Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 13th June 2014, 17:50   #121
Thanked: 54 Times
I feel the problems are over amplified. The most critical failure that customer experienced was failing of lights and the second is bumper. I can't believe that bumper just fell off. I have an D segment car and because of the overhang it is easy to bruise the bumper from bottom which gets it off its clips. That's the only scenario that can lead to bumper falling. Lights, well they shouldn't have failed even at any level of abuse. Well I still find it less crucifying than stories from an other European OEM.
vishnugs is offline   (1) Thanks Reply With Quote
Old 14th June 2014, 00:11   #122
Thanked: 436 Times
Default Re: JLR India PR disaster! Salman Khan tweets his frustration over Range Rover breakd
'I have taken it to many authorised dealers and garages but it has not helped me. It has so many problems I can't even list them all.'
The owner has so many problems that he didn't list them out. Apart from light failure and bumper falling off, there are many other problems with the car which he has not shared with the news reporter.
I think this is a wake up call for JLR and be more customer centric.
JoseVijay is offline   (1) Thanks Reply With Quote
Old 1st October 2015, 00:11   #123
johannskaria's Avatar
Thanked: 1,578 Times
Default Re: JLR India PR disaster! Salman Khan tweets his frustration over Range Rover breakdown
Guys , you might want to see this!
Do wait for his recommendation in the end!
johannskaria is offline   Reply With Quote
Old 17th July 2017, 12:35   #124
Thanked: 20 Times
Been using an Evoque for a while now.
RR recommends to change the brake-pads every 25000 kms. However, it totally depends on how you drive and how strongly you apply brakes.
Since the one we've been using, usually runs only for 40-45 kms daily, with average braking. I can somehow be convinced to change the brake-pads as RR recommends, because no one has that much time to argue about if the discs can be used for another few thousand kms.
But, most importantly, when does one have to change the discs along with the brake pads? I may not be perfect in judging the condition of the discs, but is it mandatory to change the discs along with the brake-pads when the car has done only 65000 kms. The service personnel are after us to change the discs. The discs of our Evoque look absolutely fine, even when compared to a new Evoque's discs.
Help!
DeepakS is offline   Reply With Quote
Old 17th July 2017, 13:12   #125
Thanked: 10,994 Times
Help!
My Jetta brakepads lasted for 48000KM. Being an automatic and heavier, your car might eatpads at a higher rate.
As for discs, measure the thickness. There has to be a lower tolerance.
Ask them what the lowest tolerance is and then make them measure in front of you.
VW measure my discs at each service and log the thickness. As it has not gone down to to the lower lower tolderance, they have not advised a change as yet.
ajmat is offline   (1) Thanks Reply With Quote
Old 17th July 2017, 16:10   #126
Ricky_63's Avatar
Thanked: 394 Times
Just stumbled upon this thread. Having owned a Freelander 2 in 2013-2014, I may be considered "qualified" to comment. It's a great vehicle to drive on & off road. Infact it performs beautifully off road, which I tested on a purpose built track, mudpit, water, slush.
The SUV is a great place to be in, no doubt about it. But when it throws tantrums it can be disgusting !!!
My cars do not do much mileage, hardly 1000-1500KMS a month. I sold it with 16500 on the odometer. Had seen a dear friend suffer with his top of the line Range Rover, hence decided to cut my losses.
What I later heard from the guy who bought it was no less than a nightmare !! The car is used in Madhya Pradesh, mostly highway runs. The owner has spent around 9 lacs within 5000 KMS of using the car. The parts like entire steering system was replaced apparently coz there was a kat kat sound, brakes totally replaced, suspension redone. It was unimaginable that vehicle needed all of the above & then some as it was like brand new when he took it from me. Yes they take fire for any repairs or maintenance work.
My friends Range Rover was another horror story. Hence I can quite believe Salman Khan's misery. I'm done buying any JLR products ever again
Ricky_63 is offline   (2) Thanks Reply With Quote
Salman Khan to be Suzuki Motorcycles' 1st Brand Ambassador! GTO Motorbikes 16 28th April 2012 10:02
Pics: Silver Land Rover Range Rover SE Gordon Super-Cars & Imports in India 38 4th May 2011 17:06
Land Rover Unveil 2010 Range Rover Sport with all-new 510hp V8 Engine hanmust The International Automotive Scene 2 8th April 2009 20:53
Land Rover unveil the LRX - to be badged Range Rover Tstag The International Automotive Scene 26 14th March 2009 16:17
Another Salman Khan accident case?? karthik247 The Indian Car Scene 4 11th February 2006 11:00
