Go Back   Team-BHP > BHP India > Team-BHP Reviews > Indian Car Dealerships
View Poll Results: Is Maruti Service and Spares getting costlier?
Yes 368 84.40%
No 68 15.60%
Voters: 436. You may not vote on this poll
Old 18th December 2013, 11:44   #316
Gansan's Avatar
Thanked: 887 Times
Default Re: Maruti Service is cheap - A myth!
Originally Posted by hothatchaway View Post
When you say brake overhaul does it mean replacement of the master/slave cylinder?
No. They just clean and grease the calipers and drums. And bleed the brakes and fill new brake fluid, the cost of which is charged separately.
Old 18th December 2013, 11:47   #317
Thanked: 13,410 Times
Thanks, when you say fuel injector cleaning is not required is it one of those things I should keep out of the job card at the 20k service? (I have a Alto k10 vxi)
I have never felt any change in the drive after the fuel injector cleaning and I don't believe MASS will do such things on cars when they have so many customers and are super busy.
Keep the cleaning out of the job card.
Also, pardon my ignorance, in addition to replacing the brake fluid, does 'brake bleeding' mean draining the any remaining fluid from the entire braking system itself?
Brake bleeding is flushing the old oil from the reservoir till the rotor. It removes the old oil and gets the new oil in the whole line and gets rid of air bubbles if any.
I feel it is more of inspection, lubrication and adjustment. If there is a problem only then parts are replaced else it is inspected and lubricated.
Anurag.
Old 18th December 2013, 11:55   #318
Gansan's Avatar
Thanked: 887 Times
Surprisingly, they have never suggested injector cleaning for me so far. They do suggest engine flushing and switch to synthetic oil, but I am not biting! I always write "No oil additives" in bold letters on the job card before it is even suggested!
Old 18th December 2013, 12:34   #319
audioholic's Avatar
Thanked: 5,478 Times
Hi
Just to be clear, is the INR 2500 just the labour charge for the 20k service?
No. Labour for service at 20k is Rs 1200 and some tax. Not a penny more than that
Of course one has to additionally pay for all consumables like engine oil, coolant,transmission oil, brake oil all of which are additional replacements at 20k
If thats the case then the overall bill for a alto/waggie at 20k service should be about 4.5k.
Yes. Consumables are obviously extra. Oil + Oil filter + Gear oil + coolant + brake fluid and air filter are charged extra
Yes. The overall bill must be around 5k for a major service and less than 3k for a 10k service. If anything more than that, you are either ripped or you opted for extras.
Originally Posted by Gansan View Post
This is what I paid at MSM for the 48 month service last June:
Spark plug NGK Rs 327.50
Air Cleaner element Rs 170.00
Oil filter Rs 78.00
Brake fluid Rs 262.00
Coolant Rs 410.00
Gear oil (Shell) Rs 691.00
Misc Rs 151.00
Paid service Rs 1220.00
Brake overhaul Rs 800.00
Electrical check-up Rs 200.00
Interior cleaning (optional) Rs 750.00
VAT and Service tax Rs 669.50
Total at MSM Rs 5729.00
Shel HX-7 (provided by me) Rs 1325.00
Grand total Rs 7054.00
Thats where you were ripped of cash. So they charged 1200 rupees extra and 750 was your opted extra. Hence if we subtract them the bill will come to a bit more than 5k. This is my service breakup:
Gasket - 3.49
Element, Air cleaner - 152
Filter assy, Oil - 78.6
Distilled water - 69.88
Coolant - 205
Brake fluid - 262
Screen wash conc. - 65.5
MGO - 5w30(3L) - 815
Labour:
Paid service(20/60/100K) - 1220
Caliper pin greasing - 275
Brake bleeding - 205
(will be refunded shortly )
Total - Parts - 1653, Labour - 1700-(205+275)
Net bill amount - Rs 3803(Will be refunded 480 so make it Rs. 3323)
If I included gear oil, it would have been Rs 3323+ 700 = Rs. 4000 odd.
Maruti owners booklet does not mention anything called as injector cleaning in their periodic maintenance chart. Neither is Throttle body cleaning, Decarbonisation etc.
The above tasks are to be done by service technicians ONLY when a specific problem is reported by customer. They have issued service bulletins to indicate when this has to be done.
NONE of these are a part of a periodic maintenance schedule.
audioholic is offline   Reply With Quote
Old 18th December 2013, 13:33   #320
hothatchaway's Avatar
Thanked: 542 Times
Gasket - 3.49
Coolant - 205
Brake fluid - 262
Labour:
err..shouldnt the net bill be 2873 after the 475 refund? There I just saved you a cool 450 bucks
But seriously thanks for the information. My key takeaways for my next 20k service are, brakes cleaning/bleeding/brushing whatever it is, to be included in the 1220 labour charge
Mention very clearly no additives, no TB cleaning, no injector cleaning just follow the bible oops manual!
hothatchaway is offline   Reply With Quote
Old 18th December 2013, 14:55   #321
audioholic's Avatar
Tax is included in the last part. Hence, add some 14.5% average tax to 2873 and you will get 3300. Just follow manual and put it against the SAs face.
