Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 8th September 2007, 09:15   #916
Default hello!
or may be the rest of the diesel is brimming up u with the overflowing adreanaline....
as long as u enjoy every drop of fuel consumed ..its worth it
so .enjoy the diesel!!!
Originally Posted by dr.abhijeet View Post
I THINK i will get the award for the lowest FE in SWIFT D.in the last cycle full tank to full tank, i got 13.2kmpl. the best i have got is 16kmpl.
the reason is terrain.
TURBOSAM is offline   Reply With Quote
Old 8th September 2007, 10:42   #917
Default Aveo 1.4 FE
Originally Posted by gokborki View Post
Can the Aveo owners (1.4 and 1.6) give their FE values please?
Tried searching this thread but could not find many results (got only 2).
My Aveo 1.4 has just clocked 500kms and the current FE is around 10 with AC. This should improve to 12 once the car has done 2000kms+, as told by the dealer.
LokeshG is offline   Reply With Quote
Old 8th September 2007, 16:33   #918
spadival's Avatar
Thanked: 15 Times
Baleno gives me 13-15 KMPL - mix of highway and city driving. Very little or no speedo error here.. I checked by comparing GPS readings with the speedo.
spadival is offline   Reply With Quote
Old 8th September 2007, 20:20   #919
Thanked: 13 Times
My Santro XL 2006 gives me 11 in city & 13 on highways. AC is always on. Any suggestions how I can improve it? My car runs on alloys & 165 width turanzas. Could it be because of the wider tyres?
ronline is offline   Reply With Quote
Old 8th September 2007, 21:16   #920
iTNerd's Avatar
Thanked: 503 Times
done around 2100 kms on my SX4 Zxi.. before 1st service got 10-10.5 kmpl .. from the last top up, I got a much better FE of 12.5-13 kmpl in city driving condition with 95% AC usage..guess crossing the 2000 kms mark kicks up the engine effiencieny!
iTNerd is online now   Reply With Quote
Old 9th September 2007, 11:23   #921
Default attn MANJU..
Many says IT IS BETTER to move to higher gear whenever it is possible w/o knocking the engine . -http://www.wikihow.com/Save-Money-on-Gas : says - "the most efficient speed is your car's minimum speed in it's highest gear, since this provides the best "speed per RPM" ratio."
IF it is SO..would you clarify your point"Never shift to 5th gear, unless car is at 70kmph and expects to drive at least 2kms at that speed, what it means is rarely I drove in 5th gear."
by the way what about cars which dont have TACHOMETER.
TIA
Originally Posted by manjubp View Post
My Brand new swift VXI with ABS, first FE report.
1. At 23kms on Odo filled Shell Super upto auto cutoff, reseted trip meters
2. At 441kms on Odo filled once again Shell Supreme upto auto cutoff, with trip meters showing 418.5 kms, only city driving.
3. It took 28.56 lts @ Rs54.47/lt
4. So FE is 14.65km/lt, in Bangalore on Hosur road. Daily commute between Vijayanagar and EC morning around 8AM and evening around 7-9PM.
Driving habits:
- Press clutch only when it is required to change the gear.
- RPM was maintained between 1500 to 2800 most of the time
- Never shift to 5th gear, unless car is at 70kmph and expects to drive at least 2kms at that speed, what it means is rarely I drove in 5th gear.
- Around 15% AC, as it is winter here in Bangalore
- Tyre pressure was around 36PSI, after driving around 15kms, so at cold it may be around 32psi.
regards,
-manju
shapath is offline   Reply With Quote
Old 10th September 2007, 17:31   #922
Default a thing to llok for!
its absolutely correct for all carb engines for all the conditions.in the case of mpfi engines<especially in the better designs> there is a load calculation too and the ecu will sent the air fuel ratio on richer side within pre priscribed limits. if u press the accelerator even more <how much is MORE depends upon the programming in the ecu and varies >then the lambda sensor reading is not taken in to consideration for mixture cross correction and continously richer mixture is added till the load,accelerator position lambda value and rpm<in some cars even car speed too> is within pre priscribed zone .
shifting faster while maintaining the momentum in higher gear with lightest accelerator input will give u good kmpl figures on all cars equiped with elec. management systems .
there is one more glitch.. more the advanced programming and variables and ruling parameters added to it , wider the fuel efficiencies varies on the same car .
more the complicated the system better the milage it will give in good hands.and woester in rash hands.
in short more the KNOLEDGABLE the ecu is better the driving it expects from the oprator.and rewards of punishesit accordingly .
TIA
Old 10th September 2007, 23:04   #923
tsk1979's Avatar
Thanked: 15,683 Times
Some numbers from Amreeka
30mpg in a 2006 Corolla (mixed use) (over 440 miles)
28mpg in a Chevy Cobalt (mixed use) (200 miles)
23mpg in a Dodge Avenger(highway high high high speed, hills, ripped) (1300 miles)
17mpg in a Jeep Liberty 3.7L V6. (400 miles)
Old 11th September 2007, 02:31   #924
aditya.86's Avatar
hyundai santro 2006 march
in city:13 kmpl(wit a/c)
highways:16.5-17kmpl(without a/c)
bajaj pulsar 180 dtsi 2004
in city:40 kmpl
highways:43kmpl
aditya.86 is offline   Reply With Quote
Old 12th September 2007, 20:00   #925
I got a FE of 13 on my recent tank which is split to:
15 km or 3.9% in city smooth traffic flow
350 km or 89.7% in the highway, cruising between 120-140,
15 km or 3.9% in stop go traffic for about 1 hour
10 km or 2.5% in city with smooth traffic + rough traffic + long idles.
I think its a great FE for the Ikon 1.6. What do you people say??
EDIT: 100% a/c used.
cya
A
Absar is offline   Reply With Quote
Old 13th September 2007, 14:48   #926
rockyb's Avatar
Thanked: 11 Times
Mahindra Bolero Glx 2004 (41500+km) - 10/11 kmpl in city - 13 kmpl highway
rockyb is offline   Reply With Quote
Old 13th September 2007, 16:21   #927
Thanked: 235 Times
Bolero SLE 2007 (1200km Odo)
11-12 kmpl City.
No highway trips yet. Waiting for first service.
Torqy is offline   Reply With Quote
Old 13th September 2007, 18:07   #928
hormaz's Avatar
Hey guys,
Own a Ford Fiesta 1.4 Exi, after the 1st servicing,its giving me 15kmpl in city, haven't taken her out on the highway yet after the service.
hormaz is offline   Reply With Quote
Old 14th September 2007, 18:59   #929
Default great!!!
great figures man!
actualy u have burnt a lot of fuel in that 15 kms traffic, other wise u could have broken records,,
try tankfull to tankfull on highway . without a/c . ull get great figures man !u have a great driving skill set,good car<indivisual piece>and it seems u have a good source of petrol as well as maintaince too .
cya
A
Old 14th September 2007, 19:08   #930
adman77's Avatar
Now my Corsa returns figures of around 7.5 in city usually without AC. Highway figures are around 9.5-10.
adman77 is offline   Reply With Quote
What was your car's actual resale? yeis What Car? 255 27th July 2017 14:22
What is the fuel efficiency (FE) of your Santro Automatic (AT)? subscrive The Indian Car Scene 17 7th September 2010 14:16
