Go Back   Team-BHP > BHP India > The Indian Car Scene
Closed Thread
Old 15th May 2006, 13:13   #16
Ford Rocam's Avatar
Thanked: 16 Times
Originally Posted by Shan2nu
Frankly, i dunno whats all this talk about the Vtec not handling at high speeds. I've taken turns at 170kmph on my car (which has stock suspension) and never felt anything.
The only 2 people who've complained of this in their Vtecs, are Ajmat and Wolf and as it turns out, both of them have had their suspension replaced recently (after it went bust).
So, how can v be sure that it wasn't the weak suspension that caused the handling issues.
Shan2nu
Exactly, before Modding i have driven my honda in 1.3L trim & found it acceptable, had done proper wheel alignment (front & rear) & balancing thats it, & after modding the first thing i changed was suspension got slightly stiffened & lowered from rear about 1.25inch & 0.5inch in front, the results well ask any body who has driven my car, nitorxx during daman trip & even you Psycho you have driven it. Hondas have rear wheel alignment too which contributes to the handling of the car. correct me if i am wrong.
Ford Rocam is offline
Old 15th May 2006, 13:14   #17
Psycho's Avatar
Thanked: 95 Times
So, you're planning on racing a 2ltr engine in the 1451-1650cc class? Looking forward to that.
Hey shan I am not that nuts and that signature is just to define how F1 tech evolved, please lets not get personal.
And yes the vtec is great and so are the other cars and I hope it helps you all to put an end to this topic as each time the VTEC comes up there have to be heated discussions.
Rocam, very truly said but does not necessarily need to be lowered with the right setup and taking care of the rear damping and rebound the honda's are a dream to drive excepting for the low end torque, and love your signature.
Psycho is offline
Old 15th May 2006, 13:19   #18
amitoj's Avatar
Thanked: 1,683 Times
Shan2nu
That makes it 2 out of 3 people for me who have had that complaint. Maybe urs is an exception!
Anyways, even if it was weak suspension, it would still give bad credit to the car's handling ability. If not, then my 98 zen with 1L kms had superb handling... never mind that totally shot suspension!!
amitoj is offline
Old 15th May 2006, 13:27   #19
Shan2nu's Avatar
Thanked: 89 Times
Hey, you yorself said that it was a clue. So, i thought you were planning something with a 2ltr engine.
Yup they do, the car company reccomends a slight "toe-in" at the rear. I use slight "toe-out" at the front though. Helps the car enter corners a lil faster.
Shan2nu
Shan2nu is offline
Old 15th May 2006, 21:50   #20
The Wolf's Avatar
Thanked: 58 Times
Hey Amitoj, keep me out of the count as once I got my rear suspension replaced my car started to handle like a gem...I did take my words about the rear giving out back on one of the threads...My track day is a testimony to that good rear suspension.
1sec...A car that has a boot to tow needs great suspension to feel right, even a little suspension damage will really show up magnified...hence I guess it aint comparable with the zen which is lighter, smaller and doesnt have a boot. Morover 98 carb zen which will barely do a top speed of ~120kmph(just considering upper limit of realistic speed) is no comparison to a car which blast away at 150kmph in 3rd gear and 210kmph(mine does more!!!) given a little space and time!!!
The Wolf is offline
Old 16th May 2006, 11:48   #21
devarshi84's Avatar
Thanked: 119 Times
But lets not forget that the vtec looses the 1.5 's good low-mid range performance.
A Lancer performs equally well all over the engine range. At extreme limits, its not the cars power that helps the car stay put but the handling of the car.
As it is rightly said " A vtec needs a special driver to push it to the limits, while A lancer pushes itself to the limits and makes the driver special"
devarshi84 is offline
Old 16th May 2006, 11:56   #22
amitoj's Avatar
So u agree that OHCs have shoddy stock suspension? Given that u urself had to get it changed...
U seem to have completely missed my point and misinterpreted my post.
Let me see if i can make it a little more clear for your benefit.
I am NOT comparing a zen with a vtec. See if u can get this.... my point was about a car's handling ability vis a vis its suspension. Got it?
Amitoj
PS:
ROFL... given "a little space and time" my 98 zen (when it was in stock condition, suspension included), with 1L on the odo, used to cross 140s on the speedo!! Jus FYI.
amitoj is offline
Old 16th May 2006, 16:13   #23
v1p3r's Avatar
Thanked: 27 Times
Yeah, the OHCs have a very nervous rear above 130 kmph. Or so I felt.
Isn't the Vtec limited to 185 in 5th by the ECU?
... used to cross 140s on the speedo!! Jus FYI.
