Go Back   Team-BHP > BHP India > The Indian Car Scene
Closed Thread
Old 25th October 2009, 20:38   #301
Whats the difference between VVT engine and earlier engine of SX4. One can currently get 50k discount on older model.
Is it worth losing 50k discounts + increased price (assumed) for new SX4 or should I go in for previous model?
compenn is offline
Old 25th October 2009, 22:33   #302
aaggoswami's Avatar
Thanked: 1,495 Times
Its VVT engine is equipped with Variable Valve Timing. Modern VVT allow variable lift + variable cam phasing. Earlier only lift was changed, but later on cam phasing also came in. Nissan VVEL, Toyota Valvematic and Advanced VTEC are the latest and most effective variable valve timing systems.
What this helps is in overall increase in torque and power along with a better spread of torque and power throughout the powerband.
A thread on TBHP for VVT :
http://www.team-bhp.com/forum/techni...on-thread.html (Variable Valve Timing discussion thread)
aaggoswami is offline
Old 26th October 2009, 00:38   #303
SLK
SLK's Avatar
Thanked: 190 Times
New SX4 specs
Engine:
Max Output 104.68ps @ 5600 RPM
Max Torque 145NM @ 4100 RPM
Don't really see any change in driving, practically speaking.
SLK is offline
Old 26th October 2009, 06:55   #304
In layman terms VVT is a piston technology that allows for variable valve opening / closing time (VVT - Variable Valve Timing) thereby the controlling the amount of air intake into the engine. The amount of air+fuel mixture ratio cannot be constant across the RPM level (Of course non VVT technologies control this mix based on the engine RPM and ECU tuning but not as good as VVT). One has to have more air intake at higher revs for better performance of the engine but at the same time to much air in engine at lower RPM might stall it - basic engine science. So with VVT controlling the air intake dynamically you will have a better throughput from the engine across the RPM band and an increased fuel economy since the right mixture of air/fuel is burnt. This is the primary theory though there is a lot more to VVT technology that you can Google for yourself.
As for spending a additional 50 - 80K, if you are looking for a long term ownership and if you are driving enthusiast, i would suggest you go for the VVT engine. You will have improved engine performance at lower power band that SX4 suffers from right now. You may also see a better mileage if you drive it rightly. Tip - Honda is known for its fuel economy with better power because its VTEC is one of the better designed VVT technology.
srikanths1 is offline
Old 26th October 2009, 10:09   #305
ACM
ACM's Avatar
Thanked: 2,825 Times
With the SX4 brochure already been leaked by Sid on another thread as the starting thread, shouldn't this thread be closed now or merged with the SX4 Brochure thread?
ACM is offline
Old 26th October 2009, 14:35   #306
Technocrat's Avatar
Thanked: 2,587 Times
Hi All please continue the discussion on new SX4 in This Thread (New SX4 VVT brochure)
Thread Closed
Technocrat is offline
Closed Thread
Nissan halts Evalia production due to poor sales Aditya The Indian Car Scene 36 29th June 2015 13:10
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
quake halts jap car production pawan The International Automotive Scene 2 19th July 2007 11:25
Scandal-hit VW 'halts India plan' ajmat The Indian Car Scene 8 5th July 2005 12:39
