Go Back   Team-BHP > BHP India > The Indian Car Scene
Closed Thread
Old 31st October 2012, 19:13   #106
CARDEEP's Avatar
Thanked: 1,542 Times
Default re: Honda Brio Sedan to be launched in 2013. EDIT : To be called "AMAZE"
Originally Posted by abhi.kedlaya View Post
Stumbled upon this article on the internet courtesy Daily Bhaskar. Hope this is a trustworthy source.
All you need to know about the new Honda Brio Sedan
Some claims from the above article quoted here for a quick look.
  • 3,990mm overall length
  • 2,407mm wheelbase
  • 1,680mm width
  • 1,485mm height
  • Boot space of 420 litres! and
  • Heavier than the Hatch variant by just 26 kgs!
  • 90HP 1.2-litre 4-cylinder petrol engine with CVT automatic transmission
  • 20.4 kmpl mileage. (I doubt even if the Hatch gives this kinda mileage.)
Are the above believable?
Abhi
Yes , this is what I was expecting, though I expect the wheelbase to be same as Jazz ~ 2500mm & a boot of 420L betters the Indigo CS, which has 380L boot. I also expect the Brio CS to be little more heavier than just 26 kg increase in weight.
CARDEEP is offline
Old 31st October 2012, 19:43   #107
Thanked: 550 Times
  • 2,407mm wheelbase
I think its confirmed. Following quote is from a Bangkok Paper:
At a media briefing yesterday in Thailand, Honda engineers said the Brio saloon will have a 3,990mm overall length and 2,407mm wheelbase, longer than the hatchback by 380mm and 62mm accordingly. The 1,680mm width and 1,485mm height are identical.
The additional length was made to accommodate larger, cushier rear seats and a boot measuring 420 litres. As the saloon is 26kg heavier than the hatchback, changes to the suspension had to be made including new coil springs.
The three-box Brio gets the same 90hp 1.2-litre four-cylinder petrol engine and CVT automatic transmission, good for a 20.4kpl average fuel economy.
The new Brio derivative will make its world debut in Thailand next month.
Link:http://www.bangkokpost.com/auto/auto...specs-revealed
sarthakgupta is offline   (2) Thanks
Old 31st October 2012, 20:40   #108
Thanked: 206 Times
Hey Sarthak,
Thanks for sharing.
Same information coming from two different sources is definitely reassuring (assuming daily Bhaskaran guys didn't copy from Bangkok post). Honda seems to have done a wonderful job in liberating more space while staying within the 4m mark. Amazing!
I think Honda has a winner at hand provided it doesn't goof up the pricing.
naut is offline
Old 31st October 2012, 21:24   #109
dZired's Avatar
Thanked: 7,557 Times
Some more spy shots
Honda Brio Sedan to be launched in 2013. EDIT : To be called "AMAZE"-post47470337136001351697541_thumb.jpg
Honda Brio Sedan to be launched in 2013. EDIT : To be called "AMAZE"-post47470439522001351697560_thumb.jpg
Honda Brio Sedan to be launched in 2013. EDIT : To be called "AMAZE"-post47470546039001351697584_thumb.jpg
SOURCE
dZired is offline   (2) Thanks
Old 31st October 2012, 21:36   #110
rajshenoy's Avatar
Thanked: 682 Times
Hey Sarthak,
Thanks for sharing.
I am not sure how the FE figures change for India. if ARAI has different criteria then we might see lower figures for Indian road conditions. But remaining stats look good
rajshenoy is online now   (1) Thanks
Old 31st October 2012, 21:39   #111
swiftnfurious's Avatar
Thanked: 6,569 Times
Adding to the news, IAB says the India spec diesel might be a 1.2L diesel engine. Some how disappointed if this is true.
Other points:
The color of interior trims will be different to differentiate hatch & sedan
The rear suspension slightly stiffened (by beefed up coil springs) to accommodate extra weight (which may have reduced bounciness).
No premium features like ACC or LCD infotainment to keep costs under check.
Sedan slower to hatch by just 0.1s
1.2L india spec diesel with around 75 ps.
swiftnfurious is offline   (1) Thanks
Old 1st November 2012, 02:10   #112
akhil_rpmlover's Avatar
Thanked: 29 Times
Other points:
It was indeed the 1.2L that was in talks earlier on. A 1.5 could have been better. But, this does the job and keeps the costs minimal. However i want to see a 1.5L Diesel on City. Honda will be using the same motor to power Brio, Jazz and City and brio sedan right ? But, if its a 1.2L, then they would do like the SX4, adding a VGT or so for City. But, that is a disappointment indeed.
