Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 7th June 2006, 23:45   #1
hari_rama's Avatar
Default Swift no more with eps?
HI Bhpians.today was browsing thru od forum & found out this thread.
http://www.overdrive.in/pitstop/viewtopic.php?t=243
Doesn the new swift come with eps anymore?buyers please take a note.anybody test driven the swift with rack & pinion pwer steering??
hari_rama is offline   Reply With Quote
Old 8th June 2006, 13:01   #2
WhiteKnight's Avatar
Thanked: 76 Times
Thats a news...Anone knows more?
Okay, this is total mix up. Rack & Pinion is the underlying steering technology most commonly used. So most of the cars you see has it. In a standard steering system, the user uses his muscle power to turn the steering, which through a rack & pinion, turns the wheels. Powes assited systems just use engine power (Hydraulic Power steering), or an electric motor (EPS) to reduce the user effort in turing the steering. So, having an EPS doesn't change the underlying steering technology, which is mostly rack & pinion. There is another technology called Recirculating Ball steering- don't know who uses it.
I think most of the auto sales people are ill trained about what is there in the car. So this whole story might have been fuelled by one of those sales person answering wrongly to a query.
Any more inputs?
WhiteKnight is offline   Reply With Quote
Old 8th June 2006, 13:05   #3
DCEite's Avatar
Thanked: 598 Times
Maybe they changes from EPS to HPS because the EPS feels too light and being very vague.. (case in point being wagonR and NHC).
DCEite is offline   Reply With Quote
Old 8th June 2006, 13:06   #4
DRC
DRC's Avatar
Thanked: 44 Times
Heavier tata vehicles use re-circulating ball steering, Sumo, Safari?, etc..
If EPS is going out, then what is the PS mechanism, Hydraulic?
DRC is offline   Reply With Quote
Old 8th June 2006, 14:10   #5
jesal's Avatar
sad i liked EPS more on my city than what HPS i have on the accent. its fun really since i do not go fast anymore. in city its a boon. dont know what car companies are thinking most of the times.
jesal is offline   Reply With Quote
Old 8th June 2006, 14:50   #6
himanshugoswami's Avatar
Thanked: 1,061 Times
THis is correct. WHen I went to take the test drive of the swift beofre finalizing on the Palio, the sales rep at Bimal took me on a vxi. I commented to him that the steering felt a little tight for an EPS, unlike the esteem. He told me that the lxi and vxi are now coming with HPS in the interests of costs and only the zxi comes with EPS.
Maybe even teh ZXI is now coming with HPS!
anyways, IMHO, HPS is better than EPS because u still get some amount of feedback in HPS. EPS seems totally disconnected from the road and while it may be good for city commute, it can actually be dangerous in high speeds( unless of course it is speed sensitive)
himanshugoswami is offline   Reply With Quote
Old 8th June 2006, 15:21   #7
theMAG's Avatar
Thanked: 1,542 Times
Default EPS not absent
I bought my Swift Vxi recently and lemme assure you EPS is still present - the EPS lamp glows in the instrument panel when I turn on the ignition. Also judging from the way the steering behaves, I can yet state that its EPS at work.
Also WhiteKnight is right - saying EPS and Rack&Pinion are counterparts is like saying a car can run only on rims without any tyres.
himanshugoswami,
What the sales rep told you is a complete fabrication - you should have sent this feedback to Maruti directly and watched the sales rep call you and correct himself! Almost all cars in India these days come with EPS - not HPS; even the Indica for that matter.
HPS is only used these days in large commercial vehicles like trucks and buses as EPS would be totally ineffective there.
Old 8th June 2006, 15:56   #8
neoonwheels's Avatar
Thanked: 612 Times
I was under impression that at high speeds (Say above 60-80 KMPH) the power steering gets cut off for safety... Make me correct if I am wrong.
neoonwheels is offline   Reply With Quote
Old 8th June 2006, 18:57   #9
SLK
SLK's Avatar
Thanked: 190 Times
Yes the power of the EPS system is reduced considerably but its not completely cut off....
Try it... go to 100 switch off engine.... steering would feel different... (don't try it at home )
SLK is offline   Reply With Quote
Old 8th June 2006, 19:33   #10
hari_rama's Avatar
I meant the same thing. hydraulic power assisted steering as in baleno.
But 1 thing the light steering of swift was a good feature as it tightens up necessarily with speeds
Old 8th June 2006, 19:56   #11
V-16's Avatar
Thanked: 853 Times
Hey Hari_rama, thats news to me!!
V-16 is offline   Reply With Quote
Old 8th June 2006, 23:14   #12
hellspawn's Avatar
Infractions: 0/1 (10)
cars with eps are usually lighter and stressfree to drive in the city though feedback from the wheels to the driver is less than the hps.the ikon and palio/siena/petra still use the hps which makes them better handlers and more communicative at high speeds.even the nhc has eps compared to the hps on the older city...and u know hich one is preferred for sheer handling and driving potential.plz correct me if im wrong anywhere.
hellspawn is offline   Reply With Quote
Old 9th June 2006, 10:19   #13
Thanked: 76 Times
Thank you for the info, I was not aware of any cars using Recirculating ***** steering. I think they have a slightly vague feel compared to rack & Pinion ones
I got that buddy. I was refering to the link you have given were the guy was saying "The car instead comes with Rack & Pinion type of steering wheel. The technolgy is very old & puts constant pressure on the engine. I am not sure why them have made such a decision. But I am disappointed"
This is what set me write the explanation
Old 9th June 2006, 12:16   #14
Surprise's Avatar
Thanked: 238 Times
I like the EPS in my Swift very much. Its really enjoyable taking it through sharp turns at slow speeds. Hope they will not do any changes with it for the new cars
Surprise is offline   Reply With Quote
Old 13th June 2006, 09:02   #15
tabrez02's Avatar
Yesterday i took the delivery of the Brand New Swift vxi abs. The EPS is very much present in the car, even in the dash the eps light glows when the ignition is on and under the hood also we can see the eps console.
tabrez02 is offline   Reply With Quote
More Swift - More Fun - My White Swift VDi man_xzone Test-Drives & Initial Ownership Reports 15 12th October 2011 12:03
Retrofitting an EPS viper Technical Stuff 13 10th April 2008 08:54
EPS and Rear Wiper for M800 sureshshanmugam Modifications & Accessories 9 1st October 2007 17:38
EPS on M800 sureshshanmugam Technical Stuff 5 27th December 2006 23:26
No power assistance from EPS at high speeds - Why ? mithun Technical Stuff 15 25th August 2006 23:00
