Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 11th July 2007, 14:20   #16
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 464 Times
I think it is an unnecessary act. It is always safe to stop at the auto-cut off mark. Also all the fuel tanks have some mechanism, either built into the cap or as an extra fitting to let air in/out. So if air can go in/out, then fuel too can seep out if filled to the brim.
pjbiju is offline   Reply With Quote
Old 11th July 2007, 15:02   #17
ankit.jhamb's Avatar
even my santro`s fuel tank can adjust 3 to 4 lts of fuel on shaking...bt logically ..the volume of fuel tank is same ...so how can we get extra fuel by shaking the car ....
ankit.jhamb is offline   Reply With Quote
Old 11th July 2007, 15:35   #18
Thad E Ginathom's Avatar
Thanked: 8,200 Times
What's the point?
I know some people who never ever drive with a full tank except when they are going on a long trip.
They fill up often, and with just a little --- like 1/4 tank or something.
The idea is simple: A full tank adds to the weight of the car: why use fuel to carry the weight of all that fuel around?
I have always been too lazy to even think about doing such a thing, but it seems many members here consider fuel consumption very important, and, I guess, every little counts!
Also, although I'm convinced it is psychological, I have this feeling that a car with a full tank runs better!
Old 11th July 2007, 15:47   #19
msdivy's Avatar
Thanked: 864 Times
My car's tank is 42 litres. When I fill till auto cut-off, its usually 38 litres. I know there still some fuel in it. If I shake, I can fill at most 1/2 litre more. Not worth the effort.
I guess people do it so that they fill maximum quantity of fuel in the tank and thereby reduce the number of trips to the bunk.
msdivy is offline   Reply With Quote
Old 11th July 2007, 15:56   #20
Thanked: 245 Times
there is always a small spillover pipe attached to the cars fuel inlet hose, which connects back into the tank. if you fill 1/4th tank you also let the fuel evaporate more in the empty space.
the auto-cut is no benchmark for a full tank and will always fill lesser than a full tank due to the mechanism, when the fuel comes back to the hose, it puts pressure on the filler hoses tip and that activates the cut off. since the fuel is whirling inside the tank, its usually earlier than the actual full tank.
shaking can give you max 0.5 to 1ltr more fill, nothing more.
Old 11th July 2007, 15:59   #21
DieselFan's Avatar
Thanked: 234 Times
What's the point?
Not a recommended practice. Almost empty tanks have higher evoporation of fuel hence one tends to get lower FE. It is therefore recomended to fill the tank up before it falls below 1/3 capacity.
DieselFan is offline   Reply With Quote
Old 11th July 2007, 16:16   #22
amitoj's Avatar
Thanked: 1,684 Times
Also, doesnt this practice of not filling the tank to full make it more prone to corrosion?
amitoj is offline   Reply With Quote
Old 11th July 2007, 16:18   #23
V-16's Avatar
Thanked: 853 Times
Shaking a car whilst filling fuel is probably the worst thing one can do. This is probably done to get the maximum fuel in the tank and for some it is a force of habit. But is this good? How would you feel if you had to stuff in so much food that you could not put in another morsel? Works the same way. Filling the tank to the brim will do more harm than good.
Usually the fuel delivery from the pump will snap stop after it detects that fuel has reached the filler tube. This is because the incoming fuel foams and this fools the pump head into shutting off. One may try filling in again but not by using coersive methods ashaking the car. After the second try in a short while, you will hear a second snap and the pump will again shut. One should not proceed after the pumping device shuts off for the second as some air space must be left above the fuel to allow for expansion and also for fuel to recirculate from the engine. This is essential for purposes of maintaining a constant fuel system pressure, as well as maintaining a uniform temperature throughout the fuel system.
V-16 is offline   Reply With Quote
Old 11th July 2007, 16:24   #24
manaa45's Avatar
Thanked: 11 Times
i too shake the car to release the air in the fuel tank.
it also happens sometimes that excesive air may result in the stalling or non starting of the car.
so it is better to shake the car while filling up.
Mansi
manaa45 is offline   Reply With Quote
Old 11th July 2007, 16:27   #25
Interesting thread this - i've read multiple numbers being mentioned about the quantity of fuel that can go in after the auto-cutoff, anywhere from 10-12litres (was it a truck?) to "not more than 1L max" - i am sure this is highly dependent on the vehicle type. On my zen, i could never top up more than 0.5L after auto cut-off (despite the shaking and all that), whereas on the Palio, i have regularly been able to go beyond 2L after auto cut-off (must admit the zen was a lot more easier to shake than the palio is)
Thingummy is offline   Reply With Quote
Old 11th July 2007, 18:02   #26
snaronikar's Avatar
Thanked: 23 Times
My car takes in about 1 ltr after auto cut off if we shake the vehicle. I do this when ever I'am filling the petrol to tank full and will be on long trip....
snaronikar is offline   Reply With Quote
Old 11th July 2007, 18:16   #27
nitrous's Avatar
Thanked: 285 Times
Do u have proof for this,dadu?
Aren't fuel tanks made of plastic,these days,amitoj??
PS: Nice to see u back on the forum.
Old 11th July 2007, 18:19   #28
amitoj's Avatar
Thanks!! And DOH !! now i know i had heard this in relation to bikes.
Old 11th July 2007, 18:31   #29
Jaggu's Avatar
Thanked: 8,467 Times
what was i thinking when i read the title lolz.
my thought dont shake em so much!! take a break and see if second fill happen with auto cut off, or just leave it at that. not worth the effort
Old 11th July 2007, 18:37   #30
nitrous's Avatar
Thanked: 285 Times
What is the objective of the shaking??
How is it going to affect the car or FE??
Accidentally filling Petrol in a Diesel car? Bullfrog Street Experiences 142 29th October 2017 11:42
Speedometer Needle: Shaking & vibrating Styler Technical Stuff 12 21st February 2016 16:05
Clutch friction plate hub shaking: Root cause? dhanushs Technical Stuff 32 15th December 2015 20:13
Problem: Ford Ikon vibrating (almost shaking) when Idle. Eddy Technical Stuff 34 1st August 2011 13:26
Wierd Experience at Petrol filling station nitinhegde Indian Car Dealerships 1 18th May 2006 16:53
