Go Back   Team-BHP > BHP India > The Indian Car Scene
Closed Thread
Old 3rd March 2009, 11:00   #31
SumitBahl's Avatar
Thanked: 219 Times
Originally Posted by luvjascha View Post
So, if I put new tires, will that resolve the breaking noise completely?
Definitely.
If you want to stick to 14" go for either 185 or 195.
SumitBahl is offline
Old 3rd March 2009, 11:06   #32
Ice
Ice's Avatar
Thanked: 102 Times
Brake Failure: Total loss of any kind of stopping power. Pedal depresses all the way to the floor, and driver has an omigod expression. Seen often in movies where the hero's rich father dies in a car accident.
Poor braking and brake failure are 2 entirely different thing! Poor braking can be caused by a variety of external factors, such as poor (wet/loose sand) road surface, tyres (narrow, bald, over/under inflated), wearing down of brake pads and discs, and other such reasons. The car takes longer to stop, and probably stops with great drama. But it still stops!
Mods, delete the thread, or at least change the title please!
Ice is offline
Old 3rd March 2009, 11:32   #33
lin-jo's Avatar
Default Looks like I stirred up a hornets nest
Looks like I stirred up a hornets nest here. Well I was not sure when my post would appear on the forum, and hence the delay in responding.
Read through all the reply posts - let me try to provide answers to a few questions(that stick on the top of my mind) raised across the thread:
1. Is this post driven by any Maruti competitor? Hell No!!. I am also just one of the many folks trying to zero in on a good car to buy.
2. Do I own a swift? No. I am researching which car to buy.
3. What car does my co-worker own? - He owns a Swift Petrol!!.
4. Is this a rumour? -As far as my co-worker's experience is concerned, no! He was driving Bangalore Chennai- and the Swift brakes just failed. Steering also froze. Ended up ramming into the back of a tractor trailer - his spouse got injured. By God's grace nothing else happened. His car got badly damaged. He showed me photographs. If I get them I will post them.
In addition, it was at this instance that he learned that
Maruti was trying to brush it under the carpet.
5. Is this an issue with ALL Swifts? No idea- rather - it is highly unlikely. I was trying to get the BHPians experiences up here to get clarity and an understanding on the gravity of the incidence.
6. Is it due to the stock tyres? - No. It had nothing to do with the tyres. The brakes just went hard is what he said. No response on pressing the brake as hard as one could try.
lin-jo is offline
Old 3rd March 2009, 12:31   #34
Thanked: 7 Times
This thread has served a purpose of getting all Swift owners to speak up.
Definitely Swift has no brake failure issues. This thread title is an exaggeration.
Regarding poor breaking as mentioned by others here, this is a relative term depending on the cars one has handled before. In the segment Swift is positioned it has a superior quality of brakes. Same is not applicable for the OE tyres used in Swift.
emkay456 is offline
Old 3rd March 2009, 12:44   #35
tazmaan's Avatar
Thanked: 1,246 Times
I am facing the same problem of weak brakes on my Swift Vdi (No ABS). I have upgraded my tires but the problem is not about wheel locking or skidding. Its just that they are weak. I had raised this issue on my first service and the Sai service attendant told me that the brakes are normal and you are welcome to check it on any other swift. I drove another LDi and the brake felt the same. After this I immediately upgraded my tires and the brakes still feel the same.
I had a palio before, I have an Innova and santro as well so comparing brakes with these cars. Even my santro that has driven 50k kms have better brakes.
I was also explained (Sai Service) that the in gear braking on swift D is bad because of the torque that engine produces. I have experience it. I went upto speed of 70 ( 4th Gear) and hit the brakes without cluth the car slowed down to around 50 and then the brakes felt very weak and at 40 I pressed the clutch. However I did the same by pressing the clutch and braking, the braking was much better.
Is it possible that suzuki carried forward the brakes of petrol swift to swift D and is not adequate enough for the torque it produces?
