Go Back   Team-BHP > Indian Cars > The Indian Car Scene!!
The Indian Car Scene!! Palios, Vtecs, Mahindras, Octavia RS' and everything on the Indian Car Scene.
Thread Tools
Old 3rd May 2007, 21:59   #31 (permalink)
rahul_intlad's Avatar
The volvo B7R chassis[courtesy volvo india website]
I am not too good at this but think this is not a spaceframe chassis.
rahul_intlad is offline   Reply With Quote
Old 3rd May 2007, 22:05   #32 (permalink)
v1p3r's Avatar
What about those old Greyhounds? Are they sleepers?
__________________
I've lost my phone. Please PM me your phone number if I'm on your contact list.
Old 3rd May 2007, 22:26   #33 (permalink)
1100D's Avatar
Thanks rahul, this is what I was asking for. Its a ladder frame chasis so any conventional indian bus manufacturer can tinker around with the Body on top quite safely.
For space-frame busses, (or modular coaches) its (the upward customization) not done so easily without factoring in load calculations which I dont think the normal indian bus body builders can do.
Greyhounds are not sleepers, they are normal reclining airline seats. But god, I had a ride in them earlier and vowed not to ride in them again although this is OT.
__________________
________________________
Every Ferrari is always a Fiat
1100D is offline   Reply With Quote
Old 3rd May 2007, 22:32   #34 (permalink)
tsk1979's Avatar
The first time I heard about sleeper buses when P.K Travels(Calicut-Bangalore) introduced a sleeper but with fair of around 600RS/person for an air conditioned ride to Bangalore, sometime in 2001.
Those were not B7R, but Sutlej built bodies on Tata(or maybe leyland) chasis
__________________
Reclaiming.....!
Old 3rd May 2007, 23:23   #35 (permalink)
rider60's Avatar
few of those sleeper coach volvos were made by the APSRTC for the tirupathi-hyderabad,tirupathi-vizaag and a few other places like shiridi. but later gave up for the cost per person was real high! and the dint run well either.
the fare was around 850 per ticket for the vizag and the hyd trips dont remember the fare for the shiridi trip from hyd.
rider60 is offline   Reply With Quote
Old 4th May 2007, 07:06   #36 (permalink)
Ram
Ram's Avatar
Originally Posted by 1100D View Post
For space-frame buses, (or modular coaches) its (the upward customization) not done so easily without factoring in load calculations which I dont think the normal indian bus body builders can do.
What on earth is a space-frame bus? Haven't heard of any such thing.
Is it a good time for a body-engineering. discussion?
Here goes...
Ladder chassis.
World's earliest kind of chassis.
Basically two longitudinal rails joined by multiple lateral and crossed braces.
The rails take up acceleration and deceleration forces.
Lat braces provide torsional firmness and take the cornering and lateral yaw loads. Naturally, the "Z" dimension is weakest. (as in: vertical loading, speed-breakers and potholes).
Backbone
For small sports cars, there's the fibreglass body on a rigid steel tubular backbone. This is used in the Lotus Esprit. Also Fibreglass body on a lattice TSF backbone. This is used in the TVR.
Steel, ULSAB and carbon-fiber monocoques
Steel monocoque (aka integral body or unibody)
is a one piece integrated chassis-body.
99% vehicles use it. Copiously uses metal, so you can build-in crumple-zones.
Hopelessly heavy. Only makes sense when you can afford a huge factory with
facilities for huge stampers, expensive moulders and welding robot assembly lines.
ULSAB (Ultra Light Steel Auto Body) monocoque
ULSAB uses steel too thin for the steel-monocoque stamping presses.
Basically a thin steel tube is placed in a shaping die.
Then very-high pressure (300 - 1500 bar) hydraulic fluid is pumped into the tube.
The fluid expands the tube to assume the inner surface of the die.
This is called hydroforming.
Uniform fluid pressure gives uniform steel thickness, unlike the earlier stampings.
Panels for ULSAB usually use sandwich steel -- two very thin steel skins with a sandwiched polypropylene core. This yields excellent rigidity and very low weight. But you cannot use welding. You will melt the polypropylene sandwich. Panels must be riveted or adhesive-bonded.
For doors, hoods, deck lids and hatchbacks, there's the ULSAC (Ultra Light Steel Auto Closure). Yields door structures that are 46% lighter than average frameless doors.
Invented in 1998, ULSAB will eventually replace conventional monocoque. Meets tough structural and crash criteria while weighing 25% less than steel monocoque. Used in BMW 3-Series.
Carbon-fibre monocoque
The name is self-explanatory.
The world's first carbon fibre monocoque bus was the 1988 Neoplan Metroliner. This is a city bus, with a small diesel engine on the roof that charged batteries under the floor, that powered the bus using electric motors.
Let's come to Space Frame construction.
Steel and Alloy space-frames
Steel space-frame
The 3d tubular-steel space-frame has much better strength than the ladder chassis.
circular sections provide max. strength.
Square sections easy to put the body panels on.
Weak areas are the door sills.
These must be high to take the bending stresses.
So no choice but to use Longitudinally hinged doors (aka Gullwings)
or Horizontally hinged doors (like the Countach).
Alloy space-frame (ASF)
The material used is high-strength aluminium alloy.
