Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 28th October 2011, 12:40   #31
Thanked: 102 Times
Default Re: How Indian car manufacturers are profiting by reducing weight of the vehicles
Originally Posted by sidindica View Post
I was shocked to see the alto's brochure quoted kerb weight of 705 kg for the 800 cc version. Thats about light as the omni. The k10 weighs at 760 kg, whereas the F8D had about similar weight 4-5 years ago.safety? care a damn.
Rightly pointed out. As long as the law requiring an feature / safety arrangement is made mandatory, no one cares to add them or provide them.
ABS in trucks was introduced only when law enforcing their mandatory usage came.
rajess_in is offline   Reply With Quote
Old 28th October 2011, 12:46   #32
Thanked: 23 Times
Originally Posted by rajess_in View Post
Kindly note that all steels weigh the same as their density is same. What really matters is their tensile strength (at which they break / failure starts) or rather their Yeild Strength (condition at which they permanently deform) will vary depedning on their type.
For the same load, performance, life, durability and strength normal steels will be much thicker compared to their High Strength counterparts. This is the basis for the weight difference between them.
By using this type of steel, the manufacturer (in this case Ford) would save a lot of metal to give the same amount of performance, safety, durabillity. since Boron steel, as rightly pointed by you has more tensile strength. In fact it can be made into one of the toughest steel sheet by employing the Hot Stamping process.
But at the same time the Boron steel costs a real bomb compared to the normal steels. Hence the high pricing of the car.
But IMHO the car is over priced a bit compared to what it actually should.
What parts do you think ford would have used this material in the car. Am sure they wouldnt have used it extensively for the car. Am just curious to know which parts would really matter for the high tensile strength to matter.
muni is offline   Reply With Quote
Old 28th October 2011, 13:24   #33
Gansan's Avatar
Thanked: 901 Times
That said, assuming MUL produces 1 million cars, a reduction of 1 gram weight is reduction of 1,000,000 g or 1,000kg or 1 ton. Now what metal costs 137 crores/ton (= 13L/kg or 13,000/10g) that is nearly the price of gold.
Just the right time to sell my 600+kg Alto K10 and get at least 100 crores!
I think their drive was to reduce 1 gram per component supplied by vendors.
Old 28th October 2011, 14:04   #34
Thanked: 102 Times
I have not been part of their team to give the necessary details.
Refer the below pictures for some idea of about where these are used. The second picture is that of the Fiesta Europe. Hope this explains your query.
Last edited by rajess_in : 28th October 2011 at 14:08. Reason: Left out Detail about the Fiesta
rajess_in is offline   (1) Thanks Reply With Quote
Old 28th October 2011, 14:13   #35
Thanked: 23 Times
Thanks. Looks like these play an extensive role in absorbing the energy during a impact/collision and also provide structural rigidity.
Old 28th October 2011, 15:24   #36
dot
dot's Avatar
Thanked: 714 Times
Originally Posted by Ascari View Post
For example BMW uses lighter aluminium for the fendor,bonnet and the boot lid.They are now using high strength steel in key areas.
Not just high quality metal but they (BMW and others) are also using composite structural parts which have higher strength to weight values than conventional metal.
dot is offline   Reply With Quote
Old 28th October 2011, 17:56   #37
vinya_jag's Avatar
Thanked: 172 Times
Reducing weight was done a long way as a concept.
But the sad part is that none of those technologies came into any of our cars here. Thanks to low margins.
The usual aluminium body frame, magnesium alloys are not even an option on our cars here. They cost a whole lot which the resulting fuel efficiency will never even out.
A simple aluminium bodied car might even cost a lakh more than a steel built car, and if it reduces the weight by 100 Kilos, and the fuel efficiency improves by say 2 Kmpl, it still would not make sense for an average buyer to afford the car.
Carbon fiber body parts and Kevlar fuel tanks will not even make it into India if this is the case.
Here was a concept done some 10 years back (Which I loved), and had a lot of common sense ideas that could have made it into our cars, but yes, the margins again :(
Daewoo Mirae - Interior | ConceptCar
For now atleast, we are a volume driven, low margin market, which will see systems designed to solve a very different problem making into our cars. Hope there will be a shift
vinya_jag is offline   Reply With Quote
Old 28th October 2011, 19:12   #38
Thanked: 733 Times
So, can you then explain why the same car weighs less in India? Is it because the Indian car is safer and uses high tensile steel while the Australian/Jap car uses normal steel? Really?
Lalvaz is offline   Reply With Quote
Old 28th October 2011, 19:35   #39
Ascari's Avatar
Thanked: 64 Times
@Lalvaz It maybe lighter due to lesser equipment levels.Lesser number of airbags,lesser equipment,trim,engine model etc,you never know!
