Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 7th March 2006, 00:20   #1
Unhappy low FE on optra 1.6! help
hi guys
i recently purchased royale.. i measured my fe over the past week
its only 7-8 kmpl!
help guys..
xtr21 is offline   Reply With Quote
Old 7th March 2006, 00:22   #2
BUSA's Avatar
Just Chill. Run her in and dont expect good FE till Oils change to ELF at 2nd service that is 10K.
Run her in well.
Old 7th March 2006, 09:46   #3
How did you measure your FE?
hrag is offline   Reply With Quote
Old 7th March 2006, 11:55   #4
tsreekaranrao's Avatar
The best way to measure FE is to fill the tank till the auto cut off from the pump, reset your trip meter to zero or note the odo reading. Drive normally till the tank is only half full (Better if it is almost at the Empty mark).Fill again preferably from the same pump till auto cut off and divide the total no. of kms travelled with the fuel put in the 2nd time.
HOPE YOU UNDERSTAND THIS AND IT HELPS YOU !!!!!
tsreekaranrao is offline   Reply With Quote
Old 7th March 2006, 12:05   #5
jkdas's Avatar
Thanked: 1,435 Times
Run her in well.
wait till 10K???
Optra aint know for its mileage. The best teh company claim is 12kmph or so
Old 7th March 2006, 12:08   #6
BUSA's Avatar
Wink
Originally Posted by jkdas
wait till 10K???
The New VGIS will give 11 kmpl and for that the car has to be have an oil change to smoother one.
Old 7th March 2006, 12:16   #7
jkdas's Avatar
phew 11kmpl? and taht too after waiting to run til 10k and then get an syn oil!
i would stay away frm OPtra!
Old 7th March 2006, 12:20   #8
normally_crazy's Avatar
Thanked: 393 Times
JK - you want the car to come out of the show room and start of with a 15 KMPL FE ?
normally_crazy is offline   Reply With Quote
Old 7th March 2006, 12:20   #9
Thanked: 62 Times
phew 11kmpl? and taht too after waiting to run til 10k and then get an syn oil! i would stay away frm OPtra!
Dear Sir, not every car is designed for mileage
RX135 is offline   Reply With Quote
Old 7th March 2006, 12:21   #10
BUSA's Avatar
Wink
Buddy any car unless and until has the oil changed then only returns better FE. Running is till 1000kms and then then first service. Drive the way you like after that but please expect better FE only after 10k. Not only for Optra it stands true for all cars. Because the oil in new cars are hard and it burns very badly and is changed only at 10k for all cars.
Old 7th March 2006, 12:30   #11
Thanked: 11 Times
[SIZE=2]Mine gives pretty much the same average right now , around 7-8ish. The dealer said it should go up to around 9-9.5 in city traffic, after the second service. [/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]Busa, I don't think it can give 11, though if it could, I'd be a happy man. If yours does, then I'd appreciate some tips from you.[/SIZE]
[SIZE=2]JK, I guess Optra's not your cup of tea, but seriously, I don't hold the FE against the car. It's completely worth it.[/SIZE][SIZE=2][/SIZE]
[SIZE=2][/SIZE]
Boom Shiva is offline   Reply With Quote
Old 7th March 2006, 12:31   #12
Thanked: 62 Times
Busa, it has less to do with Oil change than initial high friction and lack of lubrication of the various moving parts.
Old 7th March 2006, 12:38   #13
jkdas's Avatar
thats a point. But cant one change oil at 5k to speeden things up?
Old 7th March 2006, 12:40   #14
BUSA's Avatar
Wink
Originally Posted by Boom Shiva
Mine gives pretty much the same average right now , around 7-8ish. The dealer said it should go up to around 9-9.5 in city traffic, after the second service. Busa, I don't think it can give 11, though if it could, I'd be a happy man. If yours does, then I'd appreciate some tips from you..
Mine gives 7.5 - 8.0 but then its a 1.8 and it doesnot have VGIS and a bit of spirited driving. If you dont pull the car above 2k RPM and dont hit speeds in excess of 80kmph ( which is difficult) then i am sure you will get 11kmpl with ease. People doing that have got 12-13 and some people in the mileage run got even 26kmpl from a Optra.(Time to call the OD GUYS )
Typical Indian psychology..
http://www.team-bhp.com/forum/collec...fficiency.html
Thats happens in Honda Cars and many other comapanies which have service at 5k intervals to make money. Chevvy has service in 10K gaps and not 5k and its same for the Fords as well..
Old 7th March 2006, 12:40   #15
supremeBaleno's Avatar
Thanked: 1,676 Times
Originally Posted by xtr21
hi guys
its only 7-8 kmpl! help guys..
I am not surprised.
A guy in my apartment has an Optra LS (1.6L) and he gets around 8kmpl in city with a/c. One reason for the low FE could be the extra 200 odd kgs in weight (when compared to a Baleno 1.6 having an FE of 12kmpl). Ofcourse, the weight could add to the safety and ride comfort. But for those out there who are conscious about FE, this is not the car.
After running-in and doing a few thousand kms, it could increase a bit, though.
The "Low Mileage" Car Thread! How low is your running? saket77 The Indian Car Scene 135 23rd September 2013 22:51
Repeat EXAMM! The ghost of 1st low vs 2nd low descent haunts us again... and how! Tejas@perioimpl 4x4 Excursions 41 23rd September 2010 14:16
Coolant low on new Optra 1.6 with no other symptoms Ravich Technical Stuff 2 29th August 2006 09:22
