Go Back   Team-BHP > BHP India > The Indian Car Scene
Closed Thread
Old 10th September 2009, 21:17   #31
14000rpm's Avatar
Thanked: 639 Times
Years back DC had done a great looking convertible version of the reva(?). Had seen pics of it in red - anyone have those pics?
DC doesn't seem to have his hand here. its an all Reva effort and its getting better. kudos reva for surviving in this niche segment for this long and continuing development.
14000rpm is offline
Old 10th September 2009, 21:24   #32
Mpower's Avatar
Thanked: 1,686 Times
I dont see any details about the motor.
Last gen REVA had an low tech DC motor with simple controls.
any idea who is the batt supplier.
Mpower is offline
Old 10th September 2009, 22:40   #33
pratim's Avatar
Thanked: 12 Times
My guess on "remote charging" (from my basic knowledge):
  1. Li-Ion batteries are not designed to be TOTALLY discharged (aka deep-cycled), and doing so can damage the batteries.
  2. Typical working range per cell is from 3.0v(discharged) to 4.2v(charged)
  3. As a result, Li-Ions are paired with microchips that cut off the power when battery voltage drops below a certain threshold, or charges beyond the higher threshold.
  4. To prolong long-term battery life, i would imagine rasing that lower limit threshold by 5-10% helps.
  5. On the rare occasion that you NEED to use that additional 5-10%, you can call REVA and they enable it by telling the microchip to let you decharge down to x.x volts.
  6. Why call? - Coz this prevents you from doing it often/whenever you feel like and they can keep track of how you treat your batteries! (Kinda like how BMW only lets you use launch control X times!)
(There must be some fine print on the number of times youre allowed to "remotely charge" / effect on battery warranty!)
Open to corrections on the above, it could be a totally different system, but this would be my guess!
Wow, great stuff.
Just to elaborate or, in other words, to confuse further :
Let's assume the battery's usable energy is x AH(amp-hour). The battery gets cut off when it's drained off beyond this threshold. There is an additional 5% (approx) charge remaining at this point to avoid deep discharge and thus damaging the battery.
So, it may be quite possible that Reva will not allow to use this percentage.
Then where from the reserve power come from? It is quite possible that actually 0.8x AH (just a figure I am assumming)is made available to the car user for normal operations that give you a 80 KM range (for lead acid batteries?).
So, this SMS might just help this 20% reserve power to be available when needed.
This is quite simple with embedded software controlling the microcontroller responsible for power management.
-Pratim
pratim is offline
Old 10th September 2009, 23:09   #34
tushky's Avatar
Thanked: 772 Times
Originally Posted by sidindica View Post
This is the production Reva NXG from Reva press release via Indian autos blog.
the design is too similar to European Honda Civic Hatch.
Gen II Reva NXR revealed EDIT : Launching at Frankfurt Motor Show 2009-eurocivic_side.jpg
Gen II Reva NXR revealed EDIT : Launching at Frankfurt Motor Show 2009-3896758772_e602abec0c_b.jpg
tushky is online now
Old 10th September 2009, 23:13   #35
Thanked: 3,919 Times
Actually it resembles a shrunken version of Tarzen a wonder car.
sidindica is online now
Old 10th September 2009, 23:35   #36
khanak's Avatar
Thanked: 130 Times
Source - Don Burleson Blog: 3/2/08 - 3/9/08
khanak is offline   (1) Thanks
Old 11th September 2009, 09:11   #37
14000rpm's Avatar
Thanked: 639 Times
now I was hasty i'm replying DC hadn't had his hand on the new reva but I hadn't noticed the NXG pic. Now that definitely has DC's traces. I'm still trying to look for the image of the DC Mod'd red civic displayed in all Central outlets. Now the NXG has some of those lines on it. think about it guys.
14000rpm is offline
Old 11th September 2009, 09:31   #38
ACM
ACM's Avatar
Thanked: 2,821 Times
Looks cute, wish the Indian car companies could deliver on their plans faster.
ACM is offline
Old 11th September 2009, 11:20   #39
vcash's Avatar
I am really intrigued by the NXG. I think this makes perfect sense for someone who wants a second or third car as a small runabout to travel around your locality.
This could be a great substitute for folks evaluating the Nano for the same purpose. Only this has the green and cool factor to boot.
I hope Maini does not bypass the Indian market with lame 'No room for 2-Door Cabriolets' excuse.
