Go Back   Team-BHP > Indian Cars > The Indian Car Scene
The Indian Car Scene Swifts, Vtecs, Mahindras, Nanos and everything else on the Indian Car Scene.
Thread Tools
Old 25th November 2006, 12:00   #1 (permalink)
Default Accident repairs - local or dealer, repair or replace?
With relation to dealers charging huge amounts for accident or mechanical jobs, what is the opinion of you guys?
Dealer wants to replace everything, align any body member, replace body / bumper panels, etc. and the bill is usually not less than 25-50k, even for minor work. Local garages will heat up and repair the fibre bumper, bang out the dented panel, etc. and usually do the same job for 10-20% of the amount the dealer quoted.
Similarly for mechanical jobs, alternators / wiper motors / AC compressors can be repaired, local parts used and again the local garage can do the job at 20% of the cost of the dealer who will replace the components.
Cons of dealers:
1. Make money on parts / panels and exaggerate extent of work.
2. You are paying full taxes (labour get their PF, etc., Service tax, VAT, excise, etc.)
Cons of local garages:
1. Your car will be dirty as hell, with additional scratches, inside and outside.
2. Once a bumper / panel has been impacted, repairing it may not give it back its original strength and may not protect you as much as the first time.
3. Exploit labour / evade taxes.
4. Never get car back to original condition and often something else is damaged in the process of repair.
5. The repair job may get you stranded (alternator breaks down again) and/or you got to keep going back for more.
So where does one draw the line? Maybe we alongwith Team-BHP should make a list of critical and non-critical accident / repair items that we can get done at local garages without much compromise.
sandeep108 is offline   Reply With Quote
Old 25th November 2006, 12:36   #2 (permalink)
There are a ton of after-market body shops which do as good a job, if not better, than the authorised workshops. Problem is finding them....and the only way to verify their claims is seeing the job yourself.
It also depends on your make of car, and the extent of damage. I wouldnt mind giving my Vtec to an unauthorised but reputed bodyship. But no ways would I give a Merc or a Skoda to them.
Too many variables.......which leave the question best answered from situation to situation.
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 25th November 2006, 12:46   #3 (permalink)
sreenivass's Avatar
Default inquire through friends
Cons of dealers:
One of my colleagues got his OHC bumper repaired by a local guy. He seemed happy. He came to know about this local repair shop through another colleague.
You have to put in a little time inquirng colleagues and friends about a reliable local guy. Some times going with a colleague or friend who knows the local shop well helps.
sreenivass is offline   Reply With Quote
Old 25th November 2006, 13:00   #4 (permalink)
If a person is alien to the motoring world and also have comprehensive insurance, then it's best to stick with an A.S.S.
But if one's different from the above, then it's always better to give it to an expert mechanic/garage whom he is also comfortable with.
There're plenty of garages that are capable of beating any A.S.S, but problem is to find them and also keep a good relationship with them.
Old 25th November 2006, 13:26   #5 (permalink)
Yes, while finding good local garages who are consistent in their workmanship is a bit of a challenge, the point I was also trying to make is the cost vs benefit analysis of local vs A S S.
e.g. OHC silencer cost 20k from A S S (original lasted 4 years). I got it done in 8k from local fellow. But in 18 months I was getting muffler leak. Similarly I got AC compressor repaired at 5k instead of 24k replacement from A S S, but I had to go once to refill gas and cooling efficiency tended to deteriorate after 2-3 months each time of filling gas. Otherwise I felt both did great jobs, since there was no adverse effect in terms of performance / mileage.
Actually why not skoda/merc? Going local would result in max. savings in these cars, especially if a couple of mechanics from the A S S are involved. I do believe with high prices of skoda A S S, many people are actually getting their work done locally.
Merc...? well if you own one, you do not really care about maintenance costs do you? The OHC was my merc and I also very reluctantly gave it to a local garage, except when price differential was very high in a couple of cases above.
So yes, too many variables. But I think I would sum up that where critical issues are not involved, it may be ok to try out your trusted local garage, but otherwise (unless you have lots of time on your hands) better to give it to the A S S.
Old 25th November 2006, 14:12   #6 (permalink)
manaa45's Avatar
i agree with speed that if a person who knows nothing , it is better to approach a A.S.S as they have infrastructure to handle the major problems and it decreases ur headache.
but if you are willing to sheel out some money beforehand and are sure about the workshop that you woudnt be cheated then you can get the work done by local w/s too. normally to find such w/s you could contact your friends who get their cars done at such local w/s as they could give a better and first hand feedback.
