Go Back   Team-BHP > BHP India > Team-BHP Reviews > Indian Car Dealerships
View Poll Results: Is Maruti Service and Spares getting costlier?
Yes 377 84.53%
No 69 15.47%
Voters: 446. You may not vote on this poll
Old 19th October 2015, 22:58   #556
Thanked: 14,607 Times
Default Re: Maruti Service is cheap - A myth!
They were telling that the entire dash needs to be taken out to access the blower.
However at the MASS which I visit, they quoted Rs. 100 as the labour job and no dismantling of dash.
Is this 'blower' that you are referring to, is the A/C blower?
If yes, then isn't located behind the glove box? I thought that is a standard position for most cars!
a4anurag is online now   Reply With Quote
Old 19th October 2015, 23:05   #557
Leoshashi's Avatar
Thanked: 14,939 Times
Yes Sir, it is the A/C blower which I am referring to, and it wasn't located under the glovebox. It was accessed from the driver's side footwell, by removing the clutch pedal. This isn't the case with other cars like Wagon-R and Swift which have their blower below the glovebox.
Shashi
Edit- Please have a look at the links below about the strange location of Ritz's blower
1. http://www.team-bhp.com/forum/offici...ml#post3033547
2. http://www.team-bhp.com/forum/techni...ml#post3137106 (Odd sound from Air-con vents)
Leoshashi is offline   (6) Thanks Reply With Quote
Old 20th October 2015, 15:57   #558
condor's Avatar
Thanked: 4,904 Times
This rubber cap is from the head-lamp of my A-Star. Is this common to other Maruti models that use a H4 bulb ?
I am searching for a pair of these. The MASS guys told me that this is not available separately.
Old 20th October 2015, 16:25   #559
paragsachania's Avatar
Thanked: 12,356 Times
Attachment 1429527
From the size of it, I am more than sure its common across most of the Models with H4 Set-up.
I have done DIYs in SX4, WagonR and Swift and by looks of it, I can tell that this part/cap will be common across the models.
Let me see if I can get a part number for this. Wondering why anyone would not sell this separately. You cant spend on a whole headlight unit just for the rubber cap.
Can you call up MGP Stores and enquire?
ESSARR AUTOMOTIVES
Type :MGP Retail Outlet
111/1,
HOSUR MAIN ROAD,
Bangalore,KARNATAKA
Ph:08041108413
NEMA AUTO SPARES
59, St. Johns Church Road,
Cleveland Town,
Bangalore,KARNATAKA
Ph:08042032868
NEMA AUTO SPARES
Type :MGP Distributor
78, 5th Cross, SSI Area,
5th Block, Rajaji Nagar,
Bangalore,KARNATAKA
Ph:08023101014
Popular Auto Dealers Pvt. Ltd.
No 40-41, Manjunatha Layout,
Dental College Road, Outer Ring Road,
Bangalore,KARNATAKA
Ph:08040980501
Essarr Automotive
No. 19/1-2, 1st Floor,,
H. Siddaiah Road,,
Bangalore,KARNATAKA
Ph:08022110965
Nema Auto Spares
No.8, Hosur Bye Pass Road, Near Tata Steel Yard,,
Doorvaninagar Post, Vijinapura Taluk,,
Bangalore,KARNATAKA
Ph:08032400428
The List is not updated on the site but there is a branch of ESSAR near KR Road which should work closer for you.
Even enquiring at one of the places, you will know if anyone else has stock as its a single database they will all refer to and will be able to tell you who else in Bangalore have it if not them.
paragsachania is online now   (2) Thanks Reply With Quote
Old 20th October 2015, 16:35   #560
condor's Avatar
Parag, can you check your Wagon-R ?
this is the number on the piece: 99226-80008
Will check at the shops. For such small items, easier at the shop.
Me thinks that this is not a regular moving item, hence may not be available easily. Just like many other small parts that dont fail / break / wear-out regularly.
condor is offline   (1) Thanks Reply With Quote
Old 20th October 2015, 16:40   #561
Sure, Let me go home, pull out the cover, take a pic and share. I am more than sure that its the same part. Would take some time as I am here in EC while the WagonR is on the other end .
