Go Back   Team-BHP > BHP India > The Indian Car Scene
View Poll Results: which is the best point to upshift for best efficiency?
1000-2000rpm 9 16.07%
1500-2500rpm 29 51.79%
2000-3000rpm 12 21.43%
2500-3500rpm 6 10.71%
Voters: 56. You may not vote on this poll
Old 16th December 2005, 20:18   #1
.anshuman's Avatar
Thanked: 9,136 Times
Default Best engine speed to upshift for indian petrol cars
what do you think is best engine speed to shift to next gear for best fuel efficiency?ive heard that in cars with knock sensors we should not let the car go below 1200rpm because knock sensor can waste fuel,i think the rpm should never be streched beyond maximum torque point if we are extracting most out of every litre.i have been experimenting frequently.i got best efficiency from my accent on driving between 1700rpm-2700rpm.i never had problem with diesel cars because whichever way i drive them they never sip much diesel.
Old 16th December 2005, 20:33   #2
abhibh's Avatar
Thanked: 33 Times
I never exceed more than 2k rpm until and unless some one pisses me off..
Old 16th December 2005, 20:47   #3
The Wolf's Avatar
Thanked: 58 Times
[SIZE=2]2000rpm is ideal according to me for fuel effeciency but again this is subjective as cars with low "low end torque" requires slightly higher shifts. For example in my VTEC, 2500rpm shifts are perfect or else there is every probability that I might encounter knocking, till the next gear picksup revvs. Cars with no knock sensor will demand a higher rpm shift... No clue about diesels as Ive never used one...[/SIZE]
The Wolf is offline   Reply With Quote
Old 16th December 2005, 20:51   #4
islero's Avatar
A very experienced chauffer ( he really is an amazing driver) told me that in 1st gear, one must shift at 2500-300 and take it easy in the rest of the gears.
I myself am not qualified to comment.
islero is offline   Reply With Quote
Old 16th December 2005, 21:52   #5
sbasak's Avatar
You need to know engine's power torque curve to determine exact shifting point.
See my posting on this here
http://www.team-bhp.com/forum/techni...-movement.html (Physics behind car's movement)
sbasak is offline   Reply With Quote
Old 16th December 2005, 22:01   #6
general_neo's Avatar
Thanked: 26 Times
Exactly the point... Every engine is different and the torque and power curves are different... So the shift should differ accordingly.
No offence to the person who started the thread... but this thread makes no sense.. Or someone could start talkin about the shift rpm on each car... And the Poll is useless and wont get us to any conclusion. Most of the the low end cars dont even have a tachometer... Howeverl u can talk based on speed but... well back to my first question... wats the point?
Chill...
general_neo is offline   Reply With Quote
Old 16th December 2005, 22:30   #7
nitrous's Avatar
Thanked: 285 Times
I think 2000 to 3500 would be an optimum range for any petrol car. Diesels will have a lesser point.
My God, The safari Dicor redlines at 3000 rpm.
Old 16th December 2005, 22:57   #8
Shan2nu's Avatar
Thanked: 89 Times
I usually shift between 2500-2700 rpm.
Shan2nu
Old 16th December 2005, 23:37   #9
Rudra Sen's Avatar
Thanked: 4,259 Times
Interesting!!! How do you figure out your torque point?
How does it help you to get the best efficiency? In terms of performance and fuel?
Old 17th December 2005, 00:06   #10
.anshuman's Avatar
Its the specific rpm where the engine produces maximum torque .
Old 17th December 2005, 00:08   #11
Godfather's Avatar
Thanked: 65 Times
[SIZE=2]I think 2500 to 3000 should be a good shift for better mileage... I should try it sometimes.....[/SIZE]
Godfather is offline   Reply With Quote
Old 17th December 2005, 00:23   #12
speedsatya's Avatar
Thanked: 710 Times
it will be different for different cars ...in a mpfi zen ..i ahve got best Fe while staying below 2k and shifting between 1500-2k....FYI the mpfi zen does 80 kph in 5th gear at 2k rpm .
speedsatya is offline   Reply With Quote
Old 17th December 2005, 01:32   #13
Deeps's Avatar
Thanked: 68 Times
I am with nitrous. The specific point may vary but generally, it should be in the range of 2000 to 3500 rpm for most petrol cars in India.
And the Dicor really redlines at 3K? Thats like big buses/trucks!!
Deeps is offline   Reply With Quote
Old 17th December 2005, 02:35   #14
revtech's Avatar
Thanked: 35 Times
if your really concerned about fuel efficiency i feel its ok to shift between 1500 - 2000 rpm.
Rev
revtech is offline   Reply With Quote
Old 17th December 2005, 02:55   #15
Max
Thanked: 85 Times
Originally Posted by abhibh
which car do you drive ? I keep my RPM at 2500 on average for good fuel efficiency but I am really power hungry kind of person and most of times I drive NHC at 3000 RPM - 100-110kmph
Max is offline   Reply With Quote
Old Bollywood & Indian Films : The Best Archives for Old Cars anjan_c2007 Vintage Cars & Classics in India 1205 9th May 2018 00:09
The best car ads artofzen The Indian Car Scene 526 16th April 2018 14:45
Diesel:Petrol Car Sales Ratio. Major Shift in favour of Petrol Cars! RSR The Indian Car Scene 70 26th February 2017 11:46
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
Best Engines in Indian cars amit The Indian Car Scene 26 6th July 2006 13:14
