| LinkBack | Thread Tools | Search this Thread |
| | #196 |
| Distinguished - BHPian ![]() Join Date: Dec 2007 Location: Kanpur
Thanked: 1,188 Times
| @CowlFlap; The simple answer is that while in principle the answer may be yes, in practice it is no, neither it it advisable. Airbags need sensors to disable them when the seat is unoccupied, etc. This may need both the sensors and a link to the EMU. ABS/EBD may need less interlink with the EMU but they are too critical for fiddling. I guess one way may be to retrofit with the original but but the risks are too great. So I will suggest you steer clear of these modifications. |
| | (1)
| | #197 | |
| Team-BHP Support ![]() | Quote:
But just remember that components such as airbags and ABS are hard-wired into the system. There are a lot of electronics in question and no regular mechanic or auto-accessory store can carry out such modifications with absolute success, however reputed. Such features come built into the car right from factory, and that's when it's best and least prone to malfunction. Even then , it can happen. Retro-fitting such complicated electronics is best avoided, in my humble opinion. ![]() | |
| | #198 |
| BHPian Join Date: May 2012 Location: Mumbai
Thanked: 20 Times
| Thanks @sgiitk and @suhaas307 I guess both of you have pointed in the same direction: Possible, but better avoidable. And, in all likelyhood, I will stay away from the idea of modifying these. I understand that it can be a delicate issue, and if not done correctly, chances for malfunction are higher. I hope manufacturers can steer towards providing safety features to all variants in the future. There are those, my parents (and myself, to some extent) for instance, who are alergic *winks* to those frills I mentioned earlier. Infact, there are some (additional) features in the upper variants that become a deal breaker for us - power windows, central locking etc. Coming back to the topic, we saw both i10, and the Bree..yo. The latter suits our needs better, though the base variant does not have the safety features. It does lack boot space, but we're not overly concerned about that -removing the rear bench when not required gives ample space for those long trips. On that note, I wonder what it looks like minus the rear bench..![]() Last edited by suhaas307 : 28th May 2012 at 12:48. Reason: Stick to the two-smiley rule, please. :) |
| | #199 | |
| Senior - BHPian Join Date: May 2004 Location: mumbai
Thanked: 100 Times
| Quote:
One does not want a after-market safety like Airbag, etc to be installed from other than the factory as there will always be a question "Will it work", and there is no way to test it ![]() No dealer or aftermarket across the globe is well trained /equipped to carry out such a task with monetary constraints. The most complex task most do is replace the ABS modules, airbag kit in case they are deployed once. Ps : Micra is the only hatch to come with a driver Airbag is a base version in India but they are the same ones to skip ABS in top diesel variant. Last edited by dipen : 28th May 2012 at 13:42. | |
| | #200 |
| Senior - BHPian Join Date: Nov 2007 Location: Bangalore
Thanked: 232 Times
| | #201 |
| BHPian Join Date: Nov 2008 Location: New Delhi
| Retrofitting airbags and abs, ebd is out of the question.. but my one and only gripe with the car is the lack of even internally adjustable ORVMs on the S mt... any aftermarket hopes on this one? Last edited by eternalck : 28th May 2012 at 22:58. |
| | #202 |
| BHPian | I'm hearing water leakage issues in brio and one of bhpian seems to confirm it as well..anyone else faced this issue? |
| | #203 |
| Distinguished - BHPian ![]() Join Date: May 2005 Location: KL
Thanked: 439 Times
| Water leakage in which part? If its the water getting into high mounted stop lamp i think i read somewhere here that Honda has come up with a solution already. |
| | #204 |
| BHPian | Yeah , Hopefully it is fixed by in subsequent batches. It would be a huge drawback in a country of Monsoon. |
| | #205 | ||
| BHPian | Quote:
I would like to know more about this and be prepared. | ||
| | #206 |
| BHPian | Not much is known yet. One of bhpian had mentioned about it. Since there is a serious dearth of ownership reviews unable to dig more. Real test is yet to happen during this year monsoon. |
| | (1)
| | #207 |
| Newbie Join Date: Jan 2008 Location: bangalore
| Thanks to all, I found this forum the most informative. I too am comparing the two & did a TD. Some points not mentioned in this long thread are: Brio Cons: 1. 5'11", when i sit on the back, my head touches the roof; 2. In the back, with no proper neck restrainer, its very uncomfortable at back 3. The centre bump (axle) is much less pronounced than i10 4. Entry/Exit out of rear door is much more cramped compared to i10 i10 Cons: 1. If you drive any car with steering-mounts, found it difficult to honk (habituated to using my thumb: The honk press is very hard, not very friendly In general both cars have pretty even with each having some advantages. Brio is definitely much more fun to drive. |
| | #208 |
| Senior - BHPian | |
| | (1)
| | #209 |
| BHPian | |
| | #210 |
| Senior - BHPian | |
Similar Threads | ||||
| My Honda Brio S MT (chrome rims, 7-speaker ICE etc.) | chase_nt | Test-Drives & Initial Ownership Reports | 21 | 16th May 2013 01:22 |
| Stig gets Brio'ed! Red Honda Brio SMT (O) | adityasiera | Test-Drives & Initial Ownership Reports | 46 | 27th December 2012 13:49 |
| Up to speed with driving- now deciding between Brio / Jazz / Beat Diesel / i10 | adg_andy | Hatchbacks | 36 | 21st September 2011 20:19 |
