April 2011, 21:59   #32
Thanked: 895 Times
Originally Posted by DRIV3R View Post
Highly unlikely to work, cos the older version was overwritten by the new version, after it was worked upon for 3 hours.
Remember, data recovery software work only when those sectors which are to be recovered are not overwritten by data. If we run the data recovery utility now, all we would get is the corrupt file. My take on this.
@Rush: If Autorecover option is enabled, MS Excel should have saved a backup every 10 minutes, by default. Check for any stray xl sheets in the "Application Data\Microsoft\Excel" path in the C drive. This path differs from OS to OS, check what it is for XP and look for any files there.
Not necessarily. Usually the data storage algorithms of Microsoft Operating Systems are archaic. They do not reuse freed up clusters readily. If space is available for a sequential disposition, then data will be written onwards, disregarding the free space. Even later, when the disk is relatively full, it does not judge the best possible location of the data clusters, but again starts allocating from the starting sector in sequence, looking for whatever available free space. Result = High Fragmentation. Anyways, this is Off Topic.
It is quite possible that the data buffer was written to a separate part of the disk, than the original file. This is not a guaranteed approach, but one that might work.
Also, remember that it is possible to even retrieve over-written data sectors from Windows disks, since the Deletion algorithms are not as effective. :-))That's why Windows does not meet the DoD standards, out of the box.
roy_libran is offline   Reply With Quote
Old 14th April 2011, 10:48   #33
Thanked: 103,413 Times
Guys,
Just an update : I've created a new excel sheet and managed to re-enter all the older data (admittedly, it wasn't easy). Also, my excel has now changed the default store method as .xls. Somehow, all these corruption problems have only come up from the time I upgraded to Office 2007 / .xlsx extensions. Made a couple of changes to my backup strategy as well.
I wanted to put in a sincere Thank You to all of you. Your help & support is much appreciated & respected.
Old 14th April 2011, 18:29   #34
ph03n!x's Avatar
Thanked: 120 Times
Hope your Office 2007 installation has SP2 and all the newer updates too. I remember having a corruption problem a while back with xlsx, but have not faced it in Office 2010 so far.
ph03n!x is offline   Reply With Quote
Old 23rd March 2012, 17:51   #35
Bass&Trouble's Avatar
Thanked: 71 Times
Default Excel 2010 Help!
Just installed Office 2010. Now when I open any of my excel sheets and do a Ctrl-C Ctrl-V, the destination cell only displays the content of the source cell without copying the formula! I've looked up all the settings, all cells are set to "General" and not "Text". Under the Options>Formulas> Automatic is selected. In fact even if I right-click to paste, there is no option saying "Paste". There's a "Paste Options" under which one can only select "Text". And there's a "Paste Special" which takes you to a box which only gives you the option of pasting as Unicode Text or Text. I have attached screengrabs. Can anyone tell me what I might be doing wrong here?
PS I'm working on an Excel 2003 file in compatibility mode. But that shouldn't mean they've thrown out formula compatibility with older versions I suppose!
Old 23rd March 2012, 17:57   #36
Marlon's Avatar
Thanked: 78 Times
Default Re: Excel 2010 Help!
  • To paste formulas only, click Formulas.
Note If the copied formulas contain relative cell references, Excel adjusts the references (and the relative parts of mixed cell references) in the duplicate formulas. For example, suppose that cell B8 contains the formula =SUM(B1:B7). If you copy the formula to cell C8, the duplicate formula refers to the corresponding cells in that column: =SUM(C1:C7). If the copied formulas contain absolute cell references (absolute cell reference: In a formula, the exact address of a cell, regardless of the position of the cell that contains the formula. An absolute cell reference takes the form $A$1.), the references in the duplicate formulas are not changed. If you don't get the results that you want, you can also change the references in the original formulas to either relative or absolute cell references and then recopy the cells.
Move or copy cells and cell contents - Excel - Office.com
P.S : I have not worked on Excel 2010
Marlon is offline   Reply With Quote
Old 23rd March 2012, 17:58   #37
SunnyBoi's Avatar
Thanked: 2,832 Times
Press F2 of the source cell and copy the formula!
