Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 28th July 2008, 15:47   #46
alpha1's Avatar
Thanked: 1,035 Times
... so this will reduce pollution .. eh?
Who is gonna compress air?
Ox and donkeys?
Because unless thats the case, you would be burning fuel SOMEWHERE to compress air. Compressing air is a very lossy energy cycle. (as lossy as the Internal combustion engine).
So whats the point? You either burn fuel to power your vehicle, or you burn fuel, run a compressor, and use compressed air to run your vehicle.
And if some wise one is going to say - ELECTRICITY. Then please be forewarned that in India, 85% of electricity is generated from Coal and Gas. And any shortfall in electricity is met by Diesel.
And if it electricity you want, its better to use a direct motor drive, which has the ideal torque-rpm curve for traction.
Old 28th July 2008, 16:09   #47
srishiva's Avatar
Thanked: 930 Times
Ox and donkeys?
Ofcourse using electricity to power a motor is the easiest way.
But, since cars are mobile, you need to store this energy on the car. Batteries are not yet there. They are costly, do no last long enough and are themselves polluting.
Hence, people are looking at ways to store the energy in different ways and compressed air is one form of non-polluting, long lasting solution.
Other way to do this is Hydrogen and use fuel cells. But they are again way too costly.
So, the problem is not just about generating energy its more about what the energy carrier is going to be.
srishiva is offline   Reply With Quote
Old 24th June 2010, 16:42   #48
Thanked: 285 Times
Ox and donkeys?
In general for any electric vehicle, there has to be energy generated somewhere.
However, inspite of this, electric vehicles etc may make sense because
- A power plant is far more efficient at generating energy from fuel than a car is.
- At a central location like a power plant, pollution & emission can be controlled better than in a car.
- Also the power plant can be located far away from residential areas.
So you don't need to have an ox or a donkey to produce the original electricity in order for an electric vehicle to be more efficient & also producing lesser overall pollution than a regular car.
Also, electricity can also be produced by hydroelectric plants, nuclear plants etc in order to reduce costs & pollution further.
That's the reason there are so many companies involved in developing electric cars.
However, I have no idea if all these factors still hold true for compressed air technology. MDI(Tata's partner in the AirCar thing) has been working on Air Cars for 20 years without an actual model on road yet.
Motor Development International - Wikipedia, the free encyclopedia
carboy is offline   Reply With Quote
Old 9th August 2010, 23:21   #49
wildon's Avatar
Thanked: 1,061 Times
Got this as e-mail
Help leave healthy environment for future generations.
Tata Motors to introduce Air Car - Is it the next big thing?
Tata Motors is taking giant strides and making history for itself.. First the Landrover-Jaguar deal, then the world's cheapest car and now it is also set to introduce the car that runs on air, compressed air.
With spiralling fuel prices it is about time we heard some breakthrough!
India's largest automaker Tata Motors is set to start producing the world's first 'commercial' air-powered vehicle.
The Air Car, developed by ex-Formula One engineer Guy Nègre for Luxembourg-based MDI, uses compressed air, as opposed to the gas-and-oxygen explosions of internal-combustion models, to push its engine's pistons. Some 6000 zero-emissions Air Cars are scheduled to hit Indian streets by August 2010.
The Air Car, called the MiniCAT could cost around Rs. 3,50,000 ($ 8177) in India and would have a range of around 300 km between refuels.
The cost of a refill would be about Rs. 85 ($ 2).
The MiniCAT which is a simple, light urban car, with a tubular chassis that is glued not welded and a body of fiberglass powered by compressed air. Microcontrollers are used in every device in the car, so one tiny radio transmitter sends instructions to the lights, indicators etc.
There are no keys - just an access card which can be read by the car from your pocket. According to the designers, it costs less than 50 rupees per 100Km (about a tenth that of a petrol car). Its mileage is about double that of the most advanced electric car (200 to 300 km or 10 hours of driving), a factor which makes a perfect choice in cities where the 80% of motorists drive at less than 60Km. The car has a top speed of 105 kmph. Refilling the car will, once the market develops, take place at adapted petrol stations to administer compressed air. In two or three minutes, and at a cost of approximately 100 rupees, the car will be ready to go another 200-300 kilometers.
