Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 7th March 2006, 12:41   #16
speedsatya's Avatar
Thanked: 710 Times
i havent driven 1.6 optra ..but from what we read 7-8 kpl is too less even for a new car ...change the petrol station and see ...still if teh problem persists take it to a GM workshop as its still unders warranty ...
Hope you are driving properly
speedsatya is offline   Reply With Quote
Old 7th March 2006, 13:14   #17
jkdas's Avatar
Thanked: 1,435 Times
But according to Rudra, its pulls fabulously even in 5th gear; I mean, you dont need to shift down now and then.
Old 7th March 2006, 13:16   #18
BUSA's Avatar
Wink
Yes there is oogles of torque but then when you are in Boy Racer mode what to do??
Old 7th March 2006, 15:38   #19
the way i measure my fe is
i wait till low fuel indicator is constant and then i fill fuel
surprisingly, now im getting 10+! (checked with 10 litres in tank). there is some problem with the fuel indicator that shows slightly wrong values sometimes. this made me think that my fe is 7-8.
i hope im correct. fe of 10 is excellent for the royale. it has everything and the ride is very smooth
xtr21 is offline   Reply With Quote
Old 7th March 2006, 15:41   #20
Thanked: 11 Times
10? Whoa! That's pretty good, hope mine starts giving the same. JK, it's safe to book your Optra now!
Boom Shiva is offline   Reply With Quote
Old 7th March 2006, 15:42   #21
Thank you for clarifying.
What has been mentioned in post #4 in this thread is the best way to measure FE.
hrag is offline   Reply With Quote
Old 7th March 2006, 15:47   #22
jkdas's Avatar
haha. The point is he made a mistake in his calculation and led us to think bad abt Optra. We all check mileage by trying brim to brim fill-up and checks.
Old 7th March 2006, 16:13   #23
ya..
i hope im correct abt 10.. ill check up next month by full tank-half tank-full method.
the optra is a perfect car if it gives 9-10
Old 7th March 2006, 16:49   #24
BUSA's Avatar
Wink
Originally Posted by tsreekaranrao
The best way to measure FE is to fill the tank till the auto cut off from the pump, reset your trip meter to zero or note the odo reading. Drive normally till the tank is only half full (Better if it is almost at the Empty mark).Fill again preferably from the same pump till auto cut off and divide the total no. of kms travelled with the fuel put in the 2nd time.
HOPE YOU UNDERSTAND THIS AND IT HELPS YOU !!!!!
Am aware of this but in the Optra the auto cuts out 10L before always.
Old 7th March 2006, 16:59   #25
Thanked: 11 Times
I've had the same experience with the cut off...there's always space for at least 10 litres more. Also, for some reason I keep filling more than 60 litres, even though the manual says the tank capacity is 60 litres, and I don't wait till the last minute to fill up (I usually fill before the warning light shows).
Old 7th March 2006, 18:09   #26
BUSA's Avatar
Question
Your petrol pump is goofing. It cant take more then 60 and when warnings not on how can you fill in 60 Litres when reserve itself is 5L??
Old 7th March 2006, 18:19   #27
aseem's Avatar
Thanked: 418 Times
If you want FE than you have bought the wrong car. You should have considered Maruti Baleno or City for FE, as Accent Petrol, Oprta, Ikon, Fusion, etc are not famous or known for their FE. You should not expect more than 10.
aseem is offline   Reply With Quote
Old 7th March 2006, 18:40   #28
supremeBaleno's Avatar
Thanked: 1,676 Times
hi guys
i recently purchased royale.. i measured my fe over the past week
its only 7-8 kmpl! help guys..
hey xtr21, in the 1K kms report of yours on 24Feb06
http://www.team-bhp.com/forum/long-t...tml#post181719
you mention getting an FE of 10-11.
I guess once you use the fulltank-to-fulltank way of measuring FE, it should clear the confusion.
Old 7th March 2006, 18:41   #29
tsreekaranrao's Avatar
I dont think any car would autocut 10L less than the full mark
tsreekaranrao is offline   Reply With Quote
Old 7th March 2006, 20:29   #30
ya buddy... im totally confused as to how much it is. one week i think its 7-8. other week i think its 10+. gotta do full tank method to confirm for sure
The "Low Mileage" Car Thread! How low is your running? saket77 The Indian Car Scene 135 23rd September 2013 22:51
Repeat EXAMM! The ghost of 1st low vs 2nd low descent haunts us again... and how! Tejas@perioimpl 4x4 Excursions 41 23rd September 2010 14:16
Coolant low on new Optra 1.6 with no other symptoms Ravich Technical Stuff 2 29th August 2006 09:22
