| Hatchbacks Alto, Indica, Swift, Fabia etc. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Sep 2006 Location: Bangalore
| Hi all, I finally joined a driving school and registered for a santro. After all the discussions from my previous threads where my preferences were changed from Indica to Santro/Wagon R, I thought learning on a santro would be good. But here are my experiences. Firstly it was fun to drive the car. Finished 2 hours of driving already and doing good. But now comes the cribs. 1) The clutch rest is a real pain. When I am depressing the clutch, the moment my foot hits the clutch rest I think that the clutch is depressed fully and obviously gearing screws up then. 2) To avoid this I have to bend my left foot inward to clear the clutch rest and though this seemed fine at first after the 1 hour my foot started to ache at the knees. Plus my knees started hitting the steering column when I brought it towards the right. 3) I noticed that there is so much space between the accl pedal and the edge of the car. I felt it would have been so much more comfortable had the accl pedal been placed more to the right. Note: the car was the older santro and not the xing. How different/better is the xing compared to the earlier santros in this regard? This brings me to some observations. I need a car where there is good spread between the pedals. How do you rate the comfort levels in Indica Xeta and Wagon R as compared to the Santro? Also, I realise that I cant judge the comfort of a car within a few mins of Test Driving it. Gotta be there for at least half hour. Regards, Prashanth |
| | #2 (permalink) |
| BHPian | Hi Prashanth as a owner of zip plus its strange in your case .... but since you have come across this before buying the car you can definitely move for the spacious car but i think i can resolve your problem ... why don't you drive with your seats moved back a little off in the next driving class so that you don't hit your knees i do this because i and my mom share different seating position ... it works for me ... give it a try for yourself ... make sure you seat in correct positon if you want i will mail you correct seating posture. Xing is only face lifted ... and changes like eRLX then ac vents so no changes to pedals and all... |
| | #3 (permalink) | |
| Senior - BHPian Join Date: Aug 2006 Location: Pune
| Quote:
| | #4 (permalink) |
| Interestingly since this topic has been brought up,I had some problems adjusting with the clutch of the new Maruti Omni.The clutch in this car did take some time getting used to . Last edited by rahul_intlad : 10th September 2006 at 22:56. |
| | #5 (permalink) | |||
| Senior - BHPian | Quote:
__________________ -[ " Objects in the mirror are loosing. " - Getz CRDi ]- | |||
| | #6 (permalink) |
| Senior - BHPian | Hai There, I think the dead pedal is a boon on long drives, I too use it a lot. I've found that if its not there you tend to rest your left leg on the clutch pedal and unconsviously press it which is bad for the clutch pads. Also the distance between the brake and accelerator is OK; I think in an emergency this saves previous seconds. It all boils down to getting used to the setting of the pedals. Happy driving. --Ramky Last edited by ramkya1 : 10th September 2006 at 23:29. |
| | #7 (permalink) |
| BANNED Join Date: Nov 2005 Location: ??
| I too have had a similar problem with the foot rest besides the clutch -- it is a good idea, but I think it is a bit too close for people with big feet. My suggestion is to always use shoes while drving and keep your left heel in line with the clutch -- this has worked for me and as aZa pointed out, it can be useful on long drives. Regarding the accelerator pedal, I feel it is actually a bit too far from the brake pedal. So if your right heel is in line with the brake pedal, you will find yourself reaching awkwardly for the acc pedal. The danger with this position is that your foot may get caught under the brake pedal when you try to brake in an emergency, especially when you have floored the acc pedal -- your foot would have to come up in an arc to avoid getting caught under the brake pedal. So you should probably place your right heel either in line with the acc pedal or somewhere in between the brake and acc pedals -- in any case make sure that you get this right so that there is no problem with braking in an emergency. And as people have pointed out -- move your seat back to make yourself comfortable with the steering wheel and also less cramped with your arms and feet. Your seat should also not be reclined -- this not only gives a poor view of the road, but is also bad for your back in a long drive. |
| | #8 (permalink) | |
| BHPian Join Date: Mar 2006 Location: Bangalore
| Quote:
Some people use the handbreak for this but I find this method providing more control. subbarp | |
| | #9 (permalink) |
| Senior - BHPian Join Date: Feb 2004 Location: DL XX XX XXXX
| Well... front legroom is at slight scarcity in santro... wagonR is better and indica is best. Pull your seat as back as possible... and recline the seat back a very little bit.
__________________ Č╠╣€€Я$ $£Қ |
| | #10 (permalink) | |
| Quote:
| | #11 (permalink) |
| BHPian | Hey herculesksp, AS per ur requirements for more legroom in the front near pedals, the Indica is no doubt the best in this case! the Santro/WagonR are all too cramped! and even the seatings are not that good as compared to the Indica! Try taking a drive in the Indica next time and then see which u like. |
| | #12 (permalink) |
| BHPian Join Date: Jul 2006 Location: Hyderabad
| Try test-driving a Palio in city Traffic .. Do the same for 30 minutes .. and you will be surprised by the difference .... Palio's cluch is a bit heavy and has to be pressed down .. though it appears cumbersome initially, once you get used to it, you can keep on doing it for hours without getting any pains .. Santro is worse on the highways where you start getting Knee pains if you drive for 3-4 hours continuously ... Have tried the same with Palio .. Drove between Hyd and Mumbai Non-Stop with one 10 minute halt at Solapur (after 5 hours) and one 20 minute halt at Pune (after another 4 hours). Did not feel anything either on the knees or on the back .. 700 kms covered in 11 hours .. Palio is absolutely funtastic on the long drives .. you can just keep driving it .. |
| | #13 (permalink) |
| BHPian Join Date: Jan 2006 Location: New Delhi
| herculesksp, i am very happy to see that you started learning car-driving before going for any heroics. good to see you going for a lighter car like santro. you can see yourself, the difference of self-knowing the things. in just very less time, you are giving your opinions about a car! ![]() and regarding the pain in ankles and knees, it'll decrease with a little more time spent behind the steering, very much like exercise. that dead-pedal or foot-rest is used to keep left foot upon it while driving. never ever get used to keep your left foot resting over the cluthc, it'll kill the clutch very soon. Happy "L"(earning)! |
| Thread Tools | |
Similar Threads | ||||
| Santro Eco or Santro GL (Any Review/Comments Eco) | ForeRunner | Hatchbacks | 4 | 11th December 2008 18:56 |
| One question about tyres of Old Santro and New Santro Xing | DDGuy | Tyre & Alloy wheel Section | 5 | 12th November 2008 13:35 |
| What next..for better experience | headers | Sedans | 131 | 4th April 2008 12:39 |
| Old Santro Vs New Santro eRLX: Worth a change? | ms_rana | Hatchbacks | 20 | 5th July 2006 17:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
