Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 9th July 2011, 15:56   #91
Thanked: 91 Times
Default Re: Issues regarding ground clearance of CIVIC
My Civic scrapes at-lest 30% of the speed breakers in Delhi and lot many when I drive outside Delhi on State Roads.
Has anybody tried adding suspension spacer to their Civic? How does it affect the ride quality and performance of the vehicle.
Do these spacers have any impact on life of suspension?
How is performance affected if both tyre upgrade as well as spacers are added?
Dinesh
dinesha is offline   Reply With Quote
Old 11th July 2011, 13:41   #92
sushrutha's Avatar
Thanked: 324 Times
Dinesh
I wouldn't advice you to go with Suspension increasing SPACERS as fitment. I would affect the handling of the car.
Rather suggest you to put COIL SPRING ASSISTERS for solving this road scraping issue to a certain extent.
I have fit the same in my CIVIC, it's marginally better than the stock civic soft suspension which bottoms out royally in every road hump in BLR.
This is a very VFM upgrade.
For more info check this thread
http://www.team-bhp.com/forum/techni...uspension.html (Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspension?)
Through tyres, yes you can increase the ground clearence, if you go with a higher profile tyre. Stock is 195/65/R15, If you want more ground clearence along with wider tyres, then better go with 205/65/R15 tyres.(After the upgrade, you'll have a marginal/negligble Speed/ODO error).
sushrutha is offline   (2) Thanks Reply With Quote
Old 12th July 2011, 13:49   #93
Thanked: 91 Times
Thank you very much for the link, Gazed through few post and looks interesting. I will go through each and every post and post my quarries there?
Meanwhile I am looking for new tyres as current ones (Stock) are worn out. I am looking for max ground clearance gain as I do lot of Rajasthan/Haryana rough roads with light loads (2 persons). I will catch up there. Thanks again.
Optimum ground clearance of a Car? & how it is measured... skamb Technical Stuff 84 17th May 2017 22:36
Raising a Tata Marina's Ground Clearance vivek.singh.73 Modifications & Accessories 27 8th September 2013 21:43
Increase ground clearance of Civic & improve mileage vivek_sharma20 Modifications & Accessories 34 10th April 2012 15:13
NHC ZX - Ground Clearance venkatrx The Indian Car Scene 17 30th July 2009 20:22
NHC Zx Ground Clearance and Ride quality mahesh4sure The Indian Car Scene 8 24th February 2006 11:39
