| Indian Car Dealerships Your real life experiences with Indian car dealerships and service stations |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2007 Location: Bangalore
| My dad has an Accord - 15 months old WITH an extended warranty - the car is currently under warranty. Last month I took the car to Chennai and I found a shuddering while applying the breaks at speeds above 80 kmph. Showed it to Honda Service at Dakshin Honda and they said that the break pads and disc pads have to be changed and that they will NOT be covered under warranty. Cost is estimated to be above 10K. The car has done not even 10,000 km, is just a year and three months old. What kind of quality is Honda dishing out if pads dont even last 10K km? And this car is rarely driven on highway - only my Chennai trip in fact, and mostly only in Indiranagar area Bangalore. My Lancer which is 10 years old is better than this and required mandatory pad changes only at 50k km. We have had Hyundais, Skodas, GM cars and none have required pad changes so early. Can anyone help me out with some tel numbers/e-mails of someone in Honda who may be able to receive this complaint?
__________________ Regards, Deepak |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay
| deepak, "the brake pads and discs have to be changed" is the easy way out and shotgun style solution for a problem like this. Did the people at honda check your car? Did they actually remove and measure the discs for any warpage? I would suggest you pinpoint the problem first. If the discs are warped - maybe it could be considered a "manufacturing defect" - (since its at 10k). Is it one disc or both discs that is warped? That will tell us something too. Could it be some issue in the steering system that is actually causing this - a cracked or worn bushing etc? How bad was the shuddering? I guess what i am saying is get a thorough diagnosis and pinpoint the cause of the problem first, then figure out how to fix it and deal with honda. cya R
__________________ The memory of you will ride by our side forever. |
| | #4 (permalink) |
| Senior - BHPian | I think "Whitefield honda" is better...contact the service advisor by name "Srinivas". This guy is good , i make sure he is incharge of my car every time i leave it for service...you can ref my name to him...
__________________ " Everyone wants to park their car/bike in the shade(of a tree) but none wants to grow one!, SAVE TREES/GROW TREES" |
| | #5 (permalink) |
| Senior - BHPian Join Date: May 2004 Location: Bombay
| Accords especially automatics are notorious on brake pads...mine wore out every 20,000kms and i felt that was too early, but 10k is ridiculous ! Is you car manual?
__________________ ______________ __________ ______ __ |
| | #6 (permalink) |
| Team-BHP Support ![]() | Welcome back Doc 10k is too soon unless one has been driving around hills at high speeds. Let us be specific, have they told you that the pads are of a minimum thickness ? Have they actually checked the discs for trueness. If you pads are worn at 10k, your wheels should be black with brake dust. Take a pic of the caliper through the wheel, we might be able to tell! Now the embarassing elimination question! Did you do a panic brake on loose surface or steer when braking? you might have tripped the ABS. The accord being very nose heavy loads all its weight on the front end under hard braking causing the wheels to potentially lock up, kicking the ABS in If no to above I would first start with rebalancing your wheels and lthen looking at your suspension for wear
__________________ Rice is cheaper than German Potato's |
| | #7 (permalink) |
| BHPian | This is just the beginning, when I come to Honda spears are bit expensive. But I don’t think break pad would wear out for 10,000Kms. If you are sure that, break pad have not gone bad because of cosmetic or physical damage you can definitely question Honda one 2 one. They would inspect the car and is it’s a manufacturing defect or some other issue from there end, then they might give you some options because one of my family friend when he had escalated the issue Honda guys did contacted him back and they embarrassed some part of money. You can call Honda one 2 one on 1800 113 121 or 011 – 39898918. Before calling them check what is the warranty on the break pad’s and also make sure that there is no fault from your end. It’s a Honda technology and it’s not that easy to fail, but if it has then they need to stand with there product and get it fixed.
__________________ "If you obey all the rules, you miss all the fun" |
| | #9 (permalink) |
| Team-BHP Support ![]() | It is very rare for brake pads to wear out at 10K. However, the symptoms you describe are almost certainly caused by an uneven brake disc. I think its a case of faulty brake pads and / or brake discs. You should push for warranty replacement. If not, it will be cheaper to skim the brake discs rather than change them altogether.
__________________ GTO Work backward from your imagination, not forward from the past!
| | #10 (permalink) |
| Distinguished - BHPian ![]() | Even if we are to assume that the ABS working has caused it I think you can expect Honda to sort this out under warranty. Take it up with the regional representative and you should find a solution.
__________________ In changing yourself, you change your life |
| | #11 (permalink) |
| Distinguished - BHPian ![]() | You will notice uneven brake discs only during highway driving, which is what you did for the first time to Chennai. Unless it's a very severe uneven disc which you can notice in slow speeds as well. Push for warranty replacement by writing to Honda.
__________________ Let's get "instigated"..... \ / ][ |) `/ [_] "!" |
| | #13 (permalink) |
| Team-BHP Support ![]() | Sure will. Linkway Honda skimmed my OHC's brake discs at the last major service in January. However, it must be added, they didn't agree to do so initially. It was only after a little persuasion.
| | #15 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Get a second opinion before you go spending 10k on brake pads.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| Thread Tools | |
Similar Threads | ||||
| Honda City ZX Gxi service experience (TVS Madurai service) | wildsdi5530 | Indian Car Dealerships | 7 | 11th November 2009 01:15 |
| Shocking Diagnosis By Tata Service Station | khadoos baby | Technical Stuff | 23 | 17th December 2007 17:38 |
| Ichibaan Honda Service | manson | The Indian Car Scene | 10 | 16th June 2007 13:13 |
| alternate service points for HONDA | narayan | Indian Car Dealerships | 4 | 20th September 2006 21:30 |
| SHOCKING!! NHC crashes during routine service. | Shan2nu | The Indian Car Scene | 47 | 28th December 2005 22:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
