Old 10th December 2007, 19:21   #16
Thanked: 143 Times
gary4gar, since you dad will be running into plenty of rural areas, with bad roads and 200 to 350 KM away from major cities, and approx 50 Km from major highways, I suspect getting LPG will be a problem for at least another 3 years.
Go in for TURBO Indica - FE averages 21 KMPL according to all taxi drivers and operators I know. (that is in Kerala, where the entire state is one one big metro.)
At the distances you will be doing, I do think that more than FE, after 18 months or so, you will be more bothered with total cost of ownership (spares, etc).
I do think that given the conditions in which the car will be used, you may be better off with Indica.
You may however be advised to change over to alloy wheels - Indica OE rims are prone to bends due to the heavy weight of the car. I am only recommending that you use rims because you say your father will be diving to far off places, where I suspect the roads may not be very good.
Old 10th December 2007, 19:23   #17
Thanked: 143 Times
Originally Posted by gary4gar View Post
i also think so but someone said indica being a Diesel car will have high maintenance costs & also Diesel engines die out faster
May be, may not be. What counts is that if this is really true, the taxis, who average 5K km per MONTH to break even, will not be going in for Indicas.
Old 10th December 2007, 20:13   #18
extreme_torque's Avatar
Thanked: 1,318 Times
Indica... its a no brainer. The wagon-r duo would average less on LPG than it does on petrol. Even running on LPG Wagon-R will be more expensive to run compared to an Indica. Indica is a very underrated car, its a hell lot better than the Wagon-R (no offence to anyone). Looking for a small car option with alternate fuel, Santro with CNG makes more sense keeping in mind everything you want out of your car.
extreme_torque is online now   Reply With Quote
Old 11th December 2007, 11:19   #19
Thanks a lot guys or replies, i will refer this thread to my dad, hopefully we would get it as a new year gift
but i am concerned as someone sad that prices are increasing in new year?
gary4gar is offline   Reply With Quote
Old 25th December 2007, 21:23   #20
Thanked: 46 Times
I own WagonR duo for last 3 months and have done about 3000 kms till now. I will post my experiences after 5000 km. I had a tough time to choose between Wagon R Duo and Indica turbo DLG, cost almost similar.... but I chose Duo, reason? Quite simple
"You have to be lucky to get a good Indica but you have to be unlucky to get a bad maruti car".
Its the brand reliability that was one of the foremost reasons to select DUO, and I am pretty happy with her!
sallubhai is offline   Reply With Quote
Old 26th December 2007, 12:35   #21
aks_karthik's Avatar
Thanked: 215 Times
Defn LPG won't give u better FE than Indica Turbo Diesel.
Now the LPG is More less equal to diesel's cost.
Diesel cars gives better FE than LPG fitted cars.
Go for Diesel car.
aks_karthik is offline   Reply With Quote
Old 26th December 2007, 14:18   #22
hrman's Avatar
Thanked: 361 Times
I think the parameters should be like this:
1. Space: Indica turbo
2. Mileage : Indica
3. Cost per Km.:Indica- Rs.1.82 - Rs.31 per litre @ 17 kms
Wagon R LPG: Rs.2 - Rs.28 per litre @ 14 kms
4. Service network: Wagon R is the clear winner here
5. After sales: Maruti has better resale value than Tata. I tell this from experience
6. Driveability: Power steering of Wagon R is far superior to Indica. Indica Power steering is quite hard (in experience terms, its like steering through Mud as against steering through butter of Wagon R).
7. POwer: Turbo and Wagon R may be evenly matched here, although I would give higher points to Wagon R here.
8. Initial cost: I think the on-road of the DLG turbo is lesser than the Wagon R Duo. Pls check this
9. Life cycle: Both cars are on their end of the life cycle: Indica is coming out with Version 3 DICOR in 2008, so V2 Turbo will become outdated soon. Wagon R can also expect to take a new avatar sometime in 2008. So no choice here.
On the basis of the above, decide your drive and drivability and make the choice. You will not regret either ways.
hrman is online now   Reply With Quote
Old 26th December 2007, 14:59   #23
Thanked: 22 Times
2. Mileage : Indica
keeping in mind your requirment and above mantioned points you shold go in for an Indiaca.
Car-Agey is offline   Reply With Quote
Old 27th December 2007, 14:02   #24
tez
tez's Avatar
Thanked: 16 Times
if u are waiting till Jan, why not look out for Fiat Palio 1.3 MJD. With the a strong built, good handling along with diesel, it could be another good option.
tez is offline   Reply With Quote
Old 31st December 2007, 16:08   #25
is Indica high in maintenance and spares parts?
Old 31st December 2007, 20:23   #26
If it was it would never have been a taxi. Besides wagon-r cant take even half the amount of abuse the indica can. Also the indica would be safer, active and passive both. Frankly I would not dare to go out on a highway with my family in a Wagon-R.
Old 31st December 2007, 20:27   #27
someone said new version of indica is round ther courner, anyone can give more details on it.
Old 31st December 2007, 20:46   #28
DCEite's Avatar
Thanked: 480 Times
Well my wagonR takes a lot of abuse from me, being driven on broken roads of DLF and potholes of MG-Road everyday. Touch wood it does't feel like falling apart yet (Done ~40k). Only thing is, the plastics show their age very quickly. :(
If you are talking about the Indica Turbo with ABS and Airbags, and comparing with a bare bone wagonR, yes, you are right. But not without it. Franky i won't arrive at a conclusion unless i have the crash test ratings of both handy.
You are talking as if its an OMNI.
Please don't form your opinions based just on the height or the tall boy stance. Their is so much more to highway stability and safety. Again, I would not like to arrive at a decision just aise he.
DCEite is offline   Reply With Quote
Old 31st December 2007, 21:03   #29
CrAzY dRiVeR's Avatar
Thanked: 16,771 Times
My WagonR is now at 42,500 kms+ and managing fine till now. Have done highway trips without any big problems (with family).
Anyways, you are entitled to your opinion! Hope it comes from experience and not prejudice!
Old 31st December 2007, 21:20   #30
I have been in various indica cab having more than 80k's on the odo and a wagon-r cab with 25k's on the odo, so talking out of experience.
Its not that indica was rattle free infact far from it, but wagon-r was worse.
Talking of private owners, one of my friend drives a 70k old indica NA engine with hardly a squeak or rattle from anywhere.
I am not saying wagon-r is unsafe, what I am saying here is that Indica is safer. I am its pretty obvious why, if you still dont believe me just have a look at crashed indica's and wagon-r's lying in stock yards of various showrooms.
This is just my opinion and this is how I feel
There have been times when I had to swerve at 90-100 kph on highways in my palio due to some morons and their stupid ways of driving. Cant even think of doing that in a wagon-r. I am not saying it cant or will not be able to manage but its just what I feel, no offences meant to any owners.
Maruti restarts selling LPG WagonR Duo in old version EDIT : New Duo now launched aaggoswami The Indian Car Scene 10 17th February 2011 03:07
New Wagon R Duo Broke Down shivkumar19 Technical Stuff 20 9th April 2008 12:21
Fiat palio stile or Wagon R Duo sundance Hatchbacks 26 17th May 2007 18:03
Wagon R LXI Duo or Swift Vxi nikunj_cal Hatchbacks 7 3rd April 2007 15:49
New Wagon R DUO or Swift?? ~~VinZ~~ Hatchbacks 10 9th August 2006 17:14
