| Indian Car Dealerships Reviews of Indian Car dealerships and Indian Service Stations. What are your favorite dealerships and service stations? Who have you had bad dealings with? |
| | Thread Tools |
| | #46 (permalink) | ||
| BHPian | Quote:
@Jaggu - Nice to see that you still go by the book. btw, I always switch to low beam for cyclists/two wheelers/autos or other motorists who maybe at a disadvantage, but give away nothing to others who inconvenience me. | ||
| | #47 (permalink) |
| Senior - BHPian | Kuttapan, The problem with your approach will be when you meet another Kuttapan on the road (i.e a like minded fellow who follows the same approach as you) on the road. Both of you will be waiting for the other to switch to low beam. In the end, it will be a deadlock situation and both of you will suffer. |
| | #48 (permalink) |
| BHPian Join Date: Jan 2008 Location: Chennai
| [quote=kuttapan;771209]@mission_safari - I have clarified this before. Read above. I agree that the intensity is better with a higher wattage bulbs, but the low beam is designed to get cut off after a certain point and only illuminates 20-25 metres in front of your car. Which does not pick up obstacles, road curves etc in good time, if you are travelling at good speeds, assuming you do not know the lay of the road like the back of your hand. Thanks Kuttapan . Sorry i missed that in the previous post. I have another silly doubt which i cannot resist myself from asking. Can't we use the low beam bulb in place of the high beam bulb?
__________________ If the world was fair, God would've been here |
| | #49 (permalink) | |
| Senior - BHPian | Quote:
BTW, found out that my low beam wasnt working because the relay for the low beam has gone kaput. So in addition to spare bulbs + fuses, it may be a good idea to carry spare relays as well. | |
| | #50 (permalink) |
| [quote=spadival;772334]Its the same bulb with 2 filaments - one for high beam and one for low beam. Thanks spadivel. I feel so dumb but what the heck unless i ask the doubt will always be a doubt.
| | #51 (permalink) |
| Newbie Join Date: Jan 2007 Location: Hyderabad
| A stupid question, but how much of a difference can the beam adjustment switch make in situations like this? Can the low beam be pulled up as much as possible so that the situation is a little better? ( I am assuming that Swift has beam adjustment feature.. ) Last edited by theMAG : 26th March 2008 at 17:03. |
| | #52 (permalink) |
| BHPian Join Date: Oct 2007 Location: Bangalore
| Everybody says that Maruti A.S.S is very good. But I feel that Maruti has more service centres in number, but the quality of service offered in most of the centres is very poor. Suppose if you have 10 authorised service centres in a town, out of that only 1 or 2 might turn out to be good. Same applies to availability of spares also. |
| | #53 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
Not much really. Due to the increased speeds on highways, even the furthest setting of the low beam wont have enough reach to spot obstacles approaching you at 80 kmph.
__________________ If you lose your temper, you’ve lost the argument | |
| | #54 (permalink) |
| BHPian Join Date: Jul 2007 Location: MUMBAI
| Hello all - I guess I can contribute. I drive my Scorpio between Mumbai and Nasik every week maybe sometimes 2 times a week and it is always in the night (leaving at 7PM from office to directly go home 200 kms away). I am a staunch user of 140/110 watts bulbs made by GE. I used to use Philips 130/100 earlier. I trust only one shop in Mumbai for my bulbs and I have the wiring loom setup with Bosch relays, shunts from the alternator and Finolex wiring running right through on all my Fiats (you will find my recommendations on page 60 of the automotive lighting thread in the modifications and accessories section). Recently I have found that it is the manufacturing quality of these bulbs which is very bad. I believe that most bulbs come from China irrespective of the packaging information and that the bulbs are just not as good as they used to be. So I am not surprised at Kuttapan's ordeal. As I know this, I am still on my original 60/55 watts production bulbs on my Scorpio because I have not yet found good 140/110 bulbs for it. Incidentally, I drive with my manually adjustable headlight setting on "no 2" position and the 15 degree cutoff is perfect on the road in front of me. This is just for your information. I do not have fog lamps on my Scorpio because I do not like the way they are accommodated in the bumper. As far as Maruti or for that matter any other service is concerned, you as a customer approach a service advisor. Most of them do nothing except act as a post office. You look at their background profile, look at their faces and there is no spark there. It is the Raju or Ravi or Abdul or Ustad electrician who actually attends to your car and solves your problem (I swear by Zaheer and Zakir electricians in Nasik). If there guys are not there, there is nothing that the post office can do is it ! The electricians know what they are doing but take pride in not disclosing anything to anybody (maybe except me as I have built a bond with them). As a contingency plan, I am also my own electrician whenever I want me to be. Same goes for mechanic, doorwallah et al. Another suggestion. As a cardinal rule, I never ever leave a city limit without my toolkit which is completely equipped to handle most situations. The toolkit supplied by almost all manufacturers is not even worth laughing at. A rigged-up 12 volts bulb fitted to an old torch body (with spare Japanese make good quality bulbs placed inside the torch where it's battery should have been) is an absolute must in the middle of nowhere at night. I have helped scores of people who used to use matchsticks before (with one Fiat guy trying to soften the petrol pipe which had come off by burning it - HaHaHa) and now use mobile lights in trying to fiddle their way through. This is my system. It works best this way. I have been using it for 31 years. No compromise. Best regards, Behram Dhabhar |
| | #55 (permalink) |
| BHPian | I have always preferred to travel at night due to lesser number of people, cycles, goats etc on the highways. It is very difficult to maintain speed without the high beam. I normally use the high beam and use the low one when another vehicle approaches. IMO the worst time to travel on the Indian highways is during 5:30 p.m to 9 p.m as all the villagers return home during this time and they hardly pay any heed to traffic.
__________________ Don't quit when the hill is steepest, for your goal is almost nigh; don't quit, for you are not a failure until you fail to try |
| | #56 (permalink) |
| BHPian | @spadival - Yes, deadlock situations can happen. These are far and in between. You encounter more trucks and buses on the highway at night, so they are tha main concern. I have found that the truck guys are better than the buses, most of them actually use the dipper switch. Buses do not even know it exists. @Behram - Sir, it was the Raju or Ravi or Abdul or Ustad electrician who gave the faulty diagnosis. If I had the equipment, I would have done the troubleshooting myself. Will heed to your advice and get myself a comprehensive toolkit. |
| | #57 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Another point is the training the manufacturer provides the mechs when new models are introduced. When i had the AC fuse issue and approached the dealer in Kerala they were clueless even to the extent of locating the fuse box! So eventually one will have to get a works manual and special tool if one needs to attend to such emergencies :(
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
« Any recommendations for Maruti Dealer in Bangalore?
Shocking News about Popular Hyundai, Trivandrum »
| Thread Tools | |
Similar Threads | ||||
| Why does the customer Service suck in INDIA?? | deftones | Shifting gears | 5 | 11th August 2008 18:47 |
| When will we get customer service like this? | vijayrv | The Indian Car Scene!! | 12 | 8th March 2008 23:28 |
| Maruti Estilo fails to live up to expectations??? | rahul_intlad | The Indian Car Scene!! | 99 | 27th July 2007 09:49 |
| Customer Service!! | moralfibre | Shifting gears | 1 | 11th November 2006 20:32 |
| Amazon customer service gone downhill ? | bigman | Shifting gears | 3 | 25th February 2006 01:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
