Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Indian Car Dealerships
Indian Car Dealerships Your real life experiences with Indian car dealerships and service stations
Thread Tools
Old 1st March 2007, 00:19   #1 (permalink)
Zappo's Avatar
Default Careless mechs. What a pain!
I just noticed after a good couple of months since my car came back from its scheduled service that some stupid mech at the authorized service station has damaged a part of the body paint. Pics are attached...
I scraped a part of it and it reveals the painted surface...
The hood once down hides the damage!
Initially I could not understand how it happened. Then I figured it out. Some careless bugger probably dropped the corrosive battery electrolyte while topping it up. Now the hood is such that once its shut down it covers the damaged part very well. Only when I opened the hood to clean the insides did I notice it. Obviously it won't work if I go back now and accuse them.
So, short of getting that part painted is there any other way I can get rid of this mangy look? I scraped a small part (see the 2nd pic) and it seems to be revealing the painted surface albeit shorn of the gloss. I am worried that if I do not do anything will it corrode the sheet metal overtime?
Any ideas?
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here
Zappo is offline   Reply With Quote
Old 1st March 2007, 02:30   #2 (permalink)
rr_zen's Avatar
I had a similar experience with my esteem though this was not caused by anyone deliberately. The battery acid had spilled on the areas abutting the battery holder and I could see the paint peel of like a piece of paper. Inititally I thought of taking it to a paint shop but was apprehensive that this might be too small a job to be undertaken by any repair shop. Finally, I decided to fix it myself. I bought the required paint, primer, and emery sheet (sand paper). After scraping whatever was remaining on the affected area (so that the metal inside was visible) I applied two coats of primer and allowed it to dry for a day. After that went on it two coats of paint one after the other. This has solved my problem. Fortunately for me, it happened inside the engine compartment. Do not care for a professional glossy paint finish as the affected area is not visible from oustide. Whichever method you chose to adopt, the bottom line is that you should patch up the damaged area with new paint ASAP to prevent it from spreading to other areas. Get going. Your time starts now !
__________________
Life is a learning and Change is the law of nature !
rr_zen is offline   Reply With Quote
Old 1st March 2007, 11:04   #3 (permalink)
tsk1979's Avatar
zappo next time you go the service station let them prepare a job card.
They will take not of all scratches etc.,
They won't open the bonnet you see.
When you get the car then just open the bonnet supposedly to inspect engine bay washing, and then tell them "how did that happen".
If they can do it, so can you
__________________
Reclaimed, wrung dry and recycled....!
Old 1st March 2007, 11:24   #4 (permalink)
benbsb29's Avatar
@tsk : Wont it look kinda old.. the marks i mean.. they would very well wash off their hands saying its the customer's headache.
__________________
"You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer
Old 1st March 2007, 11:28   #5 (permalink)
tsk1979's Avatar
According to the rules, the workshop has to own up any damages to paint or exterior which is not marked in the job card. Atleast Tata has this, so they thoroughly go around the car, but miss the bonnet
__________________
Old 1st March 2007, 12:24   #6 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
Have the same issue (battery electrolyte spilled onto the plastic battery tray and from there to the painted surface) with my Baleno. It looks so ugly.
Need to mark some time to rectify it like rr_zen did it. Nice DIY spirit there rr_zen.
__________________
Suzuki Baleno : 91bhp @ 5500rpm, 130.5Nm @ 3000 rpm, 14kmpl in city @ 100% a/c.
Fun & economy needn't be mutually exclusive.
Old 1st March 2007, 12:31   #7 (permalink)
Same thing happened with my toyota innova's battery....Without blaming anyone first go to the battery manuf and get the batteries checked...in my case(exide) the guys simply replaced all the battery caps and dis the servicing of the battery.the caps of the battery have small vents to let exxcess smoke/vapours to release and if these get clogged..pressure build up leads to splashing of the acidic battery fluid.
pujaari is offline   Reply With Quote
Old 1st March 2007, 12:55   #8 (permalink)
Bass&Trouble's Avatar
Once when I was having the nozzles of my Sierra re-installed after service, the guys used more torque than required, and cracked the engine head, and then used M-seal to pack it up.