Office 2010 has some protection feature somewhere that always bugs me. You'll have to disable those options or go back to Office 2007 like I did!
SunnyBoi is offline   Reply With Quote
Old 23rd March 2012, 18:17   #38
Thanked: 71 Times
Thanks for the help, but the above things weren't the issue.
Some googling led me to this page -> Solved: Excel 2010, Word 2010 & PowerPoint 2010 - Paste only - Microsoft Answers
The last suggestion on the page is what worked. I have disabled skype plugins on IE and Chrome and now Excel is working just as intended. Nothing short of ridiculous!
Posting a new screenshot.
Old 23rd March 2012, 18:27   #39
Akshay1234's Avatar
Thanked: 7,240 Times
This is just really funny. I wonder what is up with Microsoft these days. Good to know you sorted it out Ajay.
Old 29th August 2012, 22:33   #40
amitpunjani's Avatar
Thanked: 101 Times
Default Best Microsoft Excel Training Institutes in Gurgaon
Which are the good Microsoft Excel coaching centers in Gurgaon? I want to attend Microsoft Excel coaching classes in Gurgaon, Please tell be good Microsoft Excel training institutes which are providing Microsoft Excel Courses in Gurgaon
Amit
amitpunjani is offline   Reply With Quote
Old 29th August 2012, 23:15   #41
anekho's Avatar
Thanked: 661 Times
Default Re: Best Microsoft Excel Training Institutes in Gurgaon
Hey Amit,
Not really sure what Excel coaching centers teach but I'll tell you this: Excel isn't hard to master - I don't think you'll need to attend classes.
My suggestion would be to buy Excel, watch videos on youtube (Like this one for example: ) and experiment yourself - that's the only way you'll learn. Besides, you won't have to pay for lessons!
Good luck!
anekho is offline   Reply With Quote
Old 14th May 2015, 12:03   #42
Spinnerr's Avatar
Thanked: 155 Times
Default Re: Microsoft Excel : Tips, Issues, Etc.
Need some tips to go about resolving this issue. My colleague need some help to ease his copy-calculate-paste job to simple copy-paste.
The idea is to add contents of Cell B2 with C2 and store in B2. Similarly for the rows below. It brings about a circular reference; so would need some Macros/coding for it to work.
This sheet populates a dashboard (not included in the sample file); data is updated in this sheet daily.
So Each day; he would like to open the Excel; repopulate only Column C marked as "Yesterday" and the "Till date" value would be up to date.
Sample excel sheet: Sample.xlsx
I just know a few excel formulas; never really ventured into Macros; so need some help. Thanks!
Spinnerr is offline   Reply With Quote
Old 14th May 2015, 12:23   #43
mohammedismail's Avatar
Thanked: 1,182 Times
Here is the code! It Adds B & C Column and Updates column B. Not sure if it should leave the column C as is or need to do something with it
Just add the below code to VBA module and run manually or assign it to an object. Let me know if you face any issues.
Sub M()
For i = 3 To 100
If Range("B" & i).Value = "" Then Exit For
x = WorksheetFunction.Sum(Range("B" & i), Range("C" & i))
Range("B" & i) = x
Next
End
End Sub
mohammedismail is offline   Reply With Quote
Old 14th May 2015, 13:44   #44
Spinnerr's Avatar
Thanked: 155 Times
Thanks a ton!!
That works beautifully...
Old 15th April 2016, 00:08   #45
MunnabhaiMBBS's Avatar
Thanked: 587 Times
Hi guys, Would really appreciate your help.
Need a formula / function that reads the entire row and displays particular text / value in case the row contains a certain word.
For instance :
Row indicates : House is big : If row contains the word "House", then display "Good"
Thanks in advance.
MunnabhaiMBBS is offline   Reply With Quote
Microsoft Office; Tips & Shortcuts prateek99 Shifting gears 10 9th August 2011 15:24
Tata 407 vs Force Excel 4 LCV. Which one? itsmevivek Commercial Vehicles 12 3rd April 2007 09:43
Tax Calculator (excel) required protege Shifting gears 4 30th July 2006 22:40
Fiat Panda to be launched as Tata Excel Minardi The Indian Car Scene 28 5th June 2006 12:15
