Go Back   Team-BHP > BHP India > The Indian Car Scene
Old 16th August 2010, 15:28   #31
MAS
MAS's Avatar
Thanked: 1,207 Times
This is a good feature as different engines are tuned differently and this will help the driver to change the driving style as per the engine tuning to extract maximum mileage.
It is only question of time that one would get used to this indicator and then it would be just another "gadget".
MAS is online now   Reply With Quote
Old 16th August 2010, 17:40   #32
vigneshA's Avatar
Thanked: 34 Times
This is nice feature to have for beginners. However it would be interesting to have this operate on dual mode. Meaning I can select Power or Economy mode and the gear shift indicator will indicate up/downshift accordingly - early on rpm in economy mode than in power.
vigneshA is offline   Reply With Quote
Old 16th August 2010, 18:07   #33
agbenny's Avatar
Thanked: 111 Times
Default Indy-Cator
Pete's has a product called Indy-Cator, priced Rs.7800, It that just another fancy gadget? It replaces the gear knob, that seems strange to me, who will look at the knob each time when shifting gears?
agbenny is offline   Reply With Quote
Old 17th August 2010, 16:21   #34
Thanked: 99,884 Times
Smart suggestion, but its actually very simple:
- Economy / regular driving : Change gears according to the shift indicator
- Power mode : Shift at the redline, each & every time
It's rubbish. Don't waste your money.
Old 19th August 2010, 10:23   #35
Thanked: 9 Times
Originally Posted by iPai View Post
Next time when i drive the beauty i will make sure i note down the up shift and downshift instants in kmph and/or rpms
This should point to some kind of optimum driving style for i20 right?
Well, checked yesterday! It is as per the general understanding of owners of cars with the kappa engine: Up shift at 2000 rpms!
As i observed, the indicator used to inform right at around 1900rpms except for the 4th to 5th gear upshift where it asks for an upshift at around 2100 rpms.
But downshift was not at some fixed rpms! It was asking for a downshift just before the lugging point, i felt. Which is good!! For example, when i was in 4th gear and after reaching 2100 rpms, i moved to 5th also as per the indicator, then during the course of the drive, even when the engine was at 1500 rpms, yet steady, no indication whatsoever to move down to 4th! Only when there was proper deceleration, the indicator showed up, for downshifting!
So overall, i feel this feature is something which works pretty well and not a mere gimmick.
iPai is offline   Reply With Quote
Old 7th October 2010, 15:09   #36
sunnyside's Avatar
Does the gear shift indicator also give audible warning like "Up" or "Down"??
Looking down into the console everytime you want to shift gears would be dangerous with all 2 & 3 wheelers around.
Nevertheless its a good feature for ladies and Uncles
sunnyside is offline   Reply With Quote
Automated Manual Transmission (AMT): The new buzz in India volkman10 The Indian Car Scene 322 13th May 2018 17:21
Mercedes Benz 300D (W123 series): Manual Transmission to Automatic Transmission. wartikars Post-War 5 3rd January 2014 12:39
Cable Shift vs Direct Shift Gearboxes BlackPearl Technical Stuff 14 15th September 2013 13:35
TechInfo : Gear Shift Indicator dadu Technical Stuff 5 23rd January 2009 17:28
Wanted Tachometer with gear shift indicator for my Gypsy Hemanth Shifting gears 4 3rd January 2008 15:41