Sedan is behind hatch by 0.1s is an interesting figure.
akhil_rpmlover is offline
Old 1st November 2012, 10:29   #113
Originally Posted by akhil_rpmlover
It was indeed the 1.2L that was in talks earlier on. A 1.5 could have been better...
The earlier talks were about the 1.2L 3 pot engine doing rounds in test Brio. There were also speculations of a 1.5L diesel for the sedan. The latest (unconfirmed) news is its a 1.2L 4 pot engine.
Old 1st November 2012, 11:26   #114
sgiitk's Avatar
Thanked: 3,855 Times
Infractions: 0/1 (4)
Honda have a 2 litre 4-pot Diesel, so the 1.5 3 potter is derived from that. Also, I find that the Brio Hatch is under 3700 mm long, so there is a margin of 300+mm to stretch and put in the boot and stay under the 4m.
sgiitk is offline
Old 1st November 2012, 22:32   #115
Thanked: 550 Times
Are you sure sir, that it is a 3 potter and not a 4 potter? That would be so un-Hondaish.
AFAIK Honda has a Europe specific 2.2 Liter (and not 2 Liter) 4-potter that does duty in European Civic, Accord and CR-V. The all new 1.6 will go into Civic and 2WD version of 2013 CR-V with 2.2 doing duty on AWD version of 2013 CR-V (Accord is getting axed).
I remember reading that Euro Spec diesels are not suitable for High Sulphur diesel being used in India, so Honda is preparing a new engine from grounds up (not deriving it from Euro engines).
Old 2nd November 2012, 09:48   #116
sgiitk's Avatar
All I will say is that the reported sightings of all Brio Diesel mules have indicated it is a 3-potter.
http://www.team-bhp.com/forum/indian...-video-23.html
sgiitk is offline
Old 2nd November 2012, 11:22   #117
sarathlal's Avatar
Thanked: 2,181 Times
Am afraid its slightly off topic, but;
How easy/practical is it to 'derive' 3 pots from a 4 pots?
More often when discussion about a new 'baby' product coming in for a big manufacturer happens, we often come across this idea, hence the question.
sarathlal is offline
Old 2nd November 2012, 14:06   #118
sgiitk's Avatar
@sarathlal; Quite easy. A lot of the smaller engines today are derived from the fours. Of course the reverse is also done - MS 1161 is a 4/3 of the 798! Essentially needs a revised crankshaft and of course a block. You save on pistons, con-rods, liners, etc.
sgiitk is offline
Old 2nd November 2012, 22:22   #119
Thanked: 48 Times
I'm sure with these specs honda have a winner on hand, provided they price it lower than Swift Dzire for petrol as well as diesel, which isn't difficult since they are already priced lower than swift for petrol hatch by a big margin.
ARAI mileage has to be above 18 for sedan as weight addition is just 26 kg. It will be interesting to know the detailed engine specification for diesel version and also see how honda price it.
rock75 is offline
Old 2nd November 2012, 23:01   #120
suhaas307's Avatar
Thanked: 6,842 Times
Even before the Brio sedan makes its appearance, the Sail sedan will have its way. In fact, with a large boot, spacious interior, great ride quality and a strong engine, the Sail sedan might pose quite a threat to the Brio sedan.
What works against the Brio is the lack of space (in comparison and presumably in the sedan) when pitted again the Sail. The ride too isn't great and even though its decent, the Sail's ride quality is one of its trump-cards.
The Brio has its work cut out. Will its quirky looks and Honda badge draw some customers to their showrooms? I'd like to hope so.
And if they price it too high, it will be licked by the likes of the Sail and the Dzire which is selling like hotcakes either way.
suhaas307 is offline
Closed Thread
*SCOOP* Honda Brio DIESEL caught. EDIT: Only for next-gen Brio in 2017 kpzen The Indian Car Scene 377 6th September 2015 02:55
Automatic: Used Maruti A-Star or new Honda Brio? EDIT: It's a Brio! ashwin489 Hatchbacks 54 10th September 2014 15:25
Honda recalls 31,226 units of Amaze & Brio for brake inspection M35 Technical Stuff 4 7th May 2014 20:09