Old 19th December 2013, 09:51   #322
Kaumad's Avatar
Thanked: 152 Times
Maruti service and maintenance is definitely cheap - surely not a myth!!
I have personally owned and driven 4 Marutis - Omni, Zen MT, [old] Zen AT and [current] SX4. I have never faced any maintenance issue with any of these vehicles.
The trick? - pro-active maintenence and not taking it to MASS, unless absolutely necessary [especially insurance related work].
When I say pro-active maintenance, I am not talking getting under the car and servicing it yourself. Just simple stuff like regular oil changes and consumable replacements [like, brake pads, rubber belts and so on].
I have always made it a point to take the car to a competent independant garage for maintenance.
My current SX4 has done about 79k kms in about 5.5 years and apart from front calipers change, I have not spent any big money on mechanicals. Well, in another thread I have mentioned about a recent accident but thats a different story - the repairs were cosmetic only.
Even after 79k kms, I have absolutely no complaints from the car, does not rattle one bit, returns wonderful f.e. and is a pleasure to drive.
Again, the trick - find a competent independant garage. I cannot think of any other single biggest reason!!
Kaumad is offline   (1) Thanks Reply With Quote
Old 19th December 2013, 10:05   #323
Gansan's Avatar
Thanked: 887 Times
Can you share the name and location of this garage?
Old 19th December 2013, 10:41   #324
Kaumad's Avatar
Thanked: 152 Times
Sure, here you go!
http://www.team-bhp.com/forum/chenna...e-chennai.html (Car repairs & maintenance : Ignite Garage (Chennai))
Kaumad is offline   Reply With Quote
Old 19th December 2013, 12:33   #325
Gansan's Avatar
Thanked: 887 Times
^^Ah, I didn't realize it was that one. From what I have seen in the mentioned thread, it seems to be as pricey as MSM, but not as equipped.
Old 19th December 2013, 13:28   #326
Kaumad's Avatar
Thanked: 152 Times
I am not sure I understand what you mean by "equipped" ?!
Apart from not having a dedicated paint booth, I find Ignite much better equipped [diagnostic capabilities, technical understanding, reliability and most importantly trust-worthiness] to address and solve issues than any ASS I have seen.
Old 19th December 2013, 15:21   #327
Sridhar K's Avatar
Thanked: 192 Times
Got my oil, oil filter and air filter changed at Ignite today for my swift zdi. Here is the cost breakup. I am planning to do my 30k.40k.sservices at MSM to keep my warranty and the intermediate service at Ignite.
Was offered a choice of Shell Helix Ultra, Shell HX6 or Shell HX 7, Mobil delvac mx, delvac 1, mobil1
Shell HX7 -3.5 litres -1325
Oil filter. - - 435
AIR FILTER. - 309
Consumables. - 366
Fog lamp bulb. - 550
Labor. - 600
Service tax on labor. - 74.6
Total. - 3660
Sridhar K is offline   Reply With Quote
Old 19th December 2013, 15:30   #328
Gansan's Avatar
Thanked: 887 Times
^^ To keep the warranty intact, the MASS will have to do the oil change and record it. Is this oil change an additional one, in between the annual changes at MASS?
Old 19th December 2013, 18:48   #329
Sridhar K's Avatar
Thanked: 192 Times
^^Yes. It is an additional oil change @ 5000km in between two scheduled service.
Sridhar K is offline   (1) Thanks Reply With Quote
Old 19th December 2013, 19:30   #330
Thanked: 41 Times
Oil filter. - - 435
AIR FILTER. - 309
Hope they have not overfilled you with 3.5 ltrs actually. I believe the right dose is 3.1 for the DDIS (with filter). If overfilled, pls get it drained immediately.
Also, oil & air filter rate little higher than normal ?
Adi22 is offline   Reply With Quote
Maruti Service vs Hyundai Service - Which one is cheap? Gangsta Indian Car Dealerships 23 13th September 2015 21:14
Going cheap, the Maruti way : Comparing the Maruti Alto versions jinojohnt The Indian Car Scene 93 17th December 2014 00:58
CNG savings, a MYTH??? yuv Modifications & Accessories 21 25th December 2007 21:08
LPG savings, a MYTH? yuv Modifications & Accessories 15 21st August 2007 17:24
Ferrari Challenge - New Concepts of the Myth salil_kulkarni The International Automotive Scene 4 19th November 2005 12:04