As a viable alternative, the car carries a small compressor which can be connected to the mains (220V or 380V) and refill the tank in 3-4 hours. Due to the absence of combustion and, consequently, of residues, changing the oil (1 litre of vegetable oil) is necessary only every 50,000Km).
The temperature of the clean air expelled by the exhaust pipe is between 0-15 degrees below zero, which makes it suitable for use by the internal air conditioning system with no need for gases or loss of power..
wildon is offline   Reply With Quote
Old 21st September 2011, 16:26   #50
k_nitin_r's Avatar
Thanked: 74 Times
Default Re: Tata Motors wants to bring AIR fuel technology home (MDI)
Originally Posted by Sam Kapasi View Post
WOW, a car that runs on vegetable oil and air??
I can see it now, GTO advising people to change from Postman to Saffola to make the car healthier and last longer.
Theoretically, it is possible to run an old diesel engine on vegetable oil. There are kits that enable one to convert a vehicle to use vegetable oil in a diesel engine. Regular old diesel vehicles can take diesel-vegetable oil blends. Vegetable oil itself, however, is more expensive than diesel in some parts of the world (including India) so people who convert their diesel cars to run on vegetable oil use waste vegetable oil and use a process consisting of filtering and heating (to remove moisture) to make the waste vegetable oil suitable for use as a fuel.
k_nitin_r is offline   Reply With Quote
Old 8th May 2012, 18:41   #51
Parthasarathig's Avatar
Thanked: 494 Times
Default Tata Motors hoping to make Gasoline obsolete
Just now Tata Aria Facebook page quoted this article regarding testing of new Engine technology based on compressed air.
If all goes well, soon ordinary fuels are going to be obsolete.
Few statements made on the site include
1. For as low as 2$ one can travel upto 300kms
2. Since this car has no combustion engine, oil change will be required only after 50000kms
Both of these points make this vehicle highly economical to own and maintain.
Attachment 925024
The prototype vehicle is called "MiniCat" and as reported Tatamotors seem to have conducted succesful tests on two such vehicles.
The site also says Tata seems to have signed a JV agreement with Motor Development International, the company that has developed these engines, "to produce and sell compressed air cars in India".
Here is the link as posted on the Tata Aria Facebook fanpage.
Tata Motors Successfully tested two Air-Powered Vehicles
Thats as much I could gather as of now.
Last edited by .anshuman : 9th May 2012 at 20:57. Reason: Removed repeat attachments. Thanks for sharing
Parthasarathig is offline   (1) Thanks Reply With Quote
Old 9th May 2012, 20:29   #52
Thanked: 103,475 Times
Default Re: Tata Motors hoping to make Gasoline obsolete
Thread moved from the Assembly Line (The "Assembly Line" Forum section) to the Indian Car Scene. Thanks for sharing!
GTO is offline   (1) Thanks Reply With Quote
Old 9th May 2012, 20:37   #53
ganesc's Avatar
Thanked: 124 Times
Interesting! This if am not wrong was in news during nano project in 2008 IIRC but nothing much after that. But good to see that the idea is still alive. Lets wait and watch.
Seems to be the most economical choice if it reaches market especially when petrol prices are growing vertically.
ganesc is offline   Reply With Quote
Old 9th May 2012, 21:10   #54
condor's Avatar
Thanked: 4,898 Times
Gasoline contains energy in it, which is extracted during the combustion process. Since the energy is already inside the gasoline, no external energy needs to be added to the gasoline. The cost of drilling petroleum + extraction process, and transportation costs together is going to be much lesser than the value of the energy released from gasoline.
So, in summary, cost of inputs is less than value of energy generated. This makes burning gasoline to gain kinetic energy, worth the effort & cost.
In case of compressed air, energy has to be spent to compress the air. Note that the energy that will be used in this Air-car, will have to be collected/bottled in by compressing normal air.