Or maybe they reduce the weight to earn the respect of Indian consumers who are only after what you call it "FUEL EFFICIENCY"
Ascari is offline   Reply With Quote
Old 29th October 2011, 07:45   #40
ukderebail's Avatar
Thanked: 39 Times
Originally Posted by aaren View Post
Sorry for being OT but this certainly would have been a scary experience. Hope nothing serious happened.
Having said that did you report this to Maruti and if yes, what was their reply?
Well i reported the first instance of skidding while going to tirupathi to Maruti guys. The concerned showed me a demo video of ABS system, which virtually shows the skidding to the right, whereas my vehicle veered towards left, which was not comprehended by him, by logical deduction it had shifted gravitationally towards left because two passengers were seated on the left, whereas demo had only driver on the right. But second one i did not approach them for a solid reason. I personally feel all scientific theories may not apply to Indian road condition which is already filled with slippery gravel or sand and further with light tyres brakes do have limitation in rainy season particularly.
ukderebail is offline   Reply With Quote
Old 29th October 2011, 08:04   #41
Thanked: 284 Times
Originally Posted by ukderebail View Post
With tubeless tyres unless one has ABS system one is bound to meet with accidents.
What's the connection between tubeless tyres & accidents?
carboy is online now   (1) Thanks Reply With Quote
Old 29th October 2011, 08:16   #42
ukderebail's Avatar
Thanked: 39 Times
If you compare the thread on tubeless tyres, its thickness is much lesser than the regular rubber tyres, the feel of the tubeless tyres is more of plastic compound according to me. Finally the weight per se of tubeless is much lesser. It naturally has effect on the braking power.
Old 29th October 2011, 10:45   #43
HotChillyPepper's Avatar
Thanked: 215 Times
Actually lighter vehicle will stop faster!
Well said. Mass plays an important role in inertia. As the mass goes up the inertia too.
HotChillyPepper is offline   Reply With Quote
Old 29th October 2011, 14:31   #44
AbhiJ's Avatar
Thanked: 494 Times
You are wrong on so many levels .... Let me start
1) The tread depth on a tyre is not based on the fact whether its tube or non tube type. It is simply design. The Michelin XM1+ are tubeless and have very deep tread depth. Also, tread is generally a decent wear indicator. It is not an absolute measure of grip / braking. On a dry surface, slick tyres actually perform better !
2) Regardless of what you feel, there is no plastic in the tyre compound - Tubed or Tubeless. At least not yet.
The feel might differ because of cheapening (reducing rubber %) but that is irrespective of whether a tyre is tubeless / tubed. In fact the inner most layer of the tube less tyre is usually butyle - A Synthetic Rubber.
3) Weight of the car / tyre does not help in braking. k.e. = 1/2 x m x v^2. It is in fact inverse. The more the weight, the more kinetic energy it has and hence requires more stopping.
4) Tyre companies are spending millions to actually further reduce weight of the tyre. Reduced weight = better. Period.
AbhiJ is online now   (1) Thanks Reply With Quote
Old 29th October 2011, 15:07   #45
Thanked: 1,047 Times
Tubeless tyres are heavier than tubed tyres because a layer of Butyle rubber is added to the inner part to retain air. Other wise both the tyres have same design. With tube the tubed tyre will be slightly heavier (to the extent of the weight of tube less butyle coating).
What you may be referring to is the older cross ply tyres, which had thicker bodies and heavier weight. This was necessitated by the design which flexed less hence needed more rubber.
Radial tyres due to their superior thermal characteristics are designed with less rubber for the same strength and speed rating, as they dissipate heat faster than bias (cross) ply tyres. So they last longer on highways, but may get shredded on rough roads and tracks faster.
Each part of the tyre - tread, bead, sidewall ... (there are more than 50 different separate part in a tyre), have different formulation. They are manufactured separately and assembled, primarily in a "tyre building machine", to give us the finished Tyre. For the same duty and speed the tyre formulation is same, so there is no question of "plastic" fee, as plastic per say is not used. What you may perceive, is that some formulations may use more synthetic rubber, which has that slick feel, but that comes in expensive tyres as synthetic rubber is way too expensive.
Aroy is offline   (1) Thanks Reply With Quote
Protecting highways using toll : How weight-based toll works for large vehicles sudev Commercial Vehicles 26 3rd November 2015 16:34
Indian Lube Industry - Modern Engines Reducing Oil Consumption smartcat Technical Stuff 9 21st March 2012 22:32
Reducing in car noise varadha_r Technical Stuff 35 31st May 2010 17:00
kerb weight of vehicles - swift vs palio ece2k2 The Indian Car Scene 5 8th June 2008 23:25