You are lying. I have driven your 1l setup to over 150 in 3rd, if I remember right.
v1p3r is offline
Old 16th May 2006, 16:55   #24
amitoj's Avatar
Haan but when u drove it, it wasnt stock any more as it had a different cam in it then. Before that, it used to manage to just cross 140, given enough space and time....
amitoj is offline
Old 16th May 2006, 17:11   #25
manson's Avatar
Thanked: 2,210 Times
my top whacks without feeling unstable, scary or whatever:
stock mpfi zen: 160 kmph (steering slightly jittery again)
stock carb zen: 150 kmph (steering slightly jittery again)
honda ohc 1.5: 188 kmph (not one bit scary, infact realised a 188 only when i was checking the snaps i had clicked)
my thoughts:
stock ohc (1.5/vtec) are much better off than stock lancers/balenos
stock lancer handles much better than the ohc s
baleno is a better car of the three (lancer, ohc 1.5/vtec and baleno) for city driving considering you have traffic in your city and don't live on the highways but loses out on the so damn subjective looks and oomph factor.
manson.
i'm getting sick of the ohc and baleno being discussed over and over again, same things said in different words!!
manson is offline
Old 16th May 2006, 19:57   #26
Thanked: 10,620 Times
I second that with my previous Zen
ajmat is offline
Old 16th May 2006, 21:11   #27
devarshi84's Avatar
Thanked: 119 Times
Originally Posted by manson
my thoughts:
manson.
Stock OHC engines are better off than baleno and lancer would be the right words.
A vtec has an advantage coz HM was stupid enough to not bring in the MIVEC.
A baleno WHile many find a good car, I will just say its good vFM from maruti.
In city I will still rate lancer above baleno and NHC. Be realistic and Look at the higher and flatter torque curve from that smoothest and most refined engine compared to the baleno's engine. Baleno's engine is a good free-revving aluminium gem which defined performance but Lancer holds of better any day in city driving.
Old 16th May 2006, 21:40   #28
The Wolf's Avatar
Thanked: 58 Times
So u agree that OHCs have shoddy stock suspension? Given that u urself had to get it changed....
I wouldnt agree or disagree with that as out of few dosen OHCs Ive known only Ajmat's and mine went bust...Mine I doubt was coz of my prevoius owner, God knows what he did in coorg!!! But yes I had to change them.
am NOT comparing a zen with a vtec. See if u can get this.... my point was about a car's handling ability vis a vis its suspension. Got it?.
Thanks for taking that extra effort in making me understand, appreciate it completely but I did get your point rather the first time itself... anyways I put my claims to rest after what I had to prove on the track day.
140 on the meter right??? If you read my post closely I have mentioned "Upper limit of realistic speed"... Guess u missed that out completely!!! Sorry to say but maruti speedos have unbelievable errors... Tried and tested. I have maruti owners who themselves wouldnt hesitate to back that statement. Even swift has significant error after 100kmph. Ask Gray(tbhpian who owns a swift). So if you really wanna know how a zen handles at 140kmph, try crossing 160kmph+...then post your comments on handling.
Speaking about vtec handling vs Lancer handling and city street driveability, I think the lancer takes the cake coz its heavier, hugs the road better and posesses better low end and mid range torque ...but I have never tested a lancer outright and cant say much more than this. The best way to conclude on things is to try it yourself than just putting something down that you have heard from someone who u dont even know!!!
The Wolf is offline
Old 17th May 2006, 06:53   #29
balenopower's Avatar
Thanked: 228 Times
Hmm another war rages...
well turbocharged city v/s turbocharged lancer..no to guesses which would win...
stock vtec would still run a tc lancer close....i mean a stock lancer is plain SLOW in terms of throttle response espicially after i swapped it with my baleno...but teh handling was good i must say..but tht was also due to the fact tht lancer was shod with 185/r14 tyres whereas mine with teh pathetically stock 165's.(its a diff ball game altogether now tht i have the 195/14's)
put it in simple words..
Best handling--Lancer
Best performance-city vtec
Best compromise-Baleno
balenopower is offline
Old 17th May 2006, 09:51   #30
amitoj's Avatar
Yeah right wolf, a car's true handling nature comes to light at 160 kmph only. Thats the speed to take the curves on the road!!!
Gosh i cant believe i let myself get dragged into one of those completely pointless arguments!!!
*no offence to all the rest who are still interested in continuing the discussion... please carry on!*
Anyways, another attempt at rising above all this!
Peace out
Amitoj
amitoj is offline
Closed Thread
PICS - Modified Honda Citys and Vtecs GTO Modifications & Accessories 982 26th June 2016 12:07
Tuned Vtecs and Balenos!! BUSA Technical Stuff 67 18th January 2006 20:23
Turbo Charged City!! iomega Modifications & Accessories 13 17th March 2005 16:37
Rio Design Lancers or Modded Lancers Katana Modifications & Accessories 4 24th October 2004 03:32
