Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 12th May 2006, 13:53   #1
Default How do AC's compare
hi how do the Ac's compare for the various cars on the road. Do any of them give good air distribution for the rear seat passengers? This is one of my sore points with petra, which does not give very good cooling for rear seat passengers. Can anything be done about it.
shbhrao is offline   Reply With Quote
Old 12th May 2006, 13:57   #2
venkatrx's Avatar
Baleno has great AC both for front and rear.
in honda city AC ducts are provided near the legrest of the rear seats to improve air supply to the rear.....try if this kind of alteration is possible in your car.
venkatrx is offline   Reply With Quote
Old 12th May 2006, 15:00   #3
yogi1771's Avatar
ford fiesta1.6 ac is great good cooling overall and that too in this summer heat
yogi1771 is offline   Reply With Quote
Old 12th May 2006, 15:16   #4
ksethuram's Avatar
Swift's Ac provides good cooling to the rear seat passengers in Chennai summer without any sun film...
ksethuram is offline   Reply With Quote
Old 12th May 2006, 15:57   #5
greatDrive's Avatar
Can you go to service centre and check if the blower (fan) is working fine.
I also own a petra and I am pretty satisfied with the AC performance. my father who usually sits at rear sometimes ask me to switch off AC or slow down the blower.
greatDrive is offline   Reply With Quote
Old 12th May 2006, 16:02   #6
revharder's Avatar
Thanked: 49 Times
if cooling at front seats is good than the 'throw' of blower has to be checked.
else get whole AC serviced!
revharder is offline   Reply With Quote
Old 12th May 2006, 16:53   #7
http://www.indiacar.com/infobank/aircontest.htm may be a good starting point.
hrag is offline   Reply With Quote
Old 12th May 2006, 16:54   #8
Thanks, if that does the trick I'll be very happy
cheers
Old 12th May 2006, 17:10   #9
namit's Avatar
Thanked: 49 Times
Do you have film or tinted glasses in your Petra ?
Bcoz if you are talking about cooling at the rear in our afternoon summer lot of heat radiates via glasses which can render any A/C ineffective until or unless you have a provision for air ducts at the back too like someone mentioned in the Honda city.
OR other alternative is too keep the blower speed to max for good 5 mins and then lower the fan speed.
I am very happy with my Aveo's A/C cooling in the peak noon summer of Delhi.
Cheers.
namit is offline   Reply With Quote
Old 12th May 2006, 18:20   #10
Thanked: 9 Times
Indica's a/c is pretty good, infact I dont have to put the a/c on speeds more than 1 or 2 ever....Though I am not sure if its great in the rear seat as I never sit there :s
Abhay is offline   Reply With Quote
Old 12th May 2006, 18:34   #11
askulkarni's Avatar
Default Getz and AC
The AC per se in the Getz is satisfactory. Having said that, the complaint is the peppy ness of the car decreases a lot the moment I switch on the AC. Throwing the AC (to off) switch is like giving a nitro boost to the car.
Is this the same behaviour with the others?
askulkarni is offline   Reply With Quote
Old 12th May 2006, 18:48   #12
Use recirculating mode 90% of the times to improve cooling efficiency. On long drives I switch to non-recirculating mode once an hour for about 5 mins and then switch back to recirculating. I always keep the blower speed at 1 or 2.
Remember to switch to fresh air every now and then to avoid breathing stale air.
parijnan is offline   Reply With Quote
Old 12th May 2006, 20:26   #13
DRC
DRC's Avatar
Thanked: 44 Times
Well, Petra's AC is good enough, If you have a problem / dis-satisfaction that it does not cool back seats, follow the suggestions in this thread..
1. Check the blower performance,
2. In summer, you tend to complain because of radiated heat through the wondows, get a good tint films they help a lot to reduce radiation inside..
3. With all this, Petra has a flaw in the AC(blower) by design. The vents are located too low, below the music system, and the hence the throw is more for the front passengers and front passengers will be blocking the air throw for the rear ones. So it does happen, front guys will bew freezing and those in the rear grilling . Try keeping the throw direction upwards, helps sometimes
DRC is offline   Reply With Quote
Old 13th May 2006, 00:06   #14
swale84's Avatar
Yup, makes the zen fel like it has NOS when you switch off the ac.....ok not Nos but a few extra bhp!
swale84 is offline   Reply With Quote
Old 13th May 2006, 00:41   #15
speedbuster's Avatar
this should give a better perspective
speedbuster is offline   Reply With Quote
How do Traffic Police in your city compare ? meerkat Shifting gears 6 20th January 2009 12:50
compare last and this years speedrun timings turbs Indian Motorsport 7 4th May 2006 13:09
