Old 22nd June 2007, 18:34   #16
Thanked: 143 Times
Indica turbo with hvac and power steering (DLG) will set you back by more than 4.1L on road. DLS (a/c only - no heater) should be slightly cheaper. Turbos however give you FE of 20 KMPL. But, unless a diesel runs at least 100 KM each week, the engines deteriorate pretty fast.
Old 23rd June 2007, 16:06   #17
snaronikar's Avatar
Thanked: 23 Times
I have a wagon R Lxi. Man the PS & AC is still very good. I'am driving from past 4 1/2 years. But only problem is FE. The Wagon R gives about 12~14kmpl. But Zen will at least give around 16~18kmpl (guess). The performance is 0~60kmph in 8~10 secs it has 1.1L engine and power is 64 bhp. Also the manuverability is very good in Wagin R with PS. It also has a powerful AC. The seats are at height than Zen which definately gives the advantage of clear view......
The annual manitenance cost would be around 1500 for servicing - 2 times/yr + Oil change for every 5000 Kms run. I would suggest you go for a Wagon R LXi.......
snaronikar is offline   Reply With Quote
Old 23rd June 2007, 21:39   #18
dockap's Avatar
Thanked: 376 Times
I would advice you to go for the wagon R its powerful,spacious,good driving position and comfort and in fact if u compare it to the new zen its rated far better
dockap is offline   Reply With Quote
Old 23rd June 2007, 23:25   #19
ScarySkulls's Avatar
Thanked: 19 Times
Mods can close the thread.
Got myself an Alto Lxi.
ScarySkulls is offline   Reply With Quote
Maruti Suzuki Alto 800 and Alto K10 get optional driver's airbag on all trims Rajeevraj The Indian Car Scene 18 18th August 2016 21:33
Alto K10 vs Alto 800 vs Hyundai Eon Added_flavor Hatchbacks 176 26th August 2015 10:34
@TVM. Taking a baby step; upgrading from an 800 darklord Hatchbacks 62 3rd January 2010 09:06
Alto 1.1 PW steering to Alto 800.non PWS Ramsagar Modifications & Accessories 12 15th October 2009 18:00
Wanted: Alto/WagonR/Zen/Swift ScarySkulls Shifting gears 10 12th May 2007 13:09
