Old 15th April 2016, 11:14   #46
Thanked: 100 Times
Default Re: Microsoft Excel : Tips, Issues, Etc.
Originally Posted by MunnabhaiMBBS View Post
Hi guys, Would really appreciate your help.
Need a formula / function that reads the entire row and displays particular text / value in case the row contains a certain word.
For instance :
Row indicates : House is big : If row contains the word "House", then display "Good"
Thanks in advance.
If search is on particular cell, you can use below formula:
=IF(FIND(LOWER("house"),LOWER(A1),1)>0,"Good","Bad ")
This will return 'Good' if the word 'house' is found in cell A1. Else, it will return 'Bad'. I used 'Lower' to make it case insensitive.
EDIT:
To search for entire row, you can use the below formula.
=IF(MATCH("house",A:A,-1)>0,"Good","Bad")
nfsfreak is offline   Reply With Quote
Old 15th April 2016, 11:55   #47
Thanked: 167 Times
Try this :
If the Row number 1 has House use formula ISNUMBER(SEARCH("House",1:1)) in say cell A2. It will return true if the row 1 has word House(does not mater in which cell of the Row 1) and False otherwise.
malgudi is offline   Reply With Quote
Old 18th April 2016, 16:15   #48
MunnabhaiMBBS's Avatar
Thanked: 587 Times
EDIT:
Thank you so much for the help.
Formula 1 : Worked partially, Showing "#VALUE" in place of Bad.
Formula 2 : Returned " #N/A" everywhere.
Originally Posted by malgudi View Post
Try this :
Thanks Malgudi,
Formula returned "0" in every row.
MunnabhaiMBBS is offline   Reply With Quote
Old 18th April 2016, 16:34   #49
Thanked: 167 Times
Thanks Malgudi,
Not Sure Why but this is what I tried
Old 18th April 2016, 17:31   #50
Thanked: 100 Times
Corrected formula: =IF(ISNUMBER(FIND(LOWER("house"),LOWER(A2),0)),"go od","Bad ")
Corrected formula: =IF(ISNUMBER((MATCH("house",2:2,-1))),"Good","Bad")
2:2 denotes entire 2nd row. change accordingly for related row number.
To search on entire columns, you can replace that with A:A or B:B (related column name)
Old 19th April 2016, 18:28   #51
Thanked: 587 Times
Attachment 1498688
Thanks a lot both of you. Issue is now resolved.
Another puzzle:
- 3 different sheets with 100, 200 and 300 rows respectively. Can't predict the rows for subsequent sheets.
- Using Macro for Pivot table, current selected range is 300 (Rows)
- Need to select range for the available rows for future sheets, could be 500, 600, we don't know yet.
- Can we give specific range selection instruction so to accommodate all the rows in future.
Thanks in advance.
Old 20th April 2016, 00:08   #52
Thanked: 167 Times
Another puzzle:
Thanks in advance.
Instead of selecting say a1:c300 as range for pivot table do select a:c . This will select all the data in a,b & c columns (irrespective of no of rows).
Microsoft Office; Tips & Shortcuts prateek99 Shifting gears 10 9th August 2011 15:24
Tata 407 vs Force Excel 4 LCV. Which one? itsmevivek Commercial Vehicles 12 3rd April 2007 09:43
Tax Calculator (excel) required protege Shifting gears 4 30th July 2006 22:40
Fiat Panda to be launched as Tata Excel Minardi The Indian Car Scene 28 5th June 2006 12:15
