Old 10th September 2009, 22:27   #106
i understand i am bumping a old thread but i have noticed preference was given to spark over estilo - earlier.
However, in light of new situation
1. Estlio with facelift and k line engine is out
2. Gm is having chapter 11 background.
What is your take now?
idea1979 is offline   Reply With Quote
Old 10th September 2009, 22:56   #107
aaggoswami's Avatar
Thanked: 1,542 Times
1) Take test drive of both the vehicles.
2) Personally I am not comfortable with the central location of instrument cluster.
3) Maruti has an obvious A.S & S. advantage as compared to GM.
If you are comfortable with Estilo, and if you are comfortable with Spark go for it.
The TD will be a very decisive factor.
aaggoswami is offline   Reply With Quote
Old 11th September 2009, 00:04   #108
Silver Knight's Avatar
Thanked: 23 Times
The only gripe with the Estilo was the engine. Plonking in the K series engine solves the issue. If you are ok with the looks and interiors of Estilo it will be the best.
Silver Knight is offline   Reply With Quote
Old 11th September 2009, 00:34   #109
What Maruti banks on is the k-series engine due to which the mileage is increased and life of the engine is good.
And also i did checkout the new look estilo which is already available for display in the showrooms if you are okay with the new look then it good to go to estilo.
General Motor are supposed to be steardy vehicle (my dad drives an Opel Corsa even i have driven it plenty of times) but when it comes to maintenance General Motor vehicles are pretty expensive when compared to maruti. In the long run Maruti are the best, especially if you are planning to travel a lot (outside of major cities) then maruti would be the best choice.
vivekhs is offline   Reply With Quote
Maruti Suzuki Zen Estilo - First Impressions basilmabraham Test-Drives & Initial Ownership Reports 55 31st October 2011 22:25
First car - Santro/WagonR/Alto/Estilo/Indica/Getz Prime/Spark/Palio 1.1/i10 simonkayar Hatchbacks 191 13th June 2009 12:21
Santro or Estilo or Spark or Palio sri Hatchbacks 28 16th December 2008 13:41
Chevy Spark...Chevy U-VA...comparative test drive report! omar1310 Test-Drives & Initial Ownership Reports 0 7th June 2007 11:59