With this material you construct
the components of the space-frame, viz.:
  1. aluminium extrusions
  2. pressure die-cast nodes
  3. aluminium sheet stampings
At the corners, where extrusion meets extrusion, you use the pressure die-cast nodes. These take the stresses. Everything is bonded together by laser welds.
This is very space efficient yet lighter than steel monocoque.
Audi A8 was the world's first mass produced ASF-chassis car.
...end of my body-engg. gyaan.
The Volvo B7R is a simple ladder chassis -- world's earliest form of automotive construction.
Ram
__________________
On Google Chrome 0.2.149.27 since Tue. 02-Sep-2008.
When you struggle for something and fail, that’s when you get Experience!
Ram is offline   Reply With Quote
Old 5th May 2007, 01:19   #37 (permalink)
1100D's Avatar
What is the chassis on which the Mercedes Benz Citaro or even the Old Marcopolo coaches were based on, I dont remember seeing a Tata/Ashok leyland type Lader on opening the luggage hold. Moreover what chhasis does the Low-floor busses have (definitely not ladder).
__________________
Old 5th May 2007, 12:37   #38 (permalink)
Sankar's Avatar
That was a very informative post Ram.
The Volvo buses have a cargo area through which one can walk through to the other side. And this cargo area is flat very low and quite big and can swallow even a Bullet. But I've seen at the central section of the cargo hold there's a lower ceiling area and my guess is that the ladder frame is inside that enclosure. So the loading area is actually below the chassis of the bus.
Old 5th May 2007, 19:31   #39 (permalink)
BunnyPunia's Avatar
Its an original b7r for sure but i think its an after market job. the ones coming from the factory directly even have the volvo logo upfront (between the headlights).its missing here.
last month, i travelled between 5 cities, using the b7r four times.
Bangalore-Mangalore :overnight KSRTC volvo. The driver didnt know how to change gears, may be he was new to the volvo, cudnt hear the engine sound and was upshifting with half accelerator!
Mangalore-Davangere : cudnt find a volvo service, used a push back ashok leyland bus. ok
Davangere-Pune : Sharma Volvo. Noticed the driver shiftin to neutral at the slighest hint of a decline in the road!
Pune-Davangere : NWKSRTC volvo. Nice serive, even the lights above the seat worked!
Davangere-Mumbai : VRL. Nice service, again noticed the driver shiftin to neutral for kms and kms at the slighest slope!
took sleeper volvo from belgaum to goa in march. in my personal opinion, sleepers feel good when the road is straight, on curves, you tend to move a lot and if you just had food before getting on the bus,you r going to puke for sure!
@sankar : yes the loading area is below the seats as written by you. at night, when the bus is parked in the destination city, i have seen the driver/conductor sleep in the luggage area
BunnyPunia is offline   Reply With Quote
Old 6th May 2007, 12:28   #40 (permalink)
Sankar's Avatar
What I said is it's below the chassis rails!!
Old 8th May 2007, 04:39   #41 (permalink)
Ram
Ram's Avatar
Actually, no!
While the loading area is indeed below the floor of the passenger cabin,
the luggage sits on a strengthened floor above the chassis rails.
Ram
__________________
Old 8th May 2007, 19:03   #42 (permalink)
Sankar's Avatar
Originally Posted by ram View Post
Actually, no!
Ram
But ram if you compare the pic you posted and the pic which was posted earlier there's no way the luggage compartment would sit above the chassis rails if the chasis is the first pic one. If it's so then the luggage compartment would be too high above the ground. You can see the chassis rails sitting pretty high when you compare it with wheel height. My assumptions were based on the first pic.
In the picture you positioned the engine is mounted transversely but in the B7R the engine is positioned longitudinally.
Old 8th May 2007, 19:13   #43 (permalink)
1100D's Avatar
Actually, no!
Ram
This is the chassis of the Low-floor bus. I checked some other Low-floor busses as well and they look similar. However the body above this chassis can be conveniently altered with (irrespective of low-floor or the intercity application).
__________________
Old 8th May 2007, 19:59   #44 (permalink)
Mpower's Avatar
1100D is right, the pic is for a low floor bus which has no luggage area. This type of bus is called "transit bus". The buses used for intercity travel is called "intercity coach". In order to keep the CG low, they raise the passenger seats and put luggage below.
In our desi country buses, the luggage is put on a roof carrier which is not good for aero,stability or convenience.
Now, back to the sleeper, its a great idea. Can anyone post pictures of interior. I'd like to see the seating arrangement. Is is similar to our Indian railway compartments?
__________________
The difference between the men and the boys....................is the speed of their toys.
Thread Tools
Volvo B7R reviews? abhijitaparadh The Indian Car Scene!! 149 12th October 2008 19:01
ICE For a Bus - Volvo B7R moralfibre Ask the Gurus 1 23rd October 2007 13:40
Another Volvo B7R accident on the Pune-Mumbai expressway Ram Street Experiences 63 24th July 2007 10:34
Volvo B7R crash on Pune-Mumbai expressway Ram Street Experiences 30 10th May 2006 14:45
Spotted DC modified Volvo B7R Bus Stratos The Indian Car Scene!! 10 31st October 2005 23:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
