Go Back   Team-BHP > BHP India > Team-BHP Reviews > Indian Car Dealerships
Old 16th February 2016, 12:15   #16
alpha1's Avatar
Thanked: 1,035 Times
Default Re: XC60: Flood damage at Volvo dealership
Originally Posted by IshaanIan View Post
that causes a low pressure zone in the manifold
Why should there be any instance when the pressure at exhaust manifold is lower than atmospheric? From what I can reason out, the pressure at the exhaust manifold will be much higher during the exhaust stroke, however once the valve has closed down, it has to become equal to atmospheric.
Old 16th February 2016, 12:36   #17
IshaanIan's Avatar
Thanked: 3,393 Times
Not sure of the specifics as I am more into the driving aspect than the engineering behind it though I would love to keep the discussion going on. However, why would it need to be lower than atmospheric pressure to pose harm? You do realize we are talking about an exhaust pipe that would be submerged in water right? Pressure under water is obviously much higher If you read my narration of my personal experience, you will note that I had to pilot my car through water was above the headlights with the bonnet nearly submerged at some parts.
PS: did some reading up, apparently there are 3 components to an exhaust pulse and the 3rd component is said to initially match atmospheric pressure but the momentum of the high and medium pressure components reduces pressure to lower than atmospheric level
IshaanIan is online now   Reply With Quote
Old 16th February 2016, 13:51   #18
alpha1's Avatar
Actually I agree with your reasoning, but my question was different. Let me be more specific with my question
I agree that IF the pressure is lower than atmospheric, the water will be sucked in the exhaust pipe.
I also agree that IF the water gravitation head is greater than the pressure at exhaust, even then the water will make its way in the exhaust.
However, my question was different and perhaps answered by the second part of your post:
Why or rather how will the pressure at the exhaust manifold become less than atmospheric under normal engine operations?
Now you have mentioned about the exhaust pulses. Which in other words mean that there is a standing wave formation in the entire exhaust pipe and the node and anti-nodes of this standing wave refer to the points of low pressure and high pressure respectively. In this case the node, having a low pressure may encounter less than atmospheric pressure (incidentally, this is the reason why people fit expansion chambers in 2 strokes, since lower pressure at outlet is better at sucking the exhaust gases out).
But then, water will have to make its way through the anti-node too, where the pressure is much higher than atmospheric.
How will the water sneak in through this region?
In other words, have we actually encountered a case of water ingress via exhaust pipe in a running engine?
alpha1 is offline   (1) Thanks Reply With Quote
Is Flood damage covered by insurance? gabrielthomas Indian Car Loans & Insurance 4 2nd December 2015 10:19
In pictures, Kashmir flood damage ariesonu Shifting gears 2 21st October 2014 10:38
Volvo S60 "HOT" and XC60 are coming. EDIT : XC60 launched at 39.50 lakhs ajai_dev The Indian Car Scene 56 19th January 2011 10:41
Honda paying for flood damage delay? GTO The Indian Car Scene 3 24th November 2005 20:27
Indian car makers INETHICAL approach to Mumbai 26/7 Flood Damage GTO The Indian Car Scene 15 5th October 2005 22:30
