Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 17th June 2008, 14:22   #16
Awaiting Email Confirmation
Thanked: 20 Times
I'm in no position to calculate the FE of my Palio 1.2 with GPS. I sold it many years ago. but we used to run an M800, an MM540 and a zen at the same time, and it used to hurt a lot more when the palio went to the petrol pump.
if driven slowly, for FE- I could squeeze 12kmpl. if driven like the M800 Mpfi, I'd be lucky if i got 8kmpl.
odo calibration or not, the palio 1.2 was a heavy car with poor low end torque and had lousy FE when driven to keep up with traffic.
now I shall hang a sign on my neck saying bash me, curl up, and lie on the floor.
Old 17th June 2008, 14:36   #17
sanjaymugur's Avatar
Thanked: 53 Times
good to hear this..
FIAT, always....
sanjaymugur is offline   Reply With Quote
Old 17th June 2008, 14:36   #18
dude131's Avatar
Originally Posted by deepakhon View Post
As far as what I read in ACI years ago, the Brazilian Palio had a different tyre size and hence, the calibration of the odo was different. Fiat India changed the tyres for India, but forgot to callibrate the odo for Indian Palio's tires, hence the distance shown by the odo was actually less as compared to the actual distance travelled by the car. Therefore, the FE was measured lower. Apparently, they corrected the odo callibration starting from NV models.
I remember reading this on Autocar India too, what a stupid mistake by Fiat, especially when they tested the vehicles for some many thousands of km before launch.
dude131 is offline   Reply With Quote
Old 17th June 2008, 14:37   #19
extreme_torque's Avatar
Thanked: 1,443 Times
Originally Posted by rippergeo View Post
if driven slowly, for FE- I could squeeze 12kmpl. if driven like the M800 Mpi, I'd be lucky if i got 8kmpl.
Even I drive for FE but so is the case with all the other biggish hatchbacks. If driven for performance even they will fare the same.
extreme_torque is offline   Reply With Quote
Old 17th June 2008, 14:44   #20
finneyp's Avatar
Thanked: 175 Times
Palio is heavy due to a reason - Build quality!
I have come across quite lot of accidents involving a Palio, where Palio was damaged to a total loss, but the occupants came out unhurt!
Also, it is a built to last car, my 4 year Palio doesn't have any rattles!
lousy FE?
I get 12 - 13 kmpl in City with my spirited driving, I mean I rip on fast moving roads.
Now, if you need a tinny car with excellent FE, you have lot of options in the market starting from 2 lakh onwards!
finneyp is offline   Reply With Quote
Old 17th June 2008, 14:46   #21
Thanked: 20 Times
you have a point there. the swift petrol is pretty much the same.
but what other biggish hatchbacks did you have in mind?
Old 17th June 2008, 14:46   #22
srishiva's Avatar
Thanked: 889 Times
Infractions: 0/1 (5)
This would be a good start to check all the vehicles in India. Maybe everyone with a GPS and different cars should check to see how their odos misbehave.
srishiva is offline   Reply With Quote
Old 17th June 2008, 14:55   #23
Getz, Swift as you said, Aveo UVA.
Old 17th June 2008, 15:17   #24
CrAzY dRiVeR's Avatar
Thanked: 19,051 Times
Originally Posted by finneyp View Post
So who is wrong here? I don't think Fiat India, they did the right thing! It was other Car makers, who calibrated their odos 10% more than the actual, to claim higher FE figures!
Going by that logic, FIAT is cheating its Brazilian customers in the same way!
As the odo was not caliberated even though tyre size changed, the odo of the original (Brazil, its parent market) palio will give higher readings.
Old 17th June 2008, 15:17   #25
WhiteKnight's Avatar
Thanked: 76 Times
I read across forums and hear it from people that the Palio 1.2 NV or not is not fuel efficient.
My Palio is almost dead accurate with hardly a difference of .2kmph or .3 kmph @ 60 compared to the reading on GPS.
Okay, so you mean your Pre-NV Odo is dead accurate.
Originally Posted by nitrous View Post
Apparently, the tyre size was changed in India for accommodating our bad roads. But, the great FIAT engineers didnt bother about recalibrating the speedo gearing for the different tyre size.
From above posts of nitrous and deepakhon, I understand pre-NV Odo were reading lesser Kms than actual. The Odo error was corrected in NV models.
If this is true, did FIAT re-calibrate NV Odos to inflate fuel efficiency figures? As per extreme-Torque, his GPS and Odo readings are matched, so no Odo error on Pre-NV Palios. Then where is the question of re-calibration and odd Brazilian story?
Conspiracy?cheers:
WhiteKnight is offline   Reply With Quote
Old 17th June 2008, 15:43   #26
The speedo's almost dead accurate and odo under reads. You would like to read my post again... isnt?
I repeat my odo under reads so if Fiat recaliberated the odo in NV, how does that amount to "inflating figures".
Conspiracy?cheers:
You have to read my post again
Old 17th June 2008, 15:46   #27
How do you know brazlilian market palio over read? I cant see any logic behind your statement. Besides I am talking about the Indian Palio so can we continue our discussion on the same.
Old 17th June 2008, 16:10   #28
finneyp's Avatar
Thanked: 175 Times
ET, after I re-read your first post, I realized that Fiat India did overlook the odo calibration thing when they launched the Brazilian spec'd Palio in India, they changed the tyre spec for India but retained the Brazilian odo calibration, and as you noted there was a odo under-read of 3%, which resulted in lower FE figures (actually it was not) and the rumours flew thick & fast & dented the sales of Palio.
Though, they corrected this issue in Palio 1.2 NV in later part of 2003, but this misconception remained for quite long time.
Old 17th June 2008, 16:20   #29
Thanked: 20 Times
The Mahindra is a diesel and M800 and Zen were smaller cars/had smaller engines. No surprises here.
Given that everything in this world is relative, if Maruti cars have odo's that over-read, then it defintely works towards the disadvantage of other cars, right? Moreover, specifically in case of mileage figures, we usually use that of Maruti cars as benchmark (lighter, fuel efficient cars).
Jeep is offline   Reply With Quote
Old 17th June 2008, 17:03   #30
Thanked: 34 Times
ET, all said and done, it is a good experiment to cross check the accuracy of the odo and speedo readings with GPS. I think guys with GPS phones can try these over a period of time and can report their findings in this forum. That will be a good indication of where all the cars stand.
Now, who will buy my iPhone so that I can buy it again from Airtel once it comes to India?
deepakhon is offline   Reply With Quote
10 Million USD X-Prize for Fuel Efficient Cars sriramv.iyer The Indian Car Scene 4 1st May 2010 06:59
2009 Hyundai Sonata and 2008 Malibu More Fuel-Efficient than Camry,Accord srishiva The International Automotive Scene 7 16th May 2008 11:32
Most fuel efficient diesel sedan\muv RoadFiend Sedans 18 25th June 2007 10:48
Why do we have less Fuel Efficient cars in India ? Karandeep81 The Indian Car Scene 25 14th June 2007 15:22
Kinetic motorcycles are most Fuel-efficient devarshi84 Motorbikes 14 13th April 2006 08:56
