Old 25th May 2006, 21:38   #1
amit_purohit20's Avatar
Thanked: 486 Times
Default First Car
Dear all,
I plan to purchase my first car of my life. Being a first car i would like to go for a secondhand one. I am pro diesel person regarding economy and my strong option is tata indica diesel. I plan to purchase it downpayment so nothing related to EMI or sort of. I dont plan to use this car daily but only on weekends. Distances travelled on weekends will be high because i like long drives and outings. Is it worth going for diesel for a car to be used on weekends but for long drives(considering the economy side of it).
Only thing which i have against a indica is its big problem of its wheel rims getting bent now and then. Pls help me through ur valuable suggestions and let me decide between a petrol and a diesel car and yes pls do give ur supporting facts to make ur stand on any one of it.
Thanking you,
Amit
amit_purohit20 is offline   Reply With Quote
Old 27th May 2006, 06:01   #2
Hi Amit,
Well I am also looking for car. I did so much research from past 6 months..
I have decided to go for Zen & Currenly looking for it. Well about Indica.. What I heard is after 1-2 yrs its becomes like a truck, Engine & Body conditions are not so good. U start getting all tuk tuk noise & all. I m not sure but all of my CAB drivers of office told me this,
You can check out for Zen, Alto.. Even U get a good resale value.. well check out for Ford Icon's too, Used one are coming as cheap as 2.5 lacs..
All the best & keep in touch with me
prakash2757 is offline   Reply With Quote
Old 1st June 2006, 19:01   #3
Thanked: 7 Times
think of the diesel option if you are travelling more than 50 km per day, otherwise petrol may be a better option. the upfront cost of a diesel car and maintenance costs are higher for a diesel car, so you need to have a higher running to make up for the costs. also diesels are more sluggish unless you go in for a common rail or turbo diesel
personally i don;t like the indica - i think there is a reason why they are cheap, it shows in the interiors and reliability. if you want a diesel in that segment, check out the palio. if petrol is the better option based on your running, there are several choices, as you would know
good luck!
SamRao is offline   Reply With Quote
Old 1st June 2006, 20:29   #4
sbasak's Avatar
@Amit
Diesel is not good option for only weekends drivings.
After purchasing the car, you may lose the hype of going out every week after few months
Alto/Santro/WagonR should perfectly feed your needs.
Of course, ultimate choice is yours.
sbasak is offline   Reply With Quote
Old 1st June 2006, 21:57   #5
mail4ajo's Avatar
Thanked: 261 Times
Originally Posted by amit_purohit20
Dear all,
Thanking you,
Amit
You may have the tax man at your doorsteps if you go for full downpayment. Gather all your tax papers for that.
The ALTO LXi is an ideal car if you are looking at economy (Decent Milage closer to the 20kms mark) and trouble free running. (good quality parts and Maruti service). Check the latest JD power ratings. ALTO is much above the industry average. Indica is not to be seen on this at all.
Diesel is good if you have many kms to cover. You will end up spending on its maintainence.
By the way, I am booking my first car in a week.(First car from my own money) Owned 3 M800s which were family cars.
mail4ajo is offline   Reply With Quote
Old 15th June 2006, 20:17   #6
storm162's Avatar
Hi Guys,
I am an ametaur driver and i am learning to drive ...(Going to the driving school) and i am not really sure for which car to go for .....
With the help of the valuable inputs you guys gave amit even i want to go for a diesel option -Ford Ikon,Palio,Siena,Cielo.(Refurbished)
and the other problem which i would have is that i can spend arnd 5000/Pm..
Please help
storm162 is offline   Reply With Quote
Old 16th June 2006, 11:59   #7
streetlife's Avatar
Thanked: 11 Times
Go for petrol man..considering you will only use it for weekends..
A 3-4 years old Zen or alto would suit you perfectly.
streetlife is offline   Reply With Quote
Old 16th June 2006, 12:19   #8
supremeBaleno's Avatar
Thanked: 1,711 Times
I second this choice. Alto is a wonderful 1st car - great FE, low maintenance, cheap spares etc. I would not recommend a diesel car for your usage. Since your drives are mostly highway, the Alto will give you great FE which is close to 20 or more. And if you decide to use it for daily driving, then also it is a good option in our crowded cities.
Why take on trouble by buying a 2nd hand car ? Buy a new one and have peace of mind. Alto would start at 2.5L or so. BTW, the Zen is coming with lots of discounts as it has been phased out by Maruti. That is also an option if you want some more power than the Alto. Spares should not be an issue for a long time, due to Maruti support.
Congrats, Ajo. BTW, which car ?
Old 16th June 2006, 13:00   #9
1100D's Avatar
Thanked: 2,503 Times
I wonder why the Santro eRLX does not feature in this thread.
If Diesel Vs Petrol debate has tilted towards petrol for this case, then are we not comparing Alto with the Diesel version of the Indica. Xeta however from what I heard from a few friends isn't bad at all. Definitely Bigger and sturdier than the Alto. But then service problems persist.
Moreover about Indica's turning into trucks which the drivers say, its more to do with the fact that most indicas are used by the Cabbie's. I came across a new indica (which is not run in) being driven at 110 at 4th gear. But owner maintained indica's have a much better fate. Wonder what would happen to the Alto's if they were abused that way.
1100D is offline   Reply With Quote
Old 16th June 2006, 15:23   #10
DCEite's Avatar
Thanked: 607 Times
get a WagonR or a Santro dude... Alto is good too but i didnt like its sluggish response specially with A/C on.
Forget about Xeta. Its currently undergoing TATA R&D.
DCEite is offline   Reply With Quote
Old 16th June 2006, 15:54   #11
@amit, you did not mention any budget. That would give us a better idea as to what car would be a better fit - instead of us reeling off all the small cars.
Also, you mentioned that since this is your 1st car, you want to go for a 2nd hand one. Though quite some people follow this logic, I do not see any valid basis for this. I would anyday buy a new car than deal with the headaches that come with a used car. And if budget is a constraint, it would be wise to go for a cheaper/smaller new car than a costlier/bigger used car.
Old 16th June 2006, 17:15   #12
drifter's Avatar
What makes you say that man? The xeta is pretty good.
Drifter
drifter is offline   Reply With Quote
Old 16th June 2006, 17:22   #13
Issues that buyers had just after purchase. There is a thread by Rudra Sir about his neighbour's Zeta woes.
Old 16th June 2006, 17:30   #14
Default wagonr - lpg
has maruti quietly released wagonr-lpg ?
i cant find details of it in http://www.marutiwagonr.com/
but to my suprise, when you check on the price list, its listed there already. LPG version is available only LX/LXI variant and is marginally more than the petrol only sibling.
anybody has any news or details on this ?
bharanidharang is online now   Reply With Quote
Old 16th June 2006, 18:06   #15
mail4ajo's Avatar
Thanked: 261 Times
Guys check this link:
http://www.jdpower.com/pdf/2005116.pdf
http://www.jdpower.com/pdf/2005253.pdf
Indica doesnt even feature in this list. This report was my decisive factor against Indica Zeta which I think is just about 15-20K more expensive than Alto LXi
Your first trip in your first car udaydesai Street Experiences 24 14th April 2011 15:35
Alto or A-Star? First car for a girl in first job at Delhi. dushmish Hatchbacks 51 3rd September 2009 23:43
First car, First Dent and 3000KM report- i10 amitbiz Test-Drives & Initial Ownership Reports 18 4th June 2008 16:33
Help me to select my first love [first car] deadman Hatchbacks 33 19th December 2006 20:36