__________________
Courage is not the absence of fear but rather the judgement that something else is more important than fear.
manaa45 is offline   Reply With Quote
Old 25th November 2006, 14:20   #7 (permalink)
Consider following questions:
Claiming on insurance ? Authorised dealer
Light knock ? Go to a good local
Hard knock requiring re-alignment, frame correction ? Authorised dealer but agree on scope of work if you are paying
__________________
Rice is cheaper than German Potato's
Old 11th January 2007, 22:09   #8 (permalink)
I reside in mumbai...and my zen got knocked from back by a rickshaw....bumper and back door got jacked....my garage man said insurance claim will make it send to their own shop and job wont be good....he said i will do the job...my question? is when we claim insurance where will the things be fixxed???
Text edited and corrected. Please follow the board rules. Take time to type and check your spellings.
About your question, use search function. Thanks.
ASH-WINS is offline   Reply With Quote
Old 12th January 2007, 00:42   #9 (permalink)
esteem_lover's Avatar
I have had experiences with both. i have stuck to my local service chappie for the simple reason that he is smart & will analyse things instead of asking me to leave the car & collect it after 3 days. he is also a sort of a friend now. i trust him totally & he has never disappointed. Even when insurance is involved, the *** guys are very eager to do it, but i still give it to my trusted mechanic & he gets the best possible deal from the insurance guys without over quoting.
__________________
"Keep your friends close, Keep your enemies closer"
Old 12th January 2007, 14:52   #10 (permalink)
Surprise's Avatar
My experience with Hyundai and Maruti products is that Authorized Service Stations itself does the work at fair price (though on the higher side) in comparison to the local vendors. But when it comes to Lancer, Toyota & Honda, local vendors charge only half of what has been charged by the A.S.S.
We learnt the lesson in hardway for Lancer with service from ACT India. Happy with service from local vendor before that was sold off.
ps: company owned cars
Surprise is offline   Reply With Quote
Old 12th January 2007, 14:59   #11 (permalink)
BWN
*** for Maruti's and Hyundai's or even TATA's are fairly on par with local vendors if Job quality is kept as a constant.There are local vendors who do it for half the cost but their quality is also lower by a large extent.
For Honda's or Lancers or even fiats, its better to visit the ***.Finding a good local mecanic would be a difficult task, but the costs will surely be lower with them.
If its a claimable repair, then its best done at ***.It relieves great amount of hassels and they are professionals as well.
__________________
If it is, It's UPTO me....
BWN is offline   Reply With Quote
Old 12th January 2007, 15:00   #12 (permalink)
iraghava's Avatar
My experience is that stick to the authorised centre till the car is in warranty period so that if anything goes wrong they can't pass the buck. After the warranty expires I shift to a good independent garage since the service charges are cheaper & the same genuine parts are available at 30-40% off the dealer prices.
Of course the thing here to note is that the garage should be qualified & trustworthy. Infact, the garage that looks after my car has the best body shop in all of Delhi & I prefer going there instead of going to Honda who don't do a job as good as them & overcharge too.
__________________
Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water.
Old 12th January 2007, 15:25   #13 (permalink)
rks
rks's Avatar
I go to a local garage here at Pune. The guys there seem to be OK, and the garage advertises itself as a Hyundai service centre (see quite a few old Santros and Accents there). The manager seems to be a decent guy and so far I haven't had any serious problems with them. Reasonably happy with their work. Some certificates issued by Hyundai are also displayed there, but they aren't an authorized service centre. I couldn't say for sure whether they always use genuine spares, although they do claim that. I get wheel alignment, balancing and tyre rotation at a separate tyre shop; the local garage does not do a good job.
The only reason I don't go to the authorized dealers is that they are quite far off (Sanjay Hyundai is like 25-30 kms away on the Pune-Mumbai road and Kothari Hyundai is quite far too). So I would have to depend on shady characters to drive my car there and back for the service job -- I do not have the time myself, and am uncomfortable about letting some unknown guy take the car and back. Whereas the local garage is right next door, walkiing distance.
Old 12th January 2007, 15:29   #14 (permalink)
namit's Avatar
Hi Ishan !!
I am also a Delhite.
Please let me know about this body shop.
Thanks !!
namit is offline   Reply With Quote
Thread Tools
Toyota 4Runner 2.8L- ACCIDENT REPAIR SCORPION Technical Stuff 0 4th May 2008 17:05
'Sasta Solution' -Need CD changer repair / replace advice vcash Ask the Gurus 17 18th April 2008 03:08
Car Accident Repair Cost Aashutosh Technical Stuff 1 7th February 2008 23:06
Honda Owners, do you trust your dealer for repair costs ? zenx Indian Car Dealerships 60 12th January 2008 16:52
Listing of local workshops for simple repairs theEnd The Indian Car Scene 0 21st August 2007 22:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
