Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 6th September 2008, 12:18   #31
amitpunjani's Avatar
Thanked: 101 Times
Hi
The estimate is nearly half of the value of your car. Would appreciate if you could post the break up.
amit
amitpunjani is offline   Reply With Quote
Old 6th September 2008, 12:39   #32
benbsb29's Avatar
Thanked: 4,223 Times
Shashank, thats an astronomical quote! As the others have mentioned, put up the breakup, and members would analyse whether they are trying to rip you off or not.
Old 6th September 2008, 12:42   #33
hellstar's Avatar
Thanked: 17 Times
Sad to hear about your car , but do post the estimate that they have given you , in all likelyhood instead of salvaging as far as possible the A.S.S guys would have listed them for replacement as someone has already pointed out earlier ...and the high estimate almost makes the car look like a typical case for claiming total loss which shouldnt be the case at all....
hellstar is offline   Reply With Quote
Old 6th September 2008, 13:23   #34
alpha1's Avatar
Thanked: 1,014 Times
Man, this is ridiculous, in such a situation, all that warrants is the cost of engine + few accessories that might've got harmed beacuse of water.
Is Civic's engine that expensive?
They must've given a bill of material also along, could you please publish that also.
I am sure Insurance won't cover all the items.
Old 6th September 2008, 13:40   #35
married2speed's Avatar
Thanked: 7 Times
Sorry to hear about your ordeal agentsmit2. It's one of those things which you possibly can't help no matter how much you wanted to. A friend of mine suffered almost the same fate in his baleno. Water entered the engine through the air-filter and boom he was dished out an estimate of 1.5L and counting. This is after he had extended warranty and insurance, neither of which came to his rescue.
All he did was, move the car out of the dealer, handed it over to a local mechanic and his car was repaired in 25K. So far, his car is working just fine.
What I would suggest is, in case, the insurance doesn't work out for you, try getting the car repaired from a local mechanic you trust. I'm sure your estimate would come down to around 50-70K or thereabouts.
All the best
M2S
married2speed is offline   Reply With Quote
Old 6th September 2008, 14:31   #36
agentsmith2's Avatar
Thanks for the reply people! Appreciate it.
The A.S.S. guy hasn't given the bill-of-materials yet. This estimate has been sent to the Insurance guys who are now evaluating it to see if they can approve it or not. What caught my goat was that apparently the bill includes changing the steering wheel as well.
Steering Wheel? and the car wasnt even flooded enough to let the water in. So no upholstries, no seat covers damaged, all electronics was working fine [dashboard etc]. The water didn't enter engine compartment at all - no frothy oil of any kind. Only the airfilter showed traces of water.
The bill of material will be faxed monday now.
Does anyone know a good workshop in Pune for Honda ?
Last edited by agentsmith2 : 6th September 2008 at 14:34. Reason: repaced service guy with *** guy
agentsmith2 is offline   Reply With Quote
Old 6th September 2008, 15:49   #37
Default The estimate
A Spare Parts
1 Sensor Map 1 37830rnaa01 9305.00
2 Valve Assy Bypass 1 17210rnaa01 6510.00
3 Acuator Assy By Pass 1 17150rnaa01 3750.00
4 Injector O Ring 4 91301plc000 310.00
5 Injector O Ring 4 91302pna003 310.00
6 Sensor Air Fuel Ratio 1 36531rnaa01 14518.00
7 Sensor, Oxygen 1 36532rnaa01 15490.00
8 Converter Assy Caty. 1 18160rnaa00 24285.00
9 Coil Comp., Plug Hole 4 30520rnaa01 12752.00
10 Spark Plug 4 9807b561bw 4224.00
11 Alternator Assy 1 31100rnaa01 15488.00
12 Starter Assy 1 31200rna003 6521.00
13 Water Pump Assy 1 19200rnaa01 6842.00
14 Fly Wheel Comp 1 22100rna003 7934.00
15 Disk Friction 1 22200rna003 2875.00
16 Disk Pressure 1 22300rna003 2870.00
17 Pump Assy Strg 1 56110rnaa01 11222.00
18 Pulley Assy P/s 1 56483rnaa01 1297.00
19 Drive Belt Kit 1 04301rna309 4269.00
20 Gasket Kit Cyl Head 1 06110rna000 7012.00
21 Gasket Kit Chaim Case 1 06114rnay00 1020.00
22 Air Filter Element 1 17220rnay00 825.00
23 Meter Assy Air Flow 1 37980rnaa01 5472.00
24 Pipe B Exhaust 1 18220snaa11 6629.00
25 Pipe C Exhaust 1 18307snbj01 5712.00
26 Strainer Comp Fuel 1 17048sna000 3162.00
27 Battery 1 6250.00
28 Box Assy Fuse 1 38200snbr02 14597.00
29 Relay Assy 4 3800.00
30 Motor Cooling Fan 1 19030rsag01 6796.00