__________________
Losers Commute. We Ride.
Old 1st March 2007, 13:22   #9 (permalink)
navin's Avatar
You are lucky it was only your engine. One over-enthusiastic mechanic used paint thinner to clean my Astra's dash board and the Alpine HU. Now this Alpine HU was one that did not have any internal power amp. yes that one - only it dont have it's legends anymore.
__________________
Scixelsyd Etinu
Old 1st March 2007, 14:17   #10 (permalink)
esteem_lover's Avatar
And lost its resale value .
My garage has the dirtiest guys working & they dont care about dirtying the seats or steering. But they do a wonderful job. So, i always put on a set of old seat covers & take off the steering grip everytime i give the car for service. Once they bent my brand new number plate & just bent it back to shape. The hurt is still there & so is the dent.
__________________
"Keep your friends close, Keep your enemies closer"
Old 1st March 2007, 22:03   #11 (permalink)
rr_zen's Avatar
Thanks SupremeBaleno. At least I have friends like you who appreciate what I do with my car. At home I am most unpopular for spending most of my time during weekends with my first love, my car !!
__________________
Old 1st March 2007, 22:21   #12 (permalink)
Zappo's Avatar
I thought of that too, but ticked that possibility off as in that case it would have not spilled over on the top. If you look at it the damage has happened above the battery level and that too at the side which is outside. Uhuh... if it would have happened the way you say the damage would have been inside the bonnet surface.
tsk... thats one heck of an idea... only hitch here i guess is that i find it a bit difficult to dole out a straight-face-lie dekhte hain...
however one thing is that the thing seems to have lost all its strength. do u people think that it may cause any further damage if something is not done immediately? its already been like that at least for the last 2 months... till i noticed it. i was wondering if and when i have some time maybe i will take the car to the body shop for a touch up all over, you know those nicks and scratches in the lower body that all these unruly bikers leave and at that time i will get this mended as well. but only if i am sure that the damage will not spread further.
__________________
Old 1st March 2007, 22:25   #13 (permalink)
vid6639's Avatar
it's not a dent right zappo. One thing you can do instead of fighting it out with fools is just get a touch up paint job. most service centres will do this for free.
Touch up hides it noticably as well prevent corrosion.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 1st March 2007, 22:28   #14 (permalink)
Hellraiser's Avatar
darn these mechanics ,most of the time they are careless.
the last time i gave my car (ohc) for servicing some careless mech broke/cracked the right side skirt (dont know how) even though i specially told them to be carefull with the car as it has skirts all around on top of that then they refused to pay for the damages or repair it.
__________________
somewhere i belong........
Hellraiser is offline   Reply With Quote
Old 1st March 2007, 23:08   #15 (permalink)
Zappo's Avatar
Originally Posted by vid6639 View Post
it's not a dent right zappo. One thing you can do instead of fighting it out with fools is just get a touch up paint job. most service centres will do this for free.Touch up hides it noticably as well prevent corrosion.
No its not a dent. Its just some greenish sediment formation on top of the painted surface... in fact scratching it lightly even removes the sediments and reveals the painted surface underneath.Touch up I am not sure about. The body shop guy always says that metallic paint is impossible to touch up as it immediately stands out. So the least he will probably insist on is to get the whole stretch of the surface below the windshield painted.
__________________
Thread Tools
Royal Enfield Machismo Good Mechs In Bangalore sreerajunnithan Motorbikes 29 30th July 2009 11:19
Traditional Car Mechs in Kerala AKA "Aashaan" muneemmk Modifications & Accessories 7 30th January 2009 22:44
Bike with no back pain bill1182 Motorbikes 78 5th January 2009 13:43
Hyderabad mechs? katalyst Modifications & Accessories 3 29th September 2006 15:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