Is it possible I can upgrade the brake pads to some performance ones for better bite? I personally suspect very hard break pads for a longer life.
Experts advice I am scared to drive my swift on Highways anymore because of this reason.
tazmaan is online now
Old 3rd March 2009, 12:45   #36
Thanked: 50 Times
Default No brake issues so far
I own Swift ZXi, driving it for last 3.5 years and never experienced any braking issues. I have driven it on good roads, bad roads, ghats and highways. Few times had to brake at 100+ speed, and it responded as expected.
Selective is offline
Old 3rd March 2009, 12:57   #37
abhilash_iv's Avatar
Thanked: 12 Times
From these words it looks like the engine got switched off (how?). Only then the Steering will freeze and the brakes loses the power. I think he should investigate why the engine was put off at that time?
In my experience with my Swift D, never felt that the brakes were insufficient.
abhilash_iv is offline
Old 3rd March 2009, 12:58   #38
I've done a lot of highway driving on my Swift, and I've never faced any serious break-related problems. So, the issue isn't about poor/weak braking, but the noise that emanates while breaking or when making tight turns.
luvjascha is offline
Old 3rd March 2009, 13:09   #39
Thanked: 26,313 Times
I haven't heard of or experienced any brake problems with Swifts. My uncle's ZXi is now more than 2 years old and the brakes are still very good. The JBL cars that I had been driving for a while didn't suffer from brake problems either. The one problem that most Swift owners I know are complaining about is rattle.
Brake trouble - maybe a one off case or just plain rumors.
Aditya is offline
Old 3rd March 2009, 13:39   #40
Thats serious lin-jo. Glad that all are safe.
Maybe the problem is with certain batch of Swifts. Could you get the manufacturing date of that particular Swift?
Its just a mechanical part. It can fail. How can you be so sure it will never fail?
diabloo is offline
Old 3rd March 2009, 13:56   #41
sriramv.iyer's Avatar
Thanked: 713 Times
Unhappy Brake failure for me
I am a victim of Swift brake failure - I had a VDi Swift + ABS with ZXi tyres and alloys (wider tires)
The brakes failed me at a crucial moment, and I had the worst accident of my life. The car got totaled, but that was the least of my problems.
I swore not to buy any Maruti stuff ever again in my life. (I am free to have my own opinion based on my experience - I am not telling all Swifts are bad. Just that I cannot buy any Maruti ever again in my life, unless something drastic happens)
I am not a novice driver either. The brakes locked and I couldn't use the ABS.
I am not writing more about it because the accident was quite traumatic for me personally.
sriramv.iyer is offline
Old 3rd March 2009, 14:07   #42
anachronix's Avatar
Thanked: 1,277 Times
@Sriram: Sorry about the incident!
And this news is a shocker!
anachronix is offline
Old 3rd March 2009, 14:18   #43
babhishek's Avatar
3 years of ownership - no problems yet. rumors suck!!
babhishek is offline
Old 3rd March 2009, 14:26   #44
Rumors don't suck. People are simply narrating their experiences.
Old 3rd March 2009, 14:29   #45
One of my friend had a similar brake failure in his Swift Dezire and rammed into a truck.. he also swears he'll never buy a Maruti again..
solly is offline
Closed Thread
5000kms and 12 Passes, a 20 day wild wild ride to the roof of the world! tsk1979 Travelogues 556 19th August 2015 10:42
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
A Wild Wild ride to the Mighty Chansal Ghati tsk1979 Travelogues 44 26th January 2009 18:21
ICICI Bank Bankruptcy News...Rumour?? (EDIT: Yes it was an absolutely baseless rumor) RuffRyder Shifting gears 49 30th September 2008 19:42
WagonR - Alpine+Coustic+Kicker=Space Saving (No tall claims though!!!) pt7 In-Car Entertainment 18 22nd July 2008 23:38
