Old 23rd December 2009, 10:05   #1
mohandas's Avatar
Thanked: 27 Times
Question SAFIRE vs FIRE: Same engine different FE?
TBhpians:
Here is a strange situation. My younger brother is considering the following hatchbacks and trying zeroing on one.
  1. GP 1.2 Active (Fiat) (Ex-sh @ hyd : 4.06 lacs)
  2. Indica Vista Aqua Safire (Tata) (Ex-sh @ hyd : 3.64 lacs)
From the research, i have found that both are the same engine which is 1172 cc, 8V Fiat. They are also tuned to produce same power and torque. Moreover, they are also designed to pull vehicles of similar weighs.
However, when it comes to FE, I see them widely different. Most of the reviews (professionals and current owners) on 1.2 Active are claiming good FE. On the other hand, majority of them on Vista safire claim okay to poor FE.
How this is possible? Any insight.
mohandas is offline   Reply With Quote
Old 23rd December 2009, 10:13   #2
DieselFan's Avatar
Thanked: 234 Times
FE depends a lot on factors other than engine - ECU, exhaust system, Air filter, Transmission, suspension, wheels and tyres being the most important elements that influence the FE over and above engine.
DieselFan is offline   Reply With Quote
Old 23rd December 2009, 10:18   #3
Thanked: 197 Times
Adding to DiesalFan....some other parameters are Drag coefficient, weight , engine tuneup parameters, gear rations etc
tj123 is offline   Reply With Quote
Old 23rd December 2009, 10:37   #4
mohandas's Avatar
Thanked: 27 Times
what is Drag coefficient? Is this something to do with Chasis?
To my knowledge, most of the things that you and Diesel Fan have mentioned are same or similar. For eg, ECU, and engine tuneup are same, both are having fiat Transmission, both have got same suspension according to spec. Don't know about exhaust system and Air filter. But, then, how come they are sooooo different? Surprising? Isn't it?
Old 23rd December 2009, 10:54   #5
msharma_79's Avatar
Thanked: 22 Times
May be you need to go back to your source which has given the info at the first place. Test drive the cars and let us also be aware of the changes.
I would like to believe that vista should give a better mileage!!
msharma_79 is offline   Reply With Quote
Old 28th December 2009, 11:28   #6
mohandas's Avatar
Thanked: 27 Times
Default re
From a little research, this is what i have found.
The ECU mapping of the SAFIRE and FIRE is difference. The chasis, and wheelbase of punto and vista is also different. Primarily, due to this, the FEs of vista and punto 1.2 are different.
Different manufacturers : Exactly the same engine capacity gsbhatia Technical Stuff 14 28th June 2016 17:18
Would you buy the "same car" with "Same Color" as your immediate neighbour? cool.aquarian The Indian Car Scene 39 12th November 2010 13:57
Same Profile, Same Make. But still difference in diameter. Possible? vrooooooom Tyre & Alloy wheel Section 34 13th August 2008 21:07
Different Speaker Brands = Different sound for same/similar music ? normally_crazy In-Car Entertainment 10 29th August 2006 12:05
