Go Back   Team-BHP > Indian Cars > The Indian Car Scene
The Indian Car Scene Swifts, Vtecs, Mahindras, Nanos and everything else on the Indian Car Scene.
Closed Thread
Thread Tools
Old 7th June 2007, 20:43   #16 (permalink)
Its a 2.2l, 4 Valves, 4 Cyl. 290 Nm, 85 kW, VTG with Bosch CRDI of the generation EDC16 ECU. Initial trails were over by 02.2007, however, the final version of the software was delivered only yesterday
Jhajee is offline
Old 7th June 2007, 21:36   #17 (permalink)
1100D's Avatar
Are you sure about the 85 kw stuff, it means too less for my expectations. Not that I care, but at this level Tata will not feel the need to launch the 2.2 Dicor.
BTW 85 KW at what RPM?
__________________
________________________
Every Ferrari is always a Fiat
1100D is offline
Old 7th June 2007, 23:07   #18 (permalink)
theMAG's Avatar
Originally Posted by Sideways View Post
..Like someone earlier said, maybe Diwali or later.
Then in all probability the 2.2L Dicor should also be available around that time frame.
__________________
Become who you are.
theMAG is offline
Old 7th June 2007, 23:44   #19 (permalink)
BUSA's Avatar
2.2L and just 116bhp, i would say Thank God atleast some one at MnM has sense, the Scorpio doesnot need a bigger engine or more bhp all it needs is better safety and better handling, since nobody complains about the lack of power of the Scorpio and yes the Scorpio is driven very rashly by people so a 140bhp one would be
__________________
Got Bhp? Team-Bhp.com
BUSA is offline
Old 7th June 2007, 23:48   #20 (permalink)
theMAG's Avatar
Jhajee,
I presume you work at MICO. Any other drivebility and reliability updates you could provide will be appreciated as well.
__________________
Become who you are.
theMAG is offline
Old 8th June 2007, 01:27   #21 (permalink)
Can't disclose where I work..but ain't it very obvious ?
Coming to driveability, well, its a function of many calibration parameters and is fine tuned over a period of time. A continuous process on which they are working. Hats off to mahindra system engineers for getting most of it correct the very first time. and make no mistakes, at close to 30 Euros for the ECU, mahindras have achieved the seemingly impossible--a fine balance between cost and functionality. A case in point is the independent suspension (sans the vagueness) only available in the top of the line automobiles world wide is available in scorpio for a fraction of cost.
By the way, taking of updates, its confirmed that Tata would be using Bosch patented CAN for in-vehicle communication. A good move towards complete OBD support.
Jhajee is offline
Old 8th June 2007, 10:07   #22 (permalink)
Jomz's Avatar
Just Finished the drivablity maps???!!!!!!!!!!!!!!!! Of Scorpio
what about the Protocol of some miilion Kilometers of basic testing of the new CRDE and some more million kilometers of relablity testing??? say one year???
Jomz is offline
Old 8th June 2007, 10:54   #23 (permalink)
Thanks for the updates but then whats the status of the TATA Safari 2.2, do you have any information on that, are you in touch.
dadu is offline
Old 8th June 2007, 11:19   #24 (permalink)
Thanks for the updates Jhajee...
But can you explain what 'CAN' is? Also any details on the Tata 2.2 litre engine. I personally feel that that engine is much more important to Tata than the Eagle to Mahindra.
Trapezio is offline
Old 8th June 2007, 11:25   #25 (permalink)
theMAG's Avatar
I dont think MICO is executing the Tata Dicor project. Most likely Delphi-TVS. I could be mistaken though.
__________________
Become who you are.
theMAG is offline
Old 8th June 2007, 11:29   #26 (permalink)
Well, I knew that but thought that the CAN is to with the CRDI fuel assembly but I did some search and found its not, here are the abstract of the patent.
A method for remotely accessing at least one of at least one CAN node arrangement of a CAN bus arrangement associated with the vehicle during vehicle operation, the CAN bus arrangement being associated with a CAN gateway arrangement for coupling to an external network, inn which the method includes the steps of communicating an initialization control message from the CAN gateway arrangement to the at least one CAN node arrangement using the CAN bus arrangement, the initialization control message including a CAN node arrangement identifier code, comparing the CAN node arrangement identifier code with a unique CAN node arrangement identifier code stored at each of the at least one CAN node arrangement for determining a selected CAN node arrangement based on the CAN node arrangement identifier code and the unique CAN node arrangement identifier code, processing the initialization control message using the selected CAN node arrangement, communicating a data addressing message from the CAN gateway arrangement to the selected CAN node arrangement, the data addressing message including at least one memory address of the data to be at least one of accessed, controlled and retrieved, communicating at least one data reply message from the selected CAN node arrangement to the CAN gateway arrangement, in which the at least one data reply message includes a data payload, incorporating at least the data payload of the at least one data reply message using a communication protocol of the external network for communication of the data payload to the remote accessing arrangement, and communicating an end control message from the CAN gateway arrangement to the selected CAN node arrangement using the CAN bus arrangement.
So TATA is trying to put some good technology into its vehicles.
Full patent details are here
dadu is offline
Old 8th June 2007, 11:34   #27 (permalink)
tsk1979's Avatar
Delphi is DICOR current, the rumors are that the 2.2 is a Bosch baby
__________________
Reclaimed, wrung dry and recycled....!
tsk1979 is offline
Old 8th June 2007, 11:43   #28 (permalink)
theMAG's Avatar
Originally Posted by Jomz View Post
..what about the Protocol of some miilion Kilometers of basic testing of the new CRDE and some more million kilometers of relablity testing??? say one year???
Jomz,
Car cos do running tests as a series of accumulated tests running independantly, with running from all such tests aggregated towards the total figure.
While they may very well launch the new Scorpio a year down the line, it wont be due to anything else but market strategy
__________________
Become who you are.
theMAG is offline
Old 8th June 2007, 11:54   #29 (permalink)
tsk1979's Avatar
I would like to add something to the reliability testing bit. Tata and Mahindra have a team of thousands of engineers, doing reliability testing day in and day out on their cars. The team is called "The indian car buying junta".
__________________
tsk1979 is offline
Old 8th June 2007, 12:55   #30 (permalink)
------------------ ---------------------------------- and they do a hell of a job.
dadu is offline
Closed Thread
Thread Tools
Mahindra Ingenio - Now officialy announced as XYLO EDIT: Now Launched doctor The Indian Car Scene 894 27th October 2009 12:41
Captiva AWD launching on Jan 26th EDIT: Now launched machhan81 The Indian Car Scene 60 15th September 2009 10:02
VW Jetta is Launching in India EDIT: Now Launched nicejits The Indian Car Scene 249 8th October 2008 16:41
Mahindra Scorpio mHawk 2.2 launched StarScream The Indian Car Scene 85 20th December 2007 14:10
Mahindra-Renault`s Logan EDIT: Launched at 4.3 - 6.5lac rangaraj The Indian Car Scene 432 15th May 2007 03:11
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