31 Strg Rack Comp 1 53601snbt02 33958.00
32 Set Rack End Comp 2 53010snaa01 5738.00
33 End Comp Lhs 1 53560snaa01 1288.00
34 End Comp Rhs 1 53540snaa01 1288.00
35 Engine Control Modul 1 37820rnay33 38820.00
36 Eng Harness Fuse Box 1 32200snnd10 18590.00
37 Horn Assy High 1 38150sla003 1154.00
38 Horn Assy Low 1 38100sfjw01 960.00
39 Abs Midulator Assy 1 57110snaa53 19590.00
40 Canister Assy 1 17300sna003 4033.00
41 Srs Dr Module Assy 1 77810snbu80za 28839.00
42 Srs Module Co Dvr Side 1 77820snbu82zc 50538.00
43 Carpet Set Floor 1 83301snnd11za 3867.00
44 Insulator Dash Pannel 1 74260snlt00 1860.00
45 Fr Speaker Assy 2 39120slj901 4617.00
46 Cyl Lock Set Assy 1 06350snnd01 13021.00
47 Latch Assy Fr Lhs Door 1 72150snat01 6445.00
48 Latch Assy Fr Rh Door 1 72110snat01 6442.00
49 Latch Asy Lhs Rr Dr 1 72650snaa11 6447.00
50 Latch Assy Rhs Rr Dr 1 72610snaa11 6447.00
51 A/c Comp Assy 1 38810rna004 20871.00
52 A/c Copm Set Clutch 1 38900rnaa01 5849.00
53 Set Filed Coil 1 38924rnaa01 2533.00
54 Engine Oil 710.00
55 Radiator Liquid 4 1240.00
56 M/t Oil 3 750.00
57 Brake Oil 2 640.00
Old 6th September 2008, 15:57   #38
benbsb29's Avatar
They plan on changing the door latches, carpet set, etc. No wonder they have managed to run up such a crazy figure! As for the other items, will wait for the others to comment.
Old 6th September 2008, 16:02   #39
FlyingSpur's Avatar
Thanked: 1,335 Times
Thats exactly the first thing I noticed. 25k for door latches. 4k for carpets. A few grand more for speakers. Hmmm. I don't know man, I think you should scrutinize this list and maybe get a few opinions from a trusted mech or knowledgeable folks from tbhp before going ahead with this. You know, just to make sure everything listen is actually required to be replaced.
FlyingSpur is offline   Reply With Quote
Old 6th September 2008, 16:26   #40
adityamunshi's Avatar
And there's about 1 lac for various stuff like ABS and airbag module. Why does that need changing.
adityamunshi is offline   Reply With Quote
Old 6th September 2008, 16:48   #41
mmmjgm's Avatar
Thanked: 21 Times
I believe a faulty ABS system will not work, a half dead ABS & Airbag module are even worse, there have been accidents where the driver was taken by surprise upon the air bag activation and could not see the road, compounding the accident.
cheers
mmmjgm is offline   Reply With Quote
Old 6th September 2008, 16:55   #42
cheers
Water entry causing faulty Air bag activation ?
Old 6th September 2008, 18:55   #43
Thats what i mean, the systems may not be faulty after all a little bit of water cannot damage parts of the car, other than the engine of course.
Old 6th September 2008, 21:26   #44
aerohit's Avatar
Thanked: 606 Times
The estimate is CRAP CRAP CRAP
If i was there, i would have removed the valve cover and the head and cleaned the engine, and it would we good as new!
Once again - CRAP
For example, why does Exhaust pipe need to be replaced? thats stupid
Yes, i understand some parts were wet, and this may effect the long run, but it doesnt mean they are damaged or destroyed. Open the bonnet and leave it in sun for 2 days. Let the things dry up first.
The only thing i am worried about is that the ECU may have been fried up - thats about it.
Like i told you earlier on PM, look for the word "hydrolock, honda, civic" on google.
Also start searching on dedicated Civic Forums about this and post your story.
There are "proper" honda civic experts hanging around on the US based forums. They can give you right information.
After all, your car was running fine until the very last minute! Everything cannot be destroyed immediately, all at once.
The dealer quote seems to be - precautionary measure quote, in which they will assume and replace everything they feel may be bad.
aerohit is offline   Reply With Quote
Old 6th September 2008, 21:38   #45
Awaiting Email Confirmation
Thanked: 20 Times
That is a huge estimate. hope things work out well for you. I suppose this explains your wanting an SUV as your next car.
Honda Civic stuck in flash flood mvineet Technical Stuff 39 1st September 2010 13:24
Chevy Spark got stuck in water logging. URGENT Help needed Lord Lucan Technical Stuff 33 21st October 2009 21:02
Corsair Flash Voyager 8 gb flash disk - Corrupt? nishantgandhi Gadgets, Computers & Software 5 28th July 2009 14:55
Doors getting stuck in Mumbai Flood psp62in Technical Stuff 16 18th August 2005 14:42
