Go Back   Team-BHP > Indian Cars > The Indian Car Scene
The Indian Car Scene Swifts, Vtecs, Mahindras, Nanos and everything else on the Indian Car Scene.
Thread Tools
Old 21st May 2008, 17:25   #1 (permalink)
deepgautam_qa's Avatar
Question Please Help!!! Ground clearance of Fiat Petra 1.6 gets reduced
Friends, I need your advice on how to increase the reduced ground clearance of my Fiat Petra 1.6 EL. It has sunk (rear) so low that every other hump tempts to kiss the car.I have heard of two solution, one is to use rubber padding over the existing springs and other is to get a new set of coil springs in place.Please suggest!!!
deepgautam_qa is offline   Reply With Quote
Old 21st May 2008, 17:38   #2 (permalink)
Technocrat's Avatar
Welcome To TeamBhp deepgautam_qa
I am sure people will help you once they read this in the meanwhile please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 21st May 2008, 18:13   #3 (permalink)
Default Please help!!!Ground Clearance of Fiat Petra 1.6 gets reduced
Deepak,
It is advisable to use rubber padding over the existing springs,I have used the same in my esteem as i was facing the same kind of a problem,now the problem is no more there.
I request Bhpian to give their suggestions on this,
Ishan: request you to give your expert opinion.
anupam00 is offline   Reply With Quote
Old 21st May 2008, 20:20   #4 (permalink)
rjstyles69's Avatar
deepgautam these rubber padding's that you are talking about are called SPACERS !! You generally would find them made of rubber and aluminum. Sure increases the height of your ride by an inch or so but then be ready to compromise a little on the handling part.
If you are a sober driver and not burning the tarmac always go ahead with it. You have nothing to loose. I had done it on my older Alto and friend has done the same to his esteem too.
Regarding the coil springs , get it checked with the service center. If they says its bad go ahead and replace it. For stiffer springs you can always look at Peddars .
Another was around this is to get a stiffer suspension setup. You could go for a local suspension job or get Koni's(expensive).
Hope that helps
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
Old 22nd May 2008, 12:02   #5 (permalink)
Are you saying that it has reduced only recently? That means your suspension is sagging. How many kms up?
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 22nd May 2008, 12:37   #6 (permalink)
phamilyman's Avatar
RJS/GTO: Fumb koshun, but like one needs to take his car to Leh. Say the SwiftD. 170mm is good, but 30mm spacers would make it a delectable 200 mm (Safari territory). I know its a 15 min job, but is it ok long term to put spacers for hill drives once in two-three months?
And loaded down with luggage, the C of G would again be lower - so what would net impact on handling be?
Old 22nd May 2008, 13:10   #7 (permalink)
ranc's Avatar
Phamily man
It doesnt work that way, if you put a 30 mm spacer may be you would get a 15-20 mm increase in the GC, btw you are planning to take a Swift D to leh, that is adventuous to say the least. I took my SX 4 to Rohatang couple of weaks back and I was always thinking why did I sell my Scorp. Huge boulders on some of the places where they have mountain water crossing the road. Best of luck and do let us know how the trip went.
ranc is offline   Reply With Quote
Thread Tools
Fiat Linea Ground Clearance Issue S.I.N.G.H Technical Stuff 38 16th October 2009 17:13
Ground Clearance cartech Technical Stuff 34 22nd September 2009 18:13
NHC ZX - Ground Clearance venkatrx The Indian Car Scene 17 30th July 2009 21:22
Increasing ground clearance pathfinder Modifications & Accessories 11 15th December 2006 05:03
Improving the Ground Clearance naveendhyani Modifications & Accessories 1 17th March 2006 10:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