By my estimates, NXG and NXR should be able to push a 500 - 700 cars a month provided they do not cross the 2.5 to 3L price point. Any opinions on this?
vcash is offline
Old 11th September 2009, 17:56   #40
14000rpm's Avatar
Thanked: 639 Times
Originally Posted by vcash View Post
I
2.5 to 3L? you joking? the last held discussion with the maini folks indicated a figure of 5 L for the NXR. and then, the NXG wasn't even part of my conversation.
14000rpm is offline
Old 11th September 2009, 18:17   #41
The current reva retails from 3-4.5 lakh (for the classe, in Delhi)
Expect this to be about 5.5-7L.
Old 11th September 2009, 23:03   #42
14000rpm's Avatar
Thanked: 639 Times
Note from Mod : Please do not post scans / pictures from Indian Publications without explicit permission to do so.
You may point to the publication/issue/page number instead.
Thanks.
Last edited by Rehaan : 12th September 2009 at 10:25. Reason: Please see note in post.
14000rpm is offline
Old 12th September 2009, 11:13   #43
14000rpm's Avatar
Thanked: 639 Times
Thanks.
@mods, point is clear.
More info in ACI sep '09 edition pg 19.guess the rear has got the DC signature design on it. read quirky.
14000rpm is offline
Old 12th September 2009, 13:23   #44
BomBatt's Avatar
Default GM's Spark looking to ride on Reva's technology
12 Sep 2009, 0714 hrs IST, Nandini Sen Gupta, ET Now
NEW DELHI: General Motors India, the wholly-owned subsidiary of American carmaker General Motors Corporation, is in advanced talks with the world’s leading electric car manufacturing company, Bangalore-based Reva Electric Car Company, for a technical collaboration and a joint venture, executives close to the development said.
GM India will source electric vehicle technology from Reva to roll out electric variants of its Chevrolet Spark small car in India and select overseas markets.
“We have been pursuing opportunities for commercial application of alternative fuel options, including bio-diesel, jatropha arrangement with CSMCRI (Central Salt and Marine Chemicals Research Institute), electric, fuel cell, hydrogen etc, with many parties for quite some time,” said GM India’s vice-president of corporate affairs, P Balendran. “Our efforts are ongoing and we have nothing to announce as of now. As soon as we finalise our plans for introduction of any alternative fuel solutions, we will announce the same,” he added.
The two companies will enter into a 50:50 joint venture (JV), which is currently awaiting the green signal from GM’s Detroit headquarters. If the JV goes through, it will be GM’s first deal since it filed for Chapter 11 bankruptcy.
The new alliance is another indicator of how much the Indian market means to the Chevy (Chevrolet) brand and the significance of electric vehicles in GM’s growth plans. GM has already indicated that it will introduce the Volt electric vehicle in India in a completely-imported form.
The Reva tie-up is crucial for General Motors because it will offer the cash-strapped Detroit major the chance to source the technology of the future at more competitive rates.
GM has already indicated that e-vehicles are its chosen technology of the future. And it’s not the only one. Ford and Chrysler as well as Japanese auto majors Toyota, Nissan and Honda are all queuing up.
Reva has just announced that it will unveil two new models at the upcoming 63rd Frankfurt International Motor Show. The Reva NXR (next revolution), a sporty two-seater with a targa roof, will go into production in 2011 and the REVA NXG (next generation) will be available from next year.
Source:
GM's Spark looking to ride on Reva's technology- Automobiles-Auto-News By Industry-News-The Economic Times
BomBatt is offline
Old 12th September 2009, 14:37   #45
14000rpm's Avatar
Thanked: 639 Times
Originally Posted by BomBatt View Post
The Economic Times
bravo reva. way to go. finally Maini gets their due paid out. international exposure is a big push forward for Reva.
14000rpm is offline
Closed Thread
SCOOP : Detailed Reva NXR pictures. UPDATE: Badged as the "E2O" mac187 The Indian Car Scene 204 1st April 2013 11:47
Reva NXR : Auto Expo 2012 Rehaan The Indian Car Scene 52 11th January 2013 18:47
First test drive of Reva NXR electric car MikeBoxwell Test-Drives & Initial Ownership Reports 21 12th December 2012 14:22
Scoop PICS : Maini Reva NXR caught testing in Bangalore! driving_smartly The Indian Car Scene 67 24th February 2012 19:53
Next-Gen Hyundai i30 - Revealed ahead of Frankfurt! Scorcher The International Automotive Scene 39 4th November 2011 09:47
