Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 11th January 2008, 23:09   #1
Default Some Info on Gama
Hello Everybody
I have some questions about the Trax Gama Classic.
Would certainly appreciate the feedback.
In an earlier review of the Gama Classic by moderator " Samurai ", he said
that the difference between the the Gama and Gurkha are
(1) Size of Wheels
(2) Differential breather
(3) Snorkel air intake
Now it was mentioned that the diffs found on Gama are not safe in
water.
What does it exactly mean ?
I am not looking forward to cross a river or something like that, but will
it be able to make through water logged roads during monsoons. Driving
through 1.5 to 2 feet of water. Will the diffs get damaged ?
By the way, aren't the diffs of any car water tight ?
Can you guys suggest a good electrical winch ? ( Name and other
specifications please)
Sets of high power lights ?( To be installed on bullbar )
Suggestions for bullbar/ brush guards ?
Any upgradations to the alternator or/ and battery for the winch
and lights ?
Set of good off-road tyres ? ( Indian brand please )
Also the price of a Trax Gama with Air-con, PS and 4x4 ?
Spinner Wheelz
Spinner Wheelz is offline   Reply With Quote
Old 12th January 2008, 15:07   #2
Thanked: 40 Times
Let me highlight the Important similarities and differences between Gamma and Judo
Both of them are based on 2750 mm wheel base and share the same frame and drive train.
The Gamma has a DI engine while the Judo has an IDI engine . However IDI engine is not available anymore, so no point talking about it.
All differentials have breathers. It is just a matter of how high the breather goes. In a Judo/Gurkha it goes all the way up and ends in a chamber in the engine bay.
The Breather in a Gamma ends above the chassis.
Electrical winch - not recommended. Get a hydraulic or mechanical winch . Gamma can be fitted with a PTO andd can operate both hydraulic as well as mechanical winch.
Good lights - Light force 240 Blitz. Check out my gallery to see the lights. These lights are literally bullet proof and project light a good 600 meters.
Good offroad tires - JK LT 2000 4x4
Price, contact dealership
rrnsss is offline   Reply With Quote
Old 13th January 2008, 19:13   #3
4x4addict's Avatar
Thanked: 2,639 Times
I would guess it could be driven in our flooded roads like a bolero or scorpio like MUV/SUV, but with the Gurkha/Judo you can ford much deeper water.
For you day to day use the standard set up should give you the same functionality as other SUV/MUV
4x4addict is offline   Reply With Quote
Old 13th January 2008, 23:22   #4
Thanked: 40 Times
Yes you are right. For shallow fording a Gamma should do just fine
Old 15th January 2008, 23:43   #5
Thanks guys for providing me with the info.
I really do appreciate your efforts
Thanks once again
Spinner Wheelz
Old 2nd February 2008, 14:08   #6
Torque-ative's Avatar
Thanked: 55 Times
Default Fording depth !!!
Could you define in the world of 4x4 parlence
  • shallow, :
  • deep, :
  • reeaal deep:
Though it wise to ask the hard core Jeepers amongst us.
@rrnsss & @Arka,..comments please !
Torque-ative is offline   Reply With Quote
Old 2nd February 2008, 14:58   #7
Samurai's Avatar
Thanked: 15,339 Times
Gama doesn't come with diff locks, I guess you already knew that.
There are two engine options, TD2650F (BSII) and TD2550FTI(BSIII).
TD2650F (BSII) -45kW (3200rpm) and 158Nm(2000-2200rpm)
TD2550FTI(BSIII) - 56kW (3200rpm) 195Nm(1800-2000rpm)
For off-roading, you would really want the FTI engine. But it is very difficult to get delivery, you would wait for ever.
One more hopeless combination, they don't even have an order code for this.
The only way you can get a Gama 4x4 easily, is if you order it with BSII engine and without PS & AC. If you are a city resident, you can't buy BSII, that is the catch-22.
Old 2nd February 2008, 16:02   #8
Alfa_Kilo's Avatar
  • shallow, :
  • deep, :
  • reeaal deep:
Shallow fording: A water body that can be crossed without prior preperation.
Deep fording: Preperation such as water proofing, snorkel installation, one way valve in exhaust etc. are required before crossing the water body. This usually applies to military vehicles such as tanks and SPs.
@rrnsss: Are the breathers in the Gama mounted on the axles (like they are in most indian vehicles) or on the chassis through a rubber pipe?
Alfa_Kilo is offline   Reply With Quote
Old 2nd February 2008, 17:58   #9
Thanked: 55 Times
Alfa_Kilo Sir ! I was asking in mm depth.
Thanks for the reply.
Old 3rd February 2008, 08:58   #10
Alfa_Kilo's Avatar
There is no fixed boundary depath, it depend on the vehicle, a waterbody shallow fordable by a tank may require deep fording prep on smaller vehicle.
The very first Team-BHP Test Drive of Force Motor's Trax Gama Samurai Test-Drives & Initial Ownership Reports 183 3rd October 2016 21:00
Force Gama - A few questions H3LIOS SUVs, MUVs & 4x4s 74 11th May 2015 10:32
Gifted!Force GAMA E-III - Internal modifications - need Advice. Alton Modifications & Accessories 10 2nd June 2008 21:03
want yamaha daytona or suzuki gama shoei Superbikes & Imports 4 22nd September 2006 01:04
Any Bajaj Tempo Gama/Judo/Gurkha dsnreddy Shifting gears 0 10th March 2005 07:12