To be successful, the engine that runs on compressed air must be able to generate more value of energy than what was used to compress the air. If it does not, then this will be a very lossy process, and we may as well use the original energy to drive the car itself. (energy that was used to compress the car).
But, if the process does succeed, and we have a set-up where the compressed air can generate more value of energy than what was used to compress the air, then we would created either:
1. a perpetual system that will run by itself (compressor setup + car)
2. We have created energy itself.
Since energy can be neither created nor destroyed, neither of these two possibilities will work.
So the idea of using compressed air alone will not be viable.
Your thoughts ?
p.s:
I am serious about the scenarios mentioned.
condor is online now   (4) Thanks Reply With Quote
Old 9th May 2012, 22:42   #55
Thanked: 157 Times
I think they would be running compressor by use of electricity to compress the air. This process might be similar to charging the electric vehicle's battery at home and generally kinetic energy using the battery power. So in a way, we can say it's electrical energy vs gasoline energy.
ottocycle is offline   Reply With Quote
Old 9th May 2012, 22:44   #56
Rahulkool's Avatar
Thanked: 591 Times
I think i had read about this deal and the seen the car above in one of the automobiles magazines some 7-8 years back. IIRC there was even a thread on Tbhp.
Here is the thread - http://www.team-bhp.com/forum/indian...-home-mdi.html (Tata Motors wants to bring AIR fuel technology home (MDI))
Rahulkool is offline   Reply With Quote
Old 10th May 2012, 14:58   #57
man_and_machine's Avatar
Thanked: 215 Times
Your thoughts ?
A lot of assumptions are left out in this premise. Input energy is always > output energy (atleast in the expanding entropy system). compressed energy input can be from a non-cost based system like solar energy, or say wind, assume the following scenario I have a wind turbine that I use to connect to a compressor and from there I feed it into a car (there are a lot of abstractions I have used but you get the point). Effectively you are able to capture the solar (wind is a derived solar energy) energy into the CG. So that way economically you can achieve a higher output than input.
Oil is also solar energy captured million of years ago! We might not have the tech to now compresses gas into a value generating fuel (value means what you have said above).
Hence, other view .
man_and_machine is offline   Reply With Quote
Old 10th May 2012, 15:04   #58
tsk1979's Avatar
Thanked: 16,421 Times
Your thoughts ?
p.s:
by your logic, all electric cars are not viable since energy stored in battery from wall outlet will be less than actual energy used to charge the car.
I wonder why people are buying electric scooters and like?
This compressed air system is no different. Instead of chemical energy storage(electric car), you are storing energy as compressed air.
Old 10th May 2012, 15:07   #59
condor's Avatar
@TSK, electricity that is generated is also extracting stored energy. Hydro, coal, nuclear - anything that you want. If we were to store the energy into these material, and then calculate the over cost, then the system/process will show by itself that it is very lossy.
Old 10th May 2012, 15:12   #60
srishiva's Avatar
Thanked: 930 Times
+1. As I had mentioned a while ago in this thread the problem is about storing the energy in a moving vehicle. This is better than using batteries and the associated cost/pollution/loss of efficiency etc.
If we hate these conversions, then we need to run coal/gas/nuclear power plants in the vehicles itself like locomotives/submarines
For me, existing engines which always cant operate at the optimum efficiency (due to stop and go) are not the answer. Bring on hydrogen fuel cells.
Bernie wants to bring F1 back to India. Does Jaypee? shortbread Int'l Motorsport 5 7th July 2015 13:07
Funfilled Weekend for Customers courtesy Tata Motors, KHT Motors and Aadya Motors anujmishra Indian Car Dealerships 9 27th May 2012 16:47
How to bring home a dream: Tata Safari LX BS4 simpleman Test-Drives & Initial Ownership Reports 65 6th February 2012 01:52
Williams F1 wants to bring Volkswagen to Formula One kraft.wagen Int'l Motorsport 7 23rd March 2010 23:43
New technology to bring down cost of fuel hsejars The Indian Car Scene 1 20th May 2008 16:05
