Old 2nd August 2009, 22:49   #16
mithun's Avatar
Thanked: 59 Times
Best LPG Hatch : Wagon R. Tried & Trusted.
Old 3rd August 2009, 17:14   #17
AirWind's Avatar
Thanked: 84 Times
Could be usage of domestic (subsidized) LPG in place of Auto LPG. Domestic LPG has a deliberate adulteration of an odorly substance to nasal detect when there is leakage - can you smell gas in your kitchen? The retrofit kit has a filter to trap this odorly agent and has a tap to release it at a said frequency and that used to really stink!
Originally Posted by r_nairtvm View Post
Hello Guys,
Can you please tell me, why does the smell of LPG so strong with in hatchbacks particularly.
Recently in TVM I was looking at some Santros (2003-2006 models) to buy for my mothers use there (seat hight was a factor for her to get in and out). What I noticed was invaribly in all LPG versions, the smell of LPG was there and even ones clothes had the smell even after getting out of the car. I experienced this in at least 4 cars.
Is it endemic with all LPG hatch backs or was it for those particular cars only.
Thanks for your thoughts
Ram
PS - I bought a Santro 2003 Zip. 39,000 on Clock, PwS, Remote locks, Sonly Xplod, 4 brand new tyres, Generally Good condition for 165 K.
AirWind is offline   Reply With Quote
Old 3rd August 2009, 18:29   #18
shineshine's Avatar
Thanked: 37 Times
Autogas also has the odourly sustance(Mercaptan) in it, but in a substantially lesser quantity than with the domestic LPG cylinder. Regarding, the 'Filter to trap', there is no such thing to trap mercaptin, the filter that you refer to is actually the 'Diaphragm' in the vaporizer kit, and it serves as the membrane between the water and LPG. The heat from the water is transferred easily through the diaphram to the cold LPG from the tank where it gets vaporised.
But, yes there is a tap in most of the vaporisers to drain mercaptin. If you are frequently using Domestic LPG, you need to clean the vaporiser (diassemble it) somewhere by every 12,500 to 15,000 kms.
Regarding the cars. Here goes my ranking.
1. Spark LPG.
This has got the best technology in it. A 100% sequential technology with a slave ECU with injectors for each cylinders. Consistant performance on all weather conditions.
2. TATA indica Xeta.
This has got he second best technology, a semi sequential injection, eventhough it has a slave ECU, there is no seperate gas injectors in it. The lpg is directly guided to the intake manifold through a stepper motor.
3. Santro Eco, wagonR duo
Both of them share a similar Open loop arrangement with emulator. The performance/tuning varies with change in ambient atmospheric temperature. The WagonR also has the tendency for backfiring on hard acceleration which ultimately BLOWS the AIR FILTER BOX at times.
I have test driven all these and found the SPARK engine extremely smooth on LPG. There is no big difference while putting AC in spark, while all the three behaved as if it has LOST ONE BIG CYLINDER!!!
shineshine is offline   Reply With Quote
Hatchback Dilemma ByDesign Hatchbacks 179 15th August 2010 20:51
LPG car for my parents (Old Alto or new 800 LPG) jits_1998 Hatchbacks 7 9th October 2009 11:19
Hatchback dilemma (4.5 - 5L) EatMyDust Hatchbacks 69 21st May 2007 16:50
Wagon-R: VXi+LPG OR LXi+Upgrades+LPG? EDIT: Now booked LXi sohu9 Hatchbacks 14 16th January 2007 13:37