And yes, you are right - not a fast moving part. I haven't replaced this in my WagonR since past 8+ years and the rubber hasn't shown any signs of cracks or wear.
paragsachania is online now   Reply With Quote
Old 20th October 2015, 16:47   #562
invincible7's Avatar
Thanked: 154 Times
Having owned a Swift for past 6 years and covering 1 Lac kms, and getting it serviced regularly from authorized service centers, I can say that the Maruti Authorized Service Centers are expensive when it comes to maintaining ones car in comparison to a competent independent workshop. The problem is getting a good independent workshop, workaround to this is - get to know ones car better and the good thing is that the most of the genuine parts are easily procurable from independent shops.
invincible7 is offline   Reply With Quote
Old 20th October 2015, 17:57   #563
Checked in my Swift and the part number is 1647-06-00.
Here is a picture:
Thought it was common in all H4 equipped cars.
a4anurag is online now   (1) Thanks Reply With Quote
Old 20th October 2015, 18:28   #564
condor's Avatar
Anurag, thanks ! Looks pretty much the same. This is not on all H4-based lamps, but looks more a Maruti part.
Old 20th October 2015, 21:23   #565
And here's from Ertiga and WagonR. (I forgot which one belongs to Ertiga or WagonR ☺)
Like I was mentioning earlier, no change.
Rest assured, you can pick this for any Model and this will work for your A-Star which has a H4 Set up too.
Old 21st October 2015, 07:16   #566
condor's Avatar
Parag, thank you ! That really makes things simpler. While I had suspected this part to be common for the H4 based lamps, you (and Anurag too) helped to dispel any doubts.
Btw, did you put the correct one back to each of the cars ?
Old 21st October 2015, 09:42   #567
LOL, actually I don't know cos I washed both before clicking the pic as there was dust on it but did remember one had N2 and other N6 in it and by the end of it, I forgot which one belonged to WagonR or Ertiga.
Both fit perfectly well back into the respective cars and it was also difficult for me to check from wear and tear as to which one looked new vs old.
At least this confirms that the part is indeed common. Will update you on what we discussed yesterday over tge text mesaage after I get leads today.
paragsachania is online now   (1) Thanks Reply With Quote
Old 22nd October 2015, 07:31   #568
audioholic's Avatar
Thanked: 6,136 Times
It will be same for at least the currently selling Marutis and most of the clear lens versions of headlamp. The cover is meant for the bulb mounting area and the locking tabs. Since they are common for H4, there wont be any change in the rubber seal except maybe for very minor revisions related to some extra tab here and there or maybe the material.
It will be a tough time to find this though. But the question I have is why it needs to be changed?
audioholic is online now   Reply With Quote
Old 22nd October 2015, 08:25   #569
I know the reason why the cover is needed. Remember we discussed few days back how it is different in few other brands that necessitates cutting of this cover in case you install a kit? Hence, even before I opened I knew it would be same for H4 Set up.
In a way, this cover prevents water enetering the internal area which otherwise has the Bulb holder and the tab and can easily be vulnerable to invite water inside either during wash of very heavy rains when water tries to enter engine bay area from underneath.
Old 13th December 2015, 11:32   #570
Thanked: 385 Times
Guys, quick help.
I have given my car to Bimal Auto for servicing for low AC cooling and hard clutch with some shuddering in traffic driving
They have quoted
8000 for Clutch Overhaul and
4800 for AC servicing
900 for Suspension Bushes Change
900 for Brake Servicing
Plus 1500 odd for normal servicing
Is the clutch diagnosis correct?? Are the charges fair??
2000rpm is online now   Reply With Quote
Maruti Service vs Hyundai Service - Which one is cheap? Gangsta Indian Car Dealerships 23 13th September 2015 21:14
Going cheap, the Maruti way : Comparing the Maruti Alto versions jinojohnt The Indian Car Scene 93 17th December 2014 00:58
CNG savings, a MYTH??? yuv Modifications & Accessories 21 25th December 2007 21:08
LPG savings, a MYTH? yuv Modifications & Accessories 15 21st August 2007 17:24
Ferrari Challenge - New Concepts of the Myth salil_kulkarni The International Automotive Scene 4 19th November 2005 12:04
